pttr Posted March 27 Share Posted March 27 (edited) Hi! Trying to modify this code to change Fields to Text inside a block with multiple instances. https://forums.augi.com/showthread.php?72534-Convert-Field-to-Text-within-Block-Globally I can get it to work for one, but some of the others change the content of the text to 'Model'. I'm guessing I missed some iteration check, but I'm not sure (defun c:FTT (/ ss n bn an ad s) (setq ss (ssget "_X" '((0 . "INSERT") (2 . "myblock")))) ; Get selection set of blocks named Myblock (if ss (progn (setq n 0) (while (< n (sslength ss)) (setq bn (ssname ss n)) (setq an (entnext bn)) (while (and an (setq ad (entget an)) (= "ATTRIB" (cdr (assoc 0 ad))) ) (setq s (cdr (assoc 1 ad))) (if (not (equal s nil)) ; Check if s is not nil (progn (setq ad (subst (vl-list* 1 "") (assoc 1 ad) ad)) (entmod ad) (setq ad (subst (vl-list* 1 s) (assoc 1 ad) ad)) (entmod ad)) (princ "\nAttribute value is nil. Skipping substitution.") ) (entupd an) (setq an (entnext an)) ) ;_ end while (setq n (1+ n)) ) ;_ end while (princ "\nField links removed from blocks named Myblock.") ) (princ "\nNo blocks named Myblock found.") ) (setq ss nil) (gc) (princ) ) Edited March 28 by pttr Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 28 Share Posted March 28 Read it again and fix up (setq ss (ssget "_X" '((0 . "INSERT") (2 . "myblock")))) ; Get selection set of blocks named "Regionservic" For the get value of field. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/extract-field-expression/td-p/3364401https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/extract-field-expression/td-p/3364401 Quote Link to comment Share on other sites More sharing options...
pttr Posted March 28 Author Share Posted March 28 Hmm okay, I found something that might be a problem that i can´t get my head around I think the problem is modifying the block in different layouts. rewrote from scratch and I´m not sure how i iterate different layouts to make the changes. To clarify this code works, but only in one layout (defun c:FTT (/ ss n bn an ad s ) (setq ss (ssget "_X" '((0 . "INSERT")(2 . "Myblock")))) (setq n 0) ;Initialize counter ;; Step through selection set one entity at a time (while (< n (sslength ss)) (setq bn (ssname ss n)) ;Get the nth entity in the selection set (setq an (entnext bn)) ;Get the next enity after bn ;; Step through each next entity until it is not an attribute (while (and an ;Check if entity is found (setq ad (entget an)) ;Get data (= "ATTRIB" (cdr (assoc 0 ad))) ;Check if attribute ) ;_ end of and (setq s (cdr (assoc 1 ad))) ;Get text value (setq ad (subst (vl-list* 1 "") (assoc 1 ad) ad)) ;Clear the attribute's value (entmod ad) ;Modify the entity (setq ad (subst (vl-list* 1 s) (assoc 1 ad) ad)) ;Set the attribute's value back to only the text (entmod ad) ;Modify the entity (entupd an) ;Update screen to show change (setq an (entnext an)) ;Get next entity ) ;_ end of while (setq n (1+ n)) ;Increment counter ) ;_ end of while (setq ss nil) ;Clear selection set (gc) ;Clear unused memory (princ) ) ;_ end of defun Found this, but didn´t manage to implement Quote Link to comment Share on other sites More sharing options...
pttr Posted March 28 Author Share Posted March 28 This is how far i got on my own but I still get "Model" istead of intended text sometimes (defun c:FTT (/ ss n bn an ad s) (setq layoutOld (getvar "CTAB")) (foreach layoutCrt (layoutlist) ;do som here: (setq ss (ssget "_X" (list '(2 . "myblock") (cons 410 layoutCrt)))) (setq n 0) ;Initialize counter (setq bn (ssname ss n)) ;Get the nth entity in the selection set (setq an (entnext bn)) ;Get the next enity after bn (while (and an ;Check if entity is found (setq ad (entget an)) ;Get data (= "ATTRIB" (cdr (assoc 0 ad))) ;Check if attribute ) ;_ end of and (setq s (cdr (assoc 1 ad))) ;Get text value ;(princ"---INW---") (princ s) (setq ad (subst (vl-list* 1 "") (assoc 1 ad) ad)) ;Clear the attribute's value (entmod ad) ;Modify the entity (setq ad (subst (vl-list* 1 s) (assoc 1 ad) ad)) ;Set the attribute's value back to only the text (entmod ad) ;Modify the entity (entupd an) ;Update screen to show change (setq an (entnext an)) ;Get next entity ) ;_ end of while );_end LayoutCrt (setvar "CTAB" layoutOld) ) Quote Link to comment Share on other sites More sharing options...
Danielm103 Posted March 28 Share Posted March 28 Note: other APIs (ARX or .NET), have a function convertFieldToText https://help.autodesk.com/view/OARX/2024/ENU/?guid=OARX-RefGuide-AcDbText__convertFieldToText I posted a sample with python here https://www.cadtutor.net/forum/topic/82756-convert-fields-in-blocks-to-test-with-python/ Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 28 Share Posted March 28 (edited) Are you sure this is working (setq ss (ssget "_X" (list '(2 . "myblock") (cons 410 layoutCrt)))) what is your block name I doubt its "myblock" I usually wrap a ssget in an IF to make sure it exists. (if (= ss nil) (alert "selection set has not been made skipping program") (progn ............. ) ) Edited March 28 by BIGAL Quote Link to comment Share on other sites More sharing options...
pttr Posted April 2 Author Share Posted April 2 (edited) On 3/29/2024 at 12:28 AM, BIGAL said: Are you sure this is working (setq ss (ssget "_X" (list '(2 . "myblock") (cons 410 layoutCrt)))) what is your block name I doubt its "myblock" I usually wrap a ssget in an IF to make sure it exists. (if (= ss nil) (alert "selection set has not been made skipping program") (progn ............. ) ) Yeah every file i will use this Lisp on has the block and "myblock" is an example, but it does (sort of) work! Nice, the if statement might add a layer of security but i dubt it will fix the issue. The file has about 15 layouts with 1 block in each layout Edited April 2 by pttr Quote Link to comment Share on other sites More sharing options...
pttr Posted April 2 Author Share Posted April 2 Ah it´s solved! Problem is the layouts have to be "Read/Regenerated" before I can make changes to them. Used this https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/activate-each-layout-one-by-one-in-all-open-drawing/m-p/8050459/highlight/true#M369795 Quote Link to comment Share on other sites More sharing options...
