Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   AutoCAD Forums > Other Autodesk Products > Autodesk Inventor
Reply
Thread Tools
Old 7th Nov 2009, 04:43 am   #1
matttiya88
Forum Newbie
Using: AutoCAD 2010
Default How do I draw car chassis using autodesk inventor?
Hye,
Somebody can teach me how to draw a car chassis using inventor.? i'd been assigned an assignment to draw a complete car using inventor.. somebody please help me.
p/s: any good information sources so that i can learn well.?
thanks..
matttiya88 is offline   Reply With Quote
Old 7th Nov 2009, 02:05 pm   #2
JD Mather
Super Member
JD Mather's Avatar
Using: Inventor 2009
How much experience do you have? That sounds like it might be too complex of a job for a beginner. Have you gone through the built-in tutorials? Are you familiar with the Frame Generator? How much training in surface modeling do you have?
You might follow the link in my signature to the Inventor Tutorials.
Autodesk Inventor Certified Expert
AU 2007 Altogether Smarter Inventor Challenge 1st Place
AU 2006 Altogether Smarter Inventor Challenge 2nd Place
http://home.pct.edu/~jmather/content..._Tutorials.htm
JD Mather is offline   Reply With Quote
Old 7th Nov 2009, 05:20 pm   #3
Lazer
Super Moderator
Lazer's Avatar
I agree with JD, do you have a picture of what you would like to model so we can get an idea of the level of detail you want?
USING AUTOCAD 2009 AND INVENTOR 2009.
If in doubt scale and don't ask!
Lazer is offline   Reply With Quote
Old 8th Nov 2009, 04:03 am   #4
matttiya88
Forum Newbie
Using: AutoCAD 2010
Thanks JD,
Ya, I'm quite a beginner but I have some knowledge on Frame Generator but poor at surface modeling. I would like if can go throu some exercise or tutorial on how to model a simple complete car with its chassis and body. Is there any step by step tutorial for me.?
Old 8th Nov 2009, 04:14 am   #5
matttiya88
Forum Newbie
Using: AutoCAD 2010
Quote:
Hi Lazer,
Actually I'd been assigned to model a racing car.Maybe this picture can help me.
Any suggestion on how I can draw this car using inventor.? I willing to learn eventhou its kinda hard for me as beginner.
Thanks for any good advices.
Old 8th Nov 2009, 06:20 am   #6
shift1313
Super Member
shift1313's Avatar
Using: AutoCAD 2005
what class assigned this? This is not a simple task. How detailed does your chassis need to be? Are you trying to replicate something you have or draw a car of your design? I have not found a tutorial for what you are asking in inventor. There are several online for using 3d studio, rhino etc etc.
Matt
SolidWorks09,SolidCam08,Unigraphics NX 5.0,Autocad 05/07/09/10, Inventor Pro 10/11/2009/2010, MasterCamX3, ProE Wildfire 4.0
shift1313 is offline   Reply With Quote
Old 8th Nov 2009, 06:36 am   #7
Tankman
Super Member
Tankman's Avatar
Using: AutoCAD 2005
Wow! Not beginner's work for sure!
Keep your nose in the books or work tutorials at Mr. Mather's website.
Good luck!
Tankman
"When the well is dry, we know the worth of water." Ben Franklin ~ 1746
Tankman is offline   Reply With Quote
Old 12th Nov 2009, 12:04 am   #8
Lazer
Super Moderator
Lazer's Avatar
I agree with the above comments, this model is quite complex regarding the body shape and you sould need to be on an advanced level of using surfaces in Inventor, it can be done using inventor but would take a long time to get right.
Old 12th Nov 2009, 02:26 pm   #9
shift1313
Super Member
shift1313's Avatar
Using: AutoCAD 2005
well these are in different software packages but maybe seeing the curves can help you visualize things.
http://www.carbodydesign.com/tutoria...-tutorials.php
Be away that these surface modeling packages can create the low polygon surfaces and smooth them later. If you are a student you have access to Alias Auto from autodesk but I will warn you its not a simple program to work with. You have a lot of control over your sufaces though.
Matt
Old 12th Nov 2009, 09:42 pm   #10
Lazer
Super Moderator
Lazer's Avatar
Quote:
I love the work Alias can do but always did wonder if it was easy to use. Thanks for the heads up so to say
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Will AutoCAD Inventor Professional 2010 open on Autodesk Inventor Professional 2008 NLClause Autodesk Inventor 25 30th Jun 2009 10:05 am
Autodesk Inventor 2008 Pro/inventor 10 graann Autodesk Inventor 1 21st Jul 2008 12:22 am
Chassis Rails future proof Autodesk Inventor 11 16th Oct 2007 10:31 pm
Autodesk Labs New Addition: Feature Recognition for Autodesk Inventor 11 Between the Lines AutoCAD RSS Feeds 0 19th Sep 2006 02:28 am
Can you compare Autodesk Inventor with Autodesk AutoCAD ? BAD_WOLF Autodesk Inventor 2 4th Jun 2006 01:01 pm
Why Donate?
RSS Feed for AutoCAD ForumsValid XHTML 1.0!Valid CSS!Creative Commons Licence
