minejash
Codes to Add Text only and no need leader..
minejash
hai, i need a small help.i have a working lisp routine which gives perpendicular line distance to main line when clicked on a place perpendicular, only thing i want to try and add is to remove the leader that adds and only add text without leader in position where i can click. pls reply if its possible... thanks:)
(defun c:Test ( / s p c a d)
 (if (and (setq s (car (entsel "\nPick a polyline :")))
        (or (= (cdr (assoc 0 (entget s))) "LWPOLYLINE")
            (alert "Invalid object! Please pick a polyline only.")
        (setq p (getpoint "\nSpecify point perpendicular to polyline :"))
        (setq c (vlax-curve-getclosestpointto s p))
        (setq a (angle p c))
        (not (grdraw p c 1 -1)) ;; rubber line in red colour.
        (setq d (angle '(0. 0. 0.) (vlax-curve-getfirstderiv s (vlax-curve-getparamatpoint s c))))
        (or (or (equal (rem (+ d (* pi 0.5)) (+ pi pi)) a 1e-4)
                (equal (rem (+ d (* pi 1.5)) (+ pi pi)) a 1e-4)
            (alert "Picked point is not a perpendicular to picked polyline. <!>")
 (command "_.leader" "_non" p "\\" "" (strcat "CHAINAGE=3+0" (rtos (vlax-curve-getdistatpoint s c) 2 4)) "")
) (vl-load-com)
Edited by SLW210
Fixed Code Tags
Share this post
Link to post
satishrajdev
Try this :-
(defun c:Test (/ s p c a d)
 (if
   (and
	       s
  (alert
    (entmakex
      (list
 '(0 . "text")
 '(100 . "AcDbEntity")
 '(67 . 0)
 '(370 . 13)
 '(100 . "AcDbText")
 (cons 10 p)
 (cons 40 2.5)			[color="red"]; Change text height here[/color]
 (cons 1
       (strcat "chainage=3+0"
 (cons 71 0)
 (cons 72 0)
 (cons 11 '(0 0 0))
 '(100 . "AcDbText")
 (cons 73 0)
(vl-load-com)
Share this post
Link to post
minejash
Thank u, it works good
but just want to know if its possible to select the text location manually, as this code lets the text at the point where i click for distance. Like the leader starts and then text location except no leader needed, only text. If possible it would be nice.
This code really helps a lot, thank you so much..
Share this post
Link to post
minejash
also is it possible to continous the command after i select the polyline, like i select the polyline then after were ever i click it gives the distance to it, (like MULTIPLE command).
the current command ask for polyline after every click and length.. thanks:)
Share this post
Link to post
satishrajdev
Command is continuous in this code as per your requirement:
(defun c:Test (/ s p c a d tp)
 (if
    (while
      (and
 (setq
		  s
 (or
   (alert
 (setq tp (getpoint "\nSpecify Point for Text : "))
(entmakex
  (list
    '(0 . "text")
    '(67 . 0)
    '(370 . 13)
    '(100 . "AcDbText")
    (cons 10 tp)
    (cons 40 2.5)		; Change text height here
    (cons 1
    (cons 71 0)
    (cons 72 0)
    (cons 11 '(0 0 0))
    '(100 . "AcDbText")
    (cons 73 0)
(vl-load-com)
Share this post
Link to post
satishrajdev
I've updated code above for continuous operation, check it
Share this post
Link to post
minejash
Thank you so much. It works perfectly...:D
i didn't know how to change the code to simple text sting, thanks so much...
Share this post
Link to post
satishrajdev
You're welcome :beer:
Share this post
Link to post
SLW210
Please read the Code Posting Guidelines and have your Code to be included in Code Tags.[NOPARSE]
Your Code Here[/NOPARSE]
Your Code Here
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
