Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   AutoCAD Forums > AutoCAD > AutoCAD Drawing Management & Output
Reply
Thread Tools
Old 3rd Nov 2009, 04:58 pm   #1
bbudding
Junior Member
Using: AutoCAD 2000
Default Printing 3-D coming out as wireframe!!?
Hi,
What I see when I press "hide" is exactly what I want but when I print my 3-D models from AutoCAD 2000 - a messy wireframe comes out.
I really cannot be bothered to mess about with rendering, setting it all up etc.
I tried screen grabbing but the resolution is too rough for it to look presentable enough to look professionaly enough to my customers.
Can anyone help? Would be much appreciated.
Ben
bbudding is offline   Reply With Quote
Old 3rd Nov 2009, 05:07 pm   #2
Patrick Hughes
Senior Member
Patrick Hughes's Avatar
Using: AutoCAD pre 2000
In your plot dialog there should be a checkbox "Hide" - that will perform a hide to your model before printing, you'll be able to see it in the preview.
www.cadtempo.com Time Keeping for CAD
Patrick Hughes is offline   Reply With Quote
Old 4th Nov 2009, 11:17 am   #3
bbudding
Junior Member
Using: AutoCAD 2000
Thank you!! I spent four hours on Monday trying to do that! Go make youreself a cup of tea. You've earned it!
Ben
Old 4th Nov 2009, 05:01 pm   #4
Patrick Hughes
Senior Member
You're welcome.
Funny how simple things are when you know how to do them isn't it?
Old 5th Nov 2009, 02:13 pm   #5
bbudding
Junior Member
Using: AutoCAD 2000
Hello again. So I have been happily printing out 3-D shapes using the "hide" command.
I have now moved on to using them in our company layout template. Now when I print these out - even with the hide tick box ticked, the 3-D model comes out wireframe again!
Any ideas please?
Old 5th Nov 2009, 02:44 pm   #6
Secretagdan
Senior Member
Using: AutoCAD 2008
Try the following from the command line:
Command: MVIEW
Specify corner of viewport or [ON/OFF/Fit/Shadeplot/Lock/Object/Polygonal/Restore/LAyer/2/3/4] <Fit>: H
Hidden line removal for plotting [ON/OFF]: ON
Select objects:
Follow the prompts as shown. If you have text, you will likely find that if you 'hide' it that it wil print out in an outline. If you use this option, you will not need to check the 'hidden' in the plot dialogue box.
Secretagdan is offline   Reply With Quote
Old 5th Nov 2009, 04:43 pm   #7
bbudding
Junior Member
Using: AutoCAD 2000
Great. That gives me my outline 3-D drawing and my words back on the template in mormal print.
Only small point is that dimensions within the viewing window are outlines. Is there any way to print those out not as outlines? Tricky..
B
Old 5th Nov 2009, 05:23 pm   #8
Secretagdan
Senior Member
Using: AutoCAD 2008
The only option for that is to SOLDRAW/SOLVIEW, or USE FLATSHOT to make your 3-D model 2-D, to dimension it. You can also modify your dimension style to dimension in paperspace vs. model space.
Also take a look at this thread:
http://www.cadtutor.net/forum/showthread.php?t=28670
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
3D wireframe to 3D solid? acce AutoCAD 3D Modelling & Rendering 5 19th Sep 2009 12:32 pm
wireframe rendering mtlndg AutoCAD General 1 11th Oct 2007 01:21 am
Help with Wireframe!!! DanielMaid AutoCAD Beginners' Area 8 20th Sep 2007 02:05 pm
Well AutoCAD 2005 is coming and coming soon... f700es AutoCAD Drawing Management & Output 24 16th Mar 2004 09:37 pm
wireframe to solid? bop AutoCAD 3D Modelling & Rendering 4 30th Oct 2003 11:10 pm
Why Donate?
RSS Feed for AutoCAD ForumsValid XHTML 1.0!Valid CSS!Creative Commons Licence
