Build Metric joined the community - Today
qqhsx joined the community
Searching multiple dwg files for text
qqhsx replied to clowe-thcp's topic in AutoCAD Drawing Management & Output
https://github.com/DwgSearch/DwgSearch It's free and fully meets your needs. -
irpansiswadi joined the community
Dadgad replied to indiancad's topic in AutoCAD 2D Drafting, Object Properties & Interface
Those are the ones that always bug me too. I frequently use the DIMSPACE command to force some of those unruly floaters to reorient closer to the dimline. Really annoying wasting time grip dragging dims around to get them exactly as desired! Happy Thanksgiving Day everybody. -
PDF to editable CAD: when is redrawing quicker than importing?
SLW210 replied to Kavivendhan's topic in AutoCAD 2D Drafting, Object Properties & Interface
Vector PDFs should convert very accurately, scanned it just depends on how distorted and how detailed. The Raster Tools in AutoCAD have a steep learning curve, but can really make recreating a descent scanned drawing usable and much faster than a redraw on more than just simple objects. -
As I clean up a drawing I like to use DIMEDIT, mostly the Home option to clean them up. I am thinking of trying to figure out a foolproof method to automate that with my other clean-up tools, though some dimensions don't act the way I want, particularly dimensions for small measurements that are forced outside the extension lines or if they have a leader line. Manual is probably fast enough for now though. -
Nguyen Huu Hanh Lam joined the community
Handling Flexible Components Without Overcomplicating CAD Assemblies
In assemblies involving cables, hoses, springs, flexible connectors, or moving linkages, representing every component in its actual operating position can become challenging. A component may fit perfectly in one configuration but interfere with surrounding parts when the assembly moves or changes position. Fully constraining everything can also make the model difficult to adjust. How do you handle flexible or position-dependent components in your assemblies? Do you model their actual shape, use simplified representations, or leave certain components out of detailed assembly constraints? -
When Imported CAD Geometry Contains Tiny Edges and Unwanted Sliver Faces
That makes sense, especially when the original geometry is available and the corrections are straightforward. -
Hatch Name to Multileader Lisp?
BIGAL replied to eyeofnewt555's topic in AutoLISP, Visual LISP & DCL
Working on it had some interstate visitors, maybe later today testing code for attribute in block. Thisoption 1 a simple just put layer name into the mleader. ; https://www.cadtutor.net/forum/topic/60494-hatch-name-to-multileader-lisp/ ; Label a hatch layer using a leader and block ; By AlanH Nov 2026 (defun AHMakpl ( / pt) (setq oldsnap (getvar 'osmode)) (setvar 'osmode 512) (setq pt (getpoint "\nStarting point of leader ")) (command "_pline" pt) (while (= (getvar "cmdactive") 1 ) (command (getpoint (getvar 'lastpoint))) ) (setvar 'osmode oldsnap) (princ) ) (defun AHMl1 (lst lay1 / x) (setvar 'orthomode 0) (setq x -1) (command "_Mleader") (while (= (getvar "cmdactive") 1 ) (repeat (length lst) (command (nth (setq x (1+ x)) lst)) ) (command "" lay1) ) ) (defun AHMl2 (lst lay2 / x) (setvar 'orthomode 0) (setq x -1) (command "_Mleader") (while (= (getvar "cmdactive") 1 ) (repeat (length lst) (command (nth (setq x (1+ x)) lst)) ) (command "" lay2) ) ) (defun SetMLStyle ( sty / ) (if (dictsearch (namedobjdict) "ACAD_MLEADERSTYLE" sty) (progn (setvar "CMLEADERSTYLE" sty) (princ (strcat "\nCurrent MLeader style set to: " sty)) ) (progn (Alert (strcat "\nMLeader style " sty " not found. \nWill now exit"))(exit) ) ) (princ) ) (defun c:hatlab1 ( / pt1 ss lay co-ord) (AHmakpl) (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (entlast))))) (command "erase" (entlast) "") (setq pt1 (car co-ord)) (setq ss (ssget pt1 (list (cons 0 "HATCH")))) (setq lay (cdr (assoc 8 (entget (ssname ss 0))))) (command "erase" (entlast) "") (SetMLStyle "MLEADER STYLE (HARDSCAPE) LEFT SIDE") (ahml1 co-ord lay) (princ) ) (defun c:hatlab2 ( / pt1 ss lay co-ord obj objid) (AHmakpl) (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (entlast))))) (command "erase" (entlast) "") (setq pt1 (car co-ord)) (setq ss (ssget pt1 (list (cons 0 "HATCH")))) (setq obj (vlax-ename->vla-object (ssname ss 0))) (setq objID (rtos (vla-get-objectid obj) 2 0)) (setq lay (strcat "%<\\AcObjProp Object(%<\\_ObjId " objid ">%).Layer>%")) (SetMLStyle "MLEADER STYLE (HARDSCAPE) LEFT SIDE") (ahml2 co-ord lay) (princ) ) Option 2 the field is not updating and not sure why not, anybody have an idea. Checked like Fieldval its 31.- 21 replies
- annotation
- hatch name
(and 2 more)
Tagged with:
How Much Manufacturing Information Should Be Included in a Drawing?
Agreed. Experience with the manufacturing process definitely helps decide what information is necessary and what can be left out. But when a drawing is sent to a new supplier who is unfamiliar with the design, how do you ensure that details left to interpretation don't result in different manufacturing outcomes? - Last week
ai3dstudio joined the community
El_Che_12345678 started following 5 CAD Commands That Can Save You More Time Than You Think
ktoant8 joined the community
ROLANDO JR replied to eyeofnewt555's topic in AutoLISP, Visual LISP & DCL
Thanks Bigal in advance! Hope you can help me on this.- 21 replies
- annotation
- hatch name
(and 2 more)
Tagged with:
CAD Models That Are Easy to Design but Difficult to Machine
This just mainly takes experience in a machine shop and familiarity with the machining capabilities of the equipment to be used and the availability of tooling. These things should be hammered out in the designing phase and sometimes it needs to be determined if any special tooling is needed or worth the extra investment. -
Depends on what it is, but normally I would try some simple editing with solidedit tools and adding or subtracting, etc.. If possible I would send it back to the original person to fix so they can learn. -
Basically, that's something that takes experience and communication with those manufacturing the products. It helps to know the process something will be going through to be manufactured. If something is already sized like tubing, flatbar, channel, et.al. the material list would work unless machining or post process of some sort was needed. Sometimes there is plenty of space for a little extra dimensions, but still you don't want to complicate the drawing. You can also use notes i.e. all holes are x unless noted otherwise, typical, etc.. -
Tracking Design Changes When Multiple Engineers Modify the Same DWG
Devashish Sharma replied to indiancad's topic in CAD Management
When several engineers are working on the same DWG, keeping track of changes can get tricky. I think it's best to maintain one central folder for approved drawings and use clear revision numbers so everyone knows which file is current. AutoCAD's DWG Compare feature is also useful for checking what has been added, removed, or modified between two versions. Revision clouds and notes can help highlight specific changes. It's also worth checking Xrefs and related drawings before issuing the updated file to make sure nothing has been missed. -
Devashish Sharma joined the community
jeanhnsns01 joined the community
lightvale joined the community
Kavivendhan posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi everyone, I'm Kavi. I'm looking into how people turn drawings into editable CAD and would like to hear how you handle it in practice. When you receive a PDF drawing without the original DWG, do you usually import it and clean up the geometry, or redraw it? I'm interested in both CAD-exported PDFs and scanned drawings. What makes you decide it's quicker to start again? A recent example would be helpful. I've also put together a short survey on this, if you'd rather share your experience there: https://forms.gle/QoFESgVmF7Hv3XXP9 It takes about 2 minutes. Replies here are just as welcome. -
Kavivendhan joined the community
Nexus Power Turns Agricultural Waste Into a Sustainable Battery Alternative With AutoCAD
The traditional battery industry has long depended on what can be extracted from the Earth, whether it’s lithium nickel, cobalt, or graphite. Nexus Power is upending that with an innovative approach to source battery materials above ground instead. Across India, fields of rice, wheat, corn, and other crops leave behind enormous amounts of stalks, leaves, and other organic materials after harvest. In many regions, fields are burned to clear the land for the next planting season, worsening the air quality in a country that already grapples with pollution. Nexus Power sees something entirely different in those agricultural remains: the raw ingredients for a sustainable battery alternative. Founded by twin sisters Nishita and Nikita Baliarsingh, Nexus Power is developing energy-storage technology that derives key materials from agricultural waste. It’s a win-win for the circular economy. Less air pollution from the fires and a sustainable battery alternative that is also completely biodegradable. With AutoCAD and Autodesk Fusion, they’re making this vision a reality. From an idea to a working battery Autodesk technology has been pivotal in helping Nexus Power move from concept to physical battery. The team uses AutoCAD and Fusion to design the battery components, evaluate designs through simulation, and rapidly turn digital models into working prototypes. According to Nikita Baliarsingh, the seamless interoperability between the two allows the team to pass updates smoothly between environments, reducing translation errors and keeping hardware and electrical teams in sync. “Using AutoCAD alongside Fusion gives us a seamless 2D-to-3D design pipeline,” Nikita says. “AutoCAD handles the precise 2D schematic design, electrical routing, and mechanical layouts, while Fusion allows us to take those layouts into 3D space for spatial packaging, thermal analysis, and structural CAD modeling.” Early protoype of Nexus Power battery cell. “Developing advanced battery technologies requires precision at every level, AutoCAD provides the foundational drafting environment needed to translate complex electro-chemical and structural parameters into standardized, production-ready engineering blueprints efficiently.” Nikita Baliarsingh, Co-founder, Nexus Power Designing with precision from the start During the design phase, AutoCAD was key for efficiency and accuracy. Automated wire numbering and component tagging streamlined complex wiring diagrams and virtually eliminated labelling errors. Smart schematic libraries sped up component placement and ensured consistency across battery module schematics. The team could also flag open circuits and duplicate tags early, saving significant debugging time prior to prototyping. Dynamic blocks allowed the team to quickly adapt and scale components across different battery pack architectures. With automatic bill of materials (BOM) generation in AutoCAD, they were able to instantly create accurate component lists straight from schematics, drastically cutting down manual documentation time. The Electrical toolset was also used for the electrical architecture, wiring harnesses, and battery management system (BMS) integration. “The primary benefit of the Electrical toolset was the automated schematic auditing and real-time error checking, which ensured high accuracy across complex circuitry without requiring manual double-checks,” Nikita says. Nexus Power battery pack. Looking ahead with AutoCAD For Nexus Power, AutoCAD is the undisputed choice as they continue to refine and expand their batteries. “AutoCAD is the industry standard for a reason,” Nikita says. “It offers unmatched precision, high adaptability, and seamless standardization across engineering teams. Its built-in automation features handle tedious tasks so designers can focus on core product innovation.” The post Nexus Power Turns Agricultural Waste Into a Sustainable Battery Alternative With AutoCAD appeared first on AutoCAD Blog. View the full article -
There is always a balance between providing enough information for manufacturing and making a drawing unnecessarily crowded. Adding every dimension, tolerance, surface finish, note, and detail may make a drawing difficult to read, while leaving too much information to interpretation can lead to manufacturing errors. How do you decide what information belongs on the main drawing, what should go into detail views, and what can be handled through general notes or standard specifications? Has your approach changed with experience, particularly when drawings are used by different manufacturing teams or suppliers? -
When importing geometry from another CAD system, I have occasionally seen models contain tiny edges, sliver faces, and irregular surfaces that are barely noticeable visually but cause problems during subsequent operations. These imperfections can affect face selection, filleting, shelling, Boolean operations, and downstream manufacturing workflows. How do you normally deal with this type of geometry? Do you repair the imported model, simplify the problematic areas, or rebuild the affected features from scratch? -
Steven P replied to indiancad's topic in AutoCAD 2D Drafting, Object Properties & Interface
Am sure that is new from when I was recording macros - might be time to revisit action recorder then -
In simple terms two ways to do it a field in the block text or just read the layer and write that into the attribute. Using the field option has the advantage of if you change the hatch layer the attribute updates. the disadvantage is that you can not save the ID of the object in a Block it has to be updated each time you say make the Mleader. Yes can be done. Maybe later today will do something, limited time at moment.- 21 replies
- 1
- annotation
- hatch name
(and 2 more)
Tagged with:
@Dadgad "30 or 40 drawings open at the same time" here is a freebie for you. It will display the dwg names for you pick which one to Goto. Multi radio buttons.lspListbox-AH.lsp Gotodwg.lsp -
ROLANDO JR started following Hatch Name to Multileader Lisp?
Hi, Could anyone help me create fix the Attached Mleader. 1. Add Field to read the Hatch by Layer name. 2.Create a LISP/Routine Thank you in advance. Mleader Tag By Hatch Layer Name.dwg- 21 replies
- annotation
- hatch name
(and 2 more)
Tagged with:
Actually you can edit the action macros, although I typically just rerecord them too, if I find I have an issue. In order to access the editing window click on the circled icon in the second screenshot. For me, the best ones do not require additional input while they are running. Typically the macro might perform up to about a dozen different actions, ending with Zoom All, Purge and SAVE. I usually might have 30 or 40 drawings open at the same time, than forward tab to the next drawing and run the same one again...5 or 6 seconds later, when it has completed Tab forward again, and just roll through a fair sized batch quite quickly. -
I have moved your thread to the Catch All Forum. How does this compare to LibreCAD?
Action Recorder lead me to LISPs, I was annoyed with having to re-record each time I didn't quit get it right and couldn't edit the recording. Good tool though -
Preventing Geometry Problems Before Sending CAD Profiles for CNC Cutting
indiancad posted a topic in AutoCAD Drawing Management & Output
Before sending 2D profiles for laser, plasma, or waterjet cutting, drawings sometimes contain small gaps, overlapping entities, duplicate lines, open contours, or geometry that appears closed but cannot be recognized as a valid profile. These problems may not be obvious during drafting, but they can interrupt the CAM workflow or cause unexpected toolpaths. What checks do you normally perform before sending CAD geometry for CNC cutting? Do you use automated geometry validation, cleanup tools, or manually inspect each contour before exporting DXF?
