Scoobydoo Posted November 4, 2009 Share Posted November 4, 2009 I have an assembly that calls for a 10' copper ground rod. Is there a way to show a "break line" in it so that the entire 10' ground rod length does not show up? Quote Link to comment Share on other sites More sharing options...
Scoobydoo Posted November 4, 2009 Author Share Posted November 4, 2009 I was able to do this when I created a drawing from the assembly. Am I able to do this from the assembly level? Quote Link to comment Share on other sites More sharing options...
shift1313 Posted November 5, 2009 Share Posted November 5, 2009 i dont know if there is or not, but you can create a split line on the surface of your ground rod and change the material on part of it to something else, like glass. You could also have two ground rods, one short and one 10' and just change them from visible to hidden. Hopefully someone will have the right answer for you. Quote Link to comment Share on other sites More sharing options...
