#1 |
Full Member
![]() ![]() Using: AutoCAD 2009 Join Date: Sep 2009
I'm looking for a procedure to scale objects along 1 axis only.
The varia command doesn't work this way. It always scales along all 3 axis. Workaround: make objects block delete objects insert block scale block in x,y- or z-direction only. As I like to automate things , this appears a little like awkward.Can anybody help? Thanx! |
#2 |
Forum Deity
![]() ![]() ![]() ![]() ![]() Using: Civil 3D 2009 Join Date: Sep 2006
The lisp routine found here does what your workaround does
http://www.cadtutor.org/forum/showthread.php?t=23441 |
#3 |
Super Member
![]() ![]() ![]() ![]() Using: Civil 3D 2009 Join Date: Apr 2008
Temporarily converting it to a block is probably the best method, since you can't stretch things like circles.
Seann: ...it went crazy ex-girlfriend on me...
eric_monceaux...its pretty funny seeing two AutoCAD Gods give each other flak... |
#4 |
Full Member
hi lp,
thanks. i read the code thru and i guess you're right, it seems to do exactly what i described. strange enough that you have to do such things to get a result, which is the easiest thing in any other cad application. |
#5 |
Super Member
Kinda bored....
What about something like this: XYZ.gif Subroutine required: http://www.cadtutor.net/forum/showpo...9&postcount=42 Last edited by alanjt : 4th Nov 2009 at 04:53 pm. |
#6 |
Full Member
Hi Alan, thanks, but don't be too bored:
Code:
Befehl: xyz Objekte wählen: 1 gefunden Objekte wählen: Specify base point: Geometry factor to scale [X/Y/Z]: x Error: no function definition: AT:INSERTBLOCK |
#7 |
Full Member
![]() ![]() Using: AutoCAD 2008 Join Date: Mar 2009
Try FIT.lsp
see at thread http://www.cadtutor.net/forum/showthread.php?t=40104 It solves my problem. Last edited by ica_cici : 2nd Nov 2009 at 11:31 am. |
#8 |
Full Member
Hi ica,
I'm rotating with work right now. I hope I can try FIT.lsp today or tomorrow. PS: Alan, I just tried your zerorotation, as I had to rotate 5 floors of plan. it worked quite well except for some rooms, and it also rotated my cars in the garage. still, it saved me a load of work! thanxalot! |
#9 |
Full Member
I just read the readme of fit.lsp by xordesign. it says:
"This tool scales any selection of 2D elements to fit a custom X/Y boundry" I'm afraid I need to scale 3D elements. And either by a scale factor as well as with a reference. A pity that scaleaxis doesn't work properly. |
#10 | |
Super Member
Quote:
Guess that might help. ![]() http://www.cadtutor.net/forum/showpo...9&postcount=42 |
| Thread Tools | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Scale on one axis only | TonyMS | AutoCAD Beginners' Area | 3 | 15th Oct 2008 08:26 pm |
| Setting x/y axis scale? | therock005 | AutoCAD Drawing Management & Output | 8 | 12th Dec 2007 04:22 pm |
| Scale on one Axis? | spittle | AutoCAD Drawing Management & Output | 6 | 5th Oct 2007 12:07 pm |
| How to I change the scale in only one axis? | jps | AutoCAD General | 7 | 29th May 2007 10:59 am |
| How do I get all objects onto the same Z-axis plane? | lmingll | AutoCAD Drawing Management & Output | 9 | 22nd Jun 2006 10:10 pm |
