guys
I'm loving the new look and feel of 2010 but can the Tabs and Panels be cumtomised? :oops:
i.e adding other standard tool buttons to the panels?
and making your own cutome panel?
Yes they can be customized. Save a backup copy of the acad.cui in case you make a mistake.
In AC 2009 I created a custom Ribbon with my own tabs and panels. And that was when customizing the Ribbon wasn't all that easy. 2010 has introduced some improvements.
  • 3 weeks later...
Autocad help says you can import a .mnu file as a customization. My autocad 2010 says no. I followed instructions in help file. Does not work. Why?
The AutoCAD 2010 Customization Guide, under the chapter entitled Transfer and Migrate Customization, says "the CUI Editor can be used to transfer data in a CUI, MNU, or MNS file to a CUIx file without modifying the original customization or menu file."
Did you use the Migrate Custom Settings dialog box to migrate your customizations from your previous AutoCAD release?
