#1 |
Full Member
![]() ![]() Using: AutoCAD 2009 Join Date: Jun 2008
I have an assembly that calls for a 10' copper ground rod. Is there a way to show a "break line" in it so that the entire 10' ground rod length does not show up?
#2 |
Full Member
I was able to do this when I created a drawing from the assembly. Am I able to do this from the assembly level?
#3 |
Super Member
![]() ![]() ![]() ![]() Using: AutoCAD 2005 Join Date: Sep 2008
i dont know if there is or not, but you can create a split line on the surface of your ground rod and change the material on part of it to something else, like glass. You could also have two ground rods, one short and one 10' and just change them from visible to hidden. Hopefully someone will have the right answer for you.
Matt
SolidWorks09,SolidCam08,Unigraphics NX 5.0,Autocad 05/07/09/10, Inventor Pro 10/11/2009/2010, MasterCamX3, ProE Wildfire 4.0 |
| Thread Tools | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Line supression in "Hidden" view style | bacreman | AutoCAD 3D Modelling & Rendering | 5 | 20th Jul 2009 05:49 pm |
| open http URL through command line "acad.exe" | ujin415 | AutoCAD General | 2 | 4th May 2009 08:11 am |
| Line w/text ex: _____6" Water______6"Water____ | POaid | AutoCAD General | 33 | 19th Mar 2009 01:52 pm |
| "save" in the file "pull down menu" not working | kfarrar | Civil 3D & LDD | 6 | 7th Jan 2009 03:31 am |
| 2004---Command line version of cancel? (As opposed to "Esc") | ajs | AutoCAD Beginners' Area | 5 | 10th Mar 2008 03:08 pm |
