sparkyuk Posted February 23, 2015 Share Posted February 23, 2015 Hello All her in doors has been watching a improve your house type program on UK TV and saw them building a dormer in the roof, my question is how much would a set of drawings including any work by structural engineer cost please, the dormer would be about 5.5 mts across and 5mts from ridge line and only one room with stairs and looking like below if it helps Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 24, 2015 Share Posted February 24, 2015 More than a couple of pints look up the phone book or local paper for a construction company or drafting service and they will be able to give you an idea, where I am "The extension factory" by the time you hang up the phone there will be a knock on the dooor. Quote Link to comment Share on other sites More sharing options...
sparkyuk Posted February 24, 2015 Author Share Posted February 24, 2015 Don't think The extension factory will be knocking on my door that quick long flight from aus to the UK lol Yes I have already made local enquiries and the drawings are not cheap, I was after what everyone else charges in the UK so see if what they want is about right. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 24, 2015 Share Posted February 24, 2015 (edited) Depends on what your definition of "cheap" is. I can't imagine plans for a simple dormer like that to be all that costly but you throw in a set of stairs and that will jack the price right up. Edited February 24, 2015 by ReMark Quote Link to comment Share on other sites More sharing options...
eldon Posted February 24, 2015 Share Posted February 24, 2015 I presume that you have done a Google search and come up with something like this Quote Link to comment Share on other sites More sharing options...
sparkyuk Posted February 24, 2015 Author Share Posted February 24, 2015 I presume that you have done a Google search and come up with something like this Hi Eldon I have already had appox costs of between £15,000 & £20,000 for the extension but until they have plans they are unable to firm up costs, I was only after the cost of the drawings not the extension at this time, I assumed someone on here would have been doing these drawings all the time and would be able to tell me what they charge on average ? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 24, 2015 Share Posted February 24, 2015 Why not draw the plans up yourself? Quote Link to comment Share on other sites More sharing options...
sparkyuk Posted February 24, 2015 Author Share Posted February 24, 2015 Why not draw the plans up yourself? I'm an electrician not an architect and wouldnt have a clue what size timber / steel is required for the job, so that's why I am asking for a price for someone to do them for me. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 24, 2015 Share Posted February 24, 2015 What specifically does your local building department require in the way of drawings for something like what you propose? Quote Link to comment Share on other sites More sharing options...
danellis Posted February 24, 2015 Share Posted February 24, 2015 What specifically does your local building department require in the way of drawings for something like what you propose? According to the Planning Portal extensions guide here: http://www.planningportal.gov.uk/uploads/miniguides/lofts/Lofts.pdf at that size (27.5m2) Planning Permission would be required, and it would be irrespective of size if the dormer were facing the street). The fee for an householder Planning Application is £172. You would also require Building Regulations approval, which a quick google suggests is £400-£500. You need to decide whether you'd want to manage these applications yourself (only paying for the drawings) or whether the person you employ should manage them for you. I'm sure this would affect the fees they'd charge! The drawings required for the Planning Application would be: Location plan showing your home in the context of it's neighbourhood. Block plan at a larger scale, showing just your home. Before and after floor plans. Before and after elevations. I'd have to check for Building Regs but they'd essentially need the drawings necessary to build the extension itself, more detailed floor plans, sections, along with engineering calculations to prove your existing structure would be up to the job of holding the extra weight up. HTH dJE Quote Link to comment Share on other sites More sharing options...
sparkyuk Posted February 24, 2015 Author Share Posted February 24, 2015 (edited) Our building control department tell me that they do not need to see any drawings for this type of work as planning is not required if it is under 40 cubic metres for terraced houses, but they do check the work as its being constructed to make sure it complies with the building regulations, they tell me I just need to employ a building contractor who carries out this sort of work all the time as they will know the correct way of construction a dormer and will sort out what steel need to be added etc. I wanted full drawings for my peace of mind so that I can see what and how it is going to be carried out and that I will avoid any trouble down the line, and that any quote I get is for the full job and non of " Oh that wasn't allowed for etc etc costs added" Sorry Danellis I didn't answer your post was on the phone while typing above. Yes you right 5.5 x 5 x 2.4 = 66 cubic metres i believe my maths is correct so I would have to lower the size of it to about 4x4x2.4 to not need planning correct? And thank you for the detail info you have supplied Edited February 24, 2015 by sparkyuk didnt see danellis post Quote Link to comment Share on other sites More sharing options...
danellis Posted February 25, 2015 Share Posted February 25, 2015 Roughly speaking, yes, your maths is correct. Please do remember that the dormer would have to be rear-facing to count as PD = if it's front-facing you'd still need planning permission. No problem at all re:detailed info. dJE Quote Link to comment Share on other sites More sharing options...
sparkyuk Posted February 25, 2015 Author Share Posted February 25, 2015 Yes it is rear facing Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 25, 2015 Share Posted February 25, 2015 Our building control department tell me that they do not need to see any drawings for this type of work as planning is not required if it is under 40 cubic metres for terraced houses, but they do check the work as its being constructed to make sure it complies with the building regulations, they tell me I just need to employ a building contractor who carries out this sort of work all the time as they will know the correct way of construction a dormer and will sort out what steel need to be added etc. I wanted full drawings for my peace of mind so that I can see what and how it is going to be carried out and that I will avoid any trouble down the line, and that any quote I get is for the full job and non of " Oh that wasn't allowed for etc etc costs added" Sorry Danellis I didn't answer your post was on the phone while typing above. Yes you right 5.5 x 5 x 2.4 = 66 cubic metres i believe my maths is correct so I would have to lower the size of it to about 4x4x2.4 to not need planning correct? And thank you for the detail info you have supplied I am sure you know this but I will say it anyway. Planning means that you need a licensed design/build contractor, as we call them over here, not just a bunch of blokes with a hammer, saw, and work truck. The remodel/refurbish industry on this side of the ocean is so full of criminals, we have to go to great lengths to vet such contractors. Watch your step. The U.S. has no monopoly on shysters, hucksters, and downright sociopathic people in this industry. Quote Link to comment Share on other sites More sharing options...
steven-g Posted February 25, 2015 Share Posted February 25, 2015 The U.S. has no monopoly on shysters, hucksters, and downright sociopathic people in this industry. Yeah but over here we call them "Cowboys" Quote Link to comment Share on other sites More sharing options...
sparkyuk Posted February 25, 2015 Author Share Posted February 25, 2015 Yeah but over here we call them "Cowboys" Second that Steven lol Quote Link to comment Share on other sites More sharing options...
Glen1980 Posted February 25, 2015 Share Posted February 25, 2015 I've just asked the guy at work who does lots of private work and he says a grand all in for planning, regs and structural calcs, drawings only all submissions are paid for by his client. Quote Link to comment Share on other sites More sharing options...
sparkyuk Posted February 25, 2015 Author Share Posted February 25, 2015 Thanks Glen that is about what I Have been told by some one else and I was thinking it sounder a lot but it isn't, and I see it includes the structural calcs as well. Looks like if her in doors wants the full size 5.5mt x 5 mt dormer we will have to get planning so just a case of finding someone local to do the drawings for me. Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 25, 2015 Share Posted February 25, 2015 Yeah but over here we call them "Cowboys" That's why we don't have cowboys here any more. Quote Link to comment Share on other sites More sharing options...
Glen1980 Posted February 26, 2015 Share Posted February 26, 2015 or whether the person you employ should manage them for you. I'm sure this would affect the fees they'd charge! It probably would affect the price quite a lot as having your name on official documents may make the tax man come calling Quote Link to comment Share on other sites More sharing options...
