Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   AutoCAD Forums > AutoCAD > AutoCAD General
Reply
Thread Tools
Old 7th Nov 2009, 01:16 am   #1
dragonpace
Junior Member
Using: AutoCAD 2010
Default user profile issues
I am using autocad 2010 and I am not able to save edits to my user profile and my profile will not remain the default profile when I start up new sessions? suggestions please
dragonpace is offline   Reply With Quote
Old 7th Nov 2009, 01:56 pm   #2
lpseifert
Forum Deity
Using: Civil 3D 2009
Use the profile switch /p in your startup icon on your desktop.
http://www.hyperpics.com/downloads/r...n%20Switch.pdf
lpseifert is offline   Reply With Quote
Old 8th Nov 2009, 07:02 pm   #3
Strix
Super Moderator
Strix's Avatar
Version: not applicable
Some establishments may have the system locked out so you can't save changes to the profile
Find your new best friend at Rain Rescue
Why is it a typical discussion devolves into a referendum on alcohol preference, yet a St. Patrick's Day thread turns in to a discussion on architectural styles? - MaxwellEdison at CADTutor
Strix is offline   Reply With Quote
Old 9th Nov 2009, 05:26 pm   #4
dragonpace
Junior Member
Using: AutoCAD 2010
I may not have explained my issue enough.
When I loaded 2010 there was no problem with saving setting to my profile and when I started up cad every morning my profile came up and off to work I went. But I loaded the 2010 update and now when I start every morning I get the 2010 default profile and and any change that I have made to my profile setting are missing.
I have gone to options and selected my profile and all of the previous days setting are gone. I corrected the profile and then saved it over the old one. Re-loaded the profile worked for the day with no problems. Get to work the next day and I have to start all over, the setting are all kaput. Thus having to start the process all over again.
Old 9th Nov 2009, 11:36 pm   #5
rkent
Super Member
rkent's Avatar
Using: Mechanical 2010
Does the location of your profiles look like this one
C:\Documents and Settings\username\Application Data\Autodesk\AutoCAD 2010\R18.0\enu\Support\Profiles
and
Does your Startup Icon properties look like this
"C:\Program Files\Autodesk\ACADM_2010\acad.exe" /p your profile name here /W <your workspace name here>"
Assuming XP OS.
AutoCAD 2010 Professional Certification
Abusing AutoCAD since 1989.
On a steep learning curve with Inventor 2010.
rkent is offline   Reply With Quote
Old 10th Nov 2009, 12:50 am   #6
dragonpace
Junior Member
Using: AutoCAD 2010
startup properties? (no clue how to get to that)
and no profile location is...
C:\Documents and Settings\username\Application Data\Autodesk\AutoCAD 2010\enu\Support\Profiles
Old 10th Nov 2009, 01:02 am   #7
dragonpace
Junior Member
Using: AutoCAD 2010
I find nothing with the path that you wrote for the start icon properties
Old 10th Nov 2009, 01:05 am   #8
rkent
Super Member
rkent's Avatar
Quote:
There should be a shortcut icon on your desktop. Hit the Windows key + M, everything will be minimized leaving you with just your desktop, locate the AutoCAD startup icon, right click, pick properties, add the /p your-profile-name in the target statement under the shortcut tab, pick OK to back out of that. Close Autocad if is up, now double click on the shortcut you just modified. Your profile will be used on startup.
Old 10th Nov 2009, 01:28 am   #9
dragonpace
Junior Member
Using: AutoCAD 2010
ok I got the icon switch thing figured out but cad will still not save the last profile settings. I saved over and even created a new profile but setting will not save.
Old 10th Nov 2009, 01:40 am   #10
dragonpace
Junior Member
Using: AutoCAD 2010
ok well for what ever the reason things are working again
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Country in User Profile Rob-GB Feedback 1 16th Jul 2009 08:53 am
New User Profile Fields CADTutor News, Announcements & FAQ 17 13th Jan 2009 01:02 am
User Profile question? NuttZ AutoCAD Drawing Management & Output 7 22nd May 2007 02:34 pm
CAD user profile setting loaction KBcad AutoCAD Drawing Management & Output 6 1st May 2007 09:05 pm
Why Donate?
RSS Feed for AutoCAD ForumsValid XHTML 1.0!Valid CSS!Creative Commons Licence
