Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   AutoCAD Forums > AutoCAD > AutoCAD 2D Drafting, Object Properties & the Interface
Reply
Thread Tools
Old 4th Nov 2009, 10:49 am   #1
motee-z
Senior Member
Version: not specified
Default can,t copy to clipboard
Hello freinds
i have drawing make me tired i try to copy any object to clipboard
i got the message copy to clipboard failed
even if i draw new object in the drawing then try to copy it to clipboard i got same message
any help will be appreciated
thanks
motee-z is offline   Reply With Quote
Old 4th Nov 2009, 01:04 pm   #2
ReMark
Quantum Mechanic
ReMark's Avatar
Using: AutoCAD 2009
Is your version of AutoCAD 2008 current with the latest update?
When did the problem first occur?
What attached drawing?
Education is a lifelong process.
ReMark is offline   Reply With Quote
Old 4th Nov 2009, 01:05 pm   #3
motee-z
Senior Member
attached her dwg probem
i treid it with other version of autocad but same
i notice that the size of dwg is too big for entity contain
Old 4th Nov 2009, 01:07 pm   #4
Tiger
Super Moderator
Tiger's Avatar
Using: AutoCAD 2008
Motee-z - please do not post multiple threads about the same problem. If threads are mistakenly placed in the wrong forum, moderators will move them.
Rational paranoia: They're all out to get me and I have proof! - Randy DeLux
Tiger is offline   Reply With Quote
Old 4th Nov 2009, 01:20 pm   #5
motee-z
Senior Member
sorry mr tiger
some one advise me to post in correct place
so i thought here
Old 4th Nov 2009, 01:47 pm   #6
ReMark
Quantum Mechanic
ReMark's Avatar
Using: AutoCAD 2009
I advised motee-z to post in something other than the LISP, VBA and Customization forum. I thought he would stand a better chance of getting responses to his question. I'm off to the "stocks" for my punishment.
Old 4th Nov 2009, 02:26 pm   #7
Tiger
Super Moderator
Tiger's Avatar
Using: AutoCAD 2008
Quote:
Originally Posted by motee-z View Post
sorry mr tiger
so i thought here
yes, I saw, and ReMark is correct, you will usually get a better respons in the appropriate forum.
For future reference though, creating double threads is not recommended, and will create unnecessary clutter on the forums, which is why I merged them. If you accidentily create double threads, contact a Moderator to remove the unwanted one.
Old 4th Nov 2009, 05:33 pm   #8
eldon
Super Member
Using: AutoCAD 2002
To return to the problem originally posted, try starting a new drawing from scratch. Insert the troublesome drawing as a block and explode it.
eldon is offline   Reply With Quote
Old 4th Nov 2009, 06:55 pm   #9
motee-z
Senior Member
the original drawing is exceed than allowable size to post so i delete most objects if i use autocad 2010 the message changed
(there is a proxy object dosn,t allow to copy but i cant see a proxy object to delet it)so the problem stay
Old 4th Nov 2009, 07:09 pm   #10
eldon
Super Member
Using: AutoCAD 2002
I do not want your drawing. I was hoping that you would try my suggestion yourself, and you may find that it works.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
COPY or ** COPY ** - Copy and Stretch, Move, Rotate, Scale & Mirror objects Andrew1979 Tutorials & Tips'n'Tricks 2 27th Jul 2009 07:36 am
Copy an expression to the clipboard jammie AutoLISP, VBA, the CUI & Customisation 6 12th Mar 2009 06:44 pm
clipboard ZINC AutoCAD Drawing Management & Output 1 1st Jul 2005 03:32 pm
Slow Copy to Clipboard on some files, not on others? srobinson311 AutoCAD Drawing Management & Output 3 27th Jun 2005 08:22 pm
Copy to Clipboard / Copy with Base Point not working Orbit AutoCAD Drawing Management & Output 8 12th Oct 2003 03:10 am
Why Donate?
RSS Feed for AutoCAD ForumsValid XHTML 1.0!Valid CSS!Creative Commons Licence
