i've been trying to create a macro or lisp that will offset a line and change it's layer.
the macro works fine
^C^C_offset;;\\ change Last;;P;La;S-Reveal;;
but i need to do this a lot. if i do the macro and finish it, i hit enter like i want to repeat the macro but it only repeats the last command on the command line "change".
can a macro repeat itself with user input to cancel? i think that's where lisp comes in. i've been looking over lisp tutorials and it doesn't make any sense to me. i learned it 8 years ago and have completely forgotten. here's my pathetic attempt at lisp to do the same thing:
; This command creates a 3/4" chamfer around window openings and panel edges
(defun c:CE ()
 (command "offset" "3/4"
you'll notice it just kind of trails off like a kid with A.D.D.
is there a lisp tutorial that can help me learn it from scratch?
also, can a macro be assigned to command line entry? or button only?
edit:
well, my co-worker just solved the problem with "offset: layer" option. well, that was an afternoon wasted.
i'm still dumb and want to know more about lisp.
You may abuse this one. :)
;;  Offset 0.75 to layer "0"
(defun c:ce (/ ent pt)
 (while (and
          (setq ent (car (entsel "\nSelect object to offset 3/4 or <exit>:")))
          (setq pt (getpoint "\nSpecify point on side to offset:"))
   (command "._offset" 0.75 ent "_non" pt "")
   (command "._change" (entlast) "" "_P" "_LA" "0" "")
  • 10 months later...
this lisp is great..how can it be modified so I can choose the offset distance and it not default to 3/4"
  • 1 year later...
Try this (start the command by typing "ol"):
;OffsetCurrent.lsp - Offsets a line to the current layer and linetype
(defun *error* (s)
(repeat 3 (command))
(cond ( (member s '("Function cancelled" "console break"))
(princ "*cancel*"))
(t (princ (strcat "\nError: " s))))
(setvar "highlight" 1)
(setq *error* olderr)
(defun get_offspec ( / e d)
(cond ( (setq e (entsel "\nObject to offset/CR for new distance:")))
(t (setq ofst (xgetdist "\nNew offset distance" ofst))
(if (= ofst nil) (setq ofst ofst3))
; (while (not (setq e (entsel "\nObject to offset: "))))
e
(defun xgetdist (msg def)
(cond ( (getdist (cond (def (strcat msg " :"))
(t ": ")))))
(defun C:ol (/ clay *error* lastent lastinfo olderr uecho offit offpnt ofst ofst2 ofst3 x)
(setq olderr *error*)
(setq uecho (getvar "cmdecho"))
(setvar "cmdecho" 0)
(setq ofst2 ofst)
(if (= ofst nil) (setq ofst 0))
(prompt "\n Offset Distance
(prin1 ofst)
(prompt "> :")
(setq ofst (getdist))
(if (= ofst nil) (setq ofst ofst2))
(setq x 0)
;(while (
(setq offit (get_offspec))
(setq offpnt (getpoint "\nChoose side to offset :"))
(command "OFFSET" ofst offit offpnt "")
(setq ofst3 ofst)
(setq clay (getvar "CLAYER"))
(setq lastent (entlast))
(setq lastinfo (entget lastent))
(setq lastinfo (subst (cons 6 "BYLAYER") (assoc 6 lastinfo) lastinfo))
(setq lastinfo (subst (cons 62 256) (assoc 62 lastinfo) lastinfo))
(setq lastinfo (subst (cons 8 clay) (assoc 8 lastinfo) lastinfo))
(entmod lastinfo)
dont k how to get rid of the smiley face, it should be defun c: and the letter "O"
oops. this was a really old thread I started. Had I just paid more attention to the command line I would have noticed that when you enter OFFSET there's options of "Through/Erase/Layer". Make Layer "Current" rather than default "source" does what I need it to do.
