Hello freinds
i have drawing make me tired i try to copy any object to clipboard
i got the message copy to clipboard failed
even if i draw new object in the drawing then try to copy it to clipboard i got same message
any help will be appreciated
thanks
Is your version of AutoCAD 2008 current with the latest update?
When did the problem first occur?
What attached drawing?
attached her dwg probem
i treid it with other version of autocad but same
i notice that the size of dwg is too big for entity contain
t3.zip
Motee-z - please do not post multiple threads about the same problem. If threads are mistakenly placed in the wrong forum, moderators will move them.
sorry mr tiger
some one advise me to post in correct place
so i thought here
I advised motee-z to post in something other than the LISP, VBA and Customization forum. I thought he would stand a better chance of getting responses to his question. I'm off to the "stocks" for my punishment.
sorry mr tiger
so i thought here
yes, I saw, and ReMark is correct, you will usually get a better respons in the appropriate forum.
For future reference though, creating double threads is not recommended, and will create unnecessary clutter on the forums, which is why I merged them. If you accidentily create double threads, contact a Moderator to remove the unwanted one.
To return to the problem originally posted, try starting a new drawing from scratch. Insert the troublesome drawing as a block and explode it.
the original drawing is exceed than allowable size to post so i delete most objects if i use autocad 2010 the message changed
(there is a proxy object dosn,t allow to copy but i cant see a proxy object to delet it)so the problem stay
I do not want your drawing. I was hoping that you would try my suggestion yourself, and you may find that it works.
thank mr eldon the problem solved
sorry i didn,t understand your suggestion first
but any idea why the problem happened and solved in this way
AutoCAD is a very complex programme, and from time to time things go wrong. The problem of not being able to copy to clipboard and WBLOCK not working is a problem that has occured before and is a recognized bug. I have found that what I suggested works for me, and this forum is all about suggesting solutions to problems. These suggestions may work but are certainly worth trying to see whether the problem is solved. :D
