you can make the routine show the number of selected texts and the number of attributes, please
How to Extend Lines to shape 2D Polyline
SLW210 replied to Mountain_XD's topic in AutoLISP, Visual LISP & DCL
I tried that everyway possible and no luck with AutoCAD 2026, if I get time I'll look through my settings again. Might be a quirk in my AutoCAD 2026. It does seem it used to work as you say. -
SLW210 replied to HypnoS's topic in AutoLISP, Visual LISP & DCL
I get Command: CPY-BLK-2-POLY Select objects: ; error: bad argument type: lselsetp nil- 10 replies
- autolisp
- block position
(and 3 more)
Tagged with:
Here is my effort, worked on your drawing for me. ;;; Copy blocks to a polyline/line path in ascending order left to right based on ATTRIBUTE TAG value. | ;;; | ;;; https://www.cadtutor.net/forum/topic/98615-copy-blocks-to-curve-according-to-another-curve/#findComment-675378 | ;;; | ;;; By SLW210 (a.k.a. Steve Wilson) | ;;; | ;;;****************************************************************************************************************| ;| Lines/Polylines need be drawn Left-Right or reversed, could be coded to check direction and reverse them. I'm not motivated to do that, but feel free to alter the code. I did test on angled Polylines/Lines as well as vertical and it works, but might need adjustments. I adjusted a code I already had to handle this specific request for which it works, I doubt if I'll do anymore modifications. |; ;;;***************************************************************************************************************| ;;; This code asks to select the block and type in the tag name from options given (case sensitive). | ;;; | ;;;***************************************************************************************************************| (defun c:BlksSrt2PL (/ blkLst spacing pathEnt pathObj blkCopy len i param pt getAtVal parsFract attrVal blk startPt endPt dx dy visStart dist tangent rotAngle pathDist objType blkSelEnt blkSelObj tagList tagNames selTag ) (vl-load-com) ;; Function to get attribute value by tag name (defun getAtVal (blk tag / atts val) (setq atts (vlax-invoke blk 'GetAttributes)) (setq val "") (foreach att atts (if (= (strcase (vla-get-TagString att)) (strcase tag)) (setq val (vla-get-TextString att)) ) ) val ) ;; Function to convert fractional strings (like "1/2") to numbers (defun parsFract (s / pos num1 num2) (cond ((setq pos (vl-string-search "/" s)) (setq num1 (read (substr s 1 pos))) (setq num2 (read (substr s (+ pos 2)))) (if (and num1 num2 (/= num2 0)) (/ (float num1) num2) 0.0 ) ) ((distof s)) (T 0.0) ) ) ;; Select a block to determine attribute tag name (prompt "\nSelect a block to determine the tag name:") (setq blkSelEnt (car (entsel "\nSelect a block with attributes: "))) (if (not blkSelEnt) (progn (prompt "\nNo block selected. Exiting.") (exit) ) ) (setq blkSelObj (vlax-ename->vla-object blkSelEnt)) (if (not (vla-get-HasAttributes blkSelObj)) (progn (prompt "\nSelected block has no attributes. Exiting.") (exit) ) ) ;; Get all attribute tags from selected block (setq tagList '()) (foreach att (vlax-invoke blkSelObj 'GetAttributes) (setq tagList (cons (vla-get-TagString att) tagList)) ) (setq tagNames (apply 'strcat (mapcar '(lambda (x) (strcat "\n - " x)) tagList) ) ) (prompt (strcat "\nAvailable tags in selected block:" tagNames) ) (initget 1) (setq selTag (getstring "\nEnter the tag to use: ")) ;; --- Collect all blocks with that attribute tag --- (setq blkLst '()) (vlax-for ent (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-Acad-Object)) ) (if (and (= (vla-get-ObjectName ent) "AcDbBlockReference") (vla-get-HasAttributes ent) ) (progn (setq attrVal (getAtVal ent selTag)) (if (and attrVal (/= attrVal "")) (setq blkLst (cons (list (parsFract attrVal) ent) blkLst)) ) ) ) ) (if (= (length blkLst) 0) (progn (prompt "\nNo matching blocks found.") (exit) ) ) ;; Select path: polyline or line (prompt "\nSelect path (polyline or line): ") (setq pathEnt (car (entsel "\nSelect path (polyline or line): "))) (if (not pathEnt) (progn (prompt "\nNo object selected. Exiting.") (exit) ) ) (setq pathObj (vlax-ename->vla-object pathEnt)) (setq objType (vla-get-ObjectName pathObj)) (if (or (equal objType "AcDbPolyline") (equal objType "AcDbLine") ) (progn (setq startPt (vlax-curve-getStartPoint pathObj)) (setq endPt (vlax-curve-getEndPoint pathObj)) ) (progn (prompt (strcat "\nSelected object is not a polyline or line: " objType ". Exiting." ) ) (exit) ) ) ;; Determine start point (setq dx (- (car endPt) (car startPt))) (setq dy (- (cadr endPt) (cadr startPt))) (if (> (abs dy) (abs dx)) ;; Mostly vertical (setq visStart (if (> (cadr startPt) (cadr endPt)) startPt endPt ) ) ;; Mostly horizontal or diagonal (setq visStart (if (< (car startPt) (car endPt)) startPt endPt ) ) ) ;; Sort blocks by numeric tag value (setq blkLst (vl-sort blkLst (function (lambda (a b) (> (car a) (car b)))) ) ) (if (not (equal startPt visStart 1e-6)) (setq blkLst (reverse blkLst)) ) ;; Ask for spacing (initget 7) (setq spacing (getdist "\nEnter spacing between blocks: ")) ;; Place and rotate blocks along path (setq len (length blkLst)) (setq i 0) (setq dist 0.0) (setq pathDist (vlax-curve-getDistAtParam pathObj (vlax-curve-getEndParam pathObj) ) ) (while (and (< i len) (< dist pathDist)) (setq pt (vlax-curve-getPointAtDist pathObj dist)) (setq tangent (vlax-curve-getFirstDeriv pathObj (vlax-curve-getParamAtDist pathObj dist) ) ) (setq rotAngle (atan (cadr tangent) (car tangent))) ;; Flip angles to keep blocks upright (if (or (> rotAngle (/ pi 2)) (< rotAngle (- (/ pi 2)))) (setq rotAngle (+ rotAngle pi)) ) (if pt (progn (setq blk (cadr (nth i blkLst))) (setq blkCopy (vla-copy blk)) (vla-put-InsertionPoint blkCopy (vlax-3d-point pt)) (vla-put-Rotation blkCopy rotAngle) ) ) (setq dist (+ dist spacing)) (setq i (1+ i)) ) (prompt (strcat "\nCopied " (itoa i) " blocks along path.")) (princ) )- 10 replies
- autolisp
- block position
(and 3 more)
Tagged with:
pkenewell replied to james9710's topic in AutoLISP, Visual LISP & DCL
@BlackBox Thanks! (yeah - logand is fairly advanced, but shorter lol) -
BlackBox replied to james9710's topic in AutoLISP, Visual LISP & DCL
'... as simple'... using logand. (chortles) Teeheehee Props though, as yours allows arcs, etc... Well done -
pkenewell started following closed polyline with automatic hatch
@BlackBox Beat me to the Punch! @james9710 Here is my version - as simple as I can make it: (defun C:PLH (/ e el) (command "._pline") (while (= (logand (getvar "cmdactive") 1) 1) (command pause) ) (if (and (setq e (entlast)) (setq el (entget e)) (= (cdr (assoc 0 el)) "LWPOLYLINE") (= (logand (cdr (assoc 70 el)) 1) 1) ) (command "._-hatch" "_pro" "_S" "_S" e "" "") (princ "\nInvalid Polyline Created (Must be complete and Closed).") ) (princ) ) -
BlackBox started following closed polyline with automatic hatch
Without using Visual LISP reactors, here's a starting point: (defun c:PLH (/ pt) (entlast) (command "._pline") (while (and (not (initget 32)) (if pt (setq pt (getpoint pt)) (setq pt (getpoint)) ) ) (command pt) ) (command "_c") (command "._-hatch" "_p" "_s" "_co" "." "." "_la" "." "_s" (ssadd (entlast)) "" "" ) (princ) ) -
ronjonp replied to Mohamed Haytham's topic in AutoLISP, Visual LISP & DCL
devitg started following Copy blocks to curve according to another curve and closed polyline with automatic hatch
devitg replied to james9710's topic in AutoLISP, Visual LISP & DCL
@james9710 please upload your sample dwg where you will apply such lisp -
devitg replied to HypnoS's topic in AutoLISP, Visual LISP & DCL
@HypnoS Please show the command line text or error message.- 10 replies
- autolisp
- block position
(and 3 more)
Tagged with:
hi, can someone please assist me on creating a lisp: create polyline then after closing, it will automatically create a solid hatch within the closed polyline. hatch should be solid and layer is as per current. command should be PLH big thanks. we are working on large scale landscape projects that need hatches of each area of soft scape and hardscape
Tsuky replied to Mountain_XD's topic in AutoLISP, Visual LISP & DCL
It works, but the fence must pass on each side of the middle of the segment to be extended. -
I just did a quick look in AutoCAD, this may be a bit tricky for me. Let me get my paid to do work done and I'll do more looking. -
Tsuky replied to Mohamed Haytham's topic in AutoLISP, Visual LISP & DCL
Try the code modified. If equal starting and ending widths or global width is define, the global width is individual set otherwise is ignored. Also takes into account the last segment if the polyline is closed as well as the generation of the linetype as well as the UCS of the original entity (defun c:break_lw ( / js i ent dxf_obj dxf_43 dxf_38 dxf_39 dxf_10 dxf_40 dxf_41 dxf_42 dxf_39 dxf_210 n) (initget "All Select") (if (eq (getkword "\nLWPolylines to break at each vertex? [All/Select] <Select>: ") "All") (setq js (ssget "_X" (list (cons 0 "LWPOLYLINE") (cons 67 (if (eq (getvar "CVPORT") 2) 0 1)) (cons 410 (if (eq (getvar "CVPORT") 2) "Model" (getvar "CTAB"))) ) ) i -1 ) (setq js (ssget (list (cons 0 "LWPOLYLINE") (cons 67 (if (eq (getvar "CVPORT") 2) 0 1)) (cons 410 (if (eq (getvar "CVPORT") 2) "Model" (getvar "CTAB"))) ) ) i -1 ) ) (cond (js (repeat (sslength js) (setq dxf_obj (entget (setq ent (ssname js (setq i (1+ i)))))) (if (cdr (assoc 43 dxf_obj)) (setq dxf_43 (cdr (assoc 43 dxf_obj))) (setq dxf_43 nil) ) (if (cdr (assoc 38 dxf_obj)) (setq dxf_38 (cdr (assoc 38 dxf_obj))) (setq dxf_38 0.0) ) (if (cdr (assoc 39 dxf_obj)) (setq dxf_39 (cdr (assoc 39 dxf_obj))) (setq dxf_39 0.0) ) (setq dxf_10 (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) dxf_obj)) dxf_40 (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 40)) dxf_obj)) dxf_41 (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 41)) dxf_obj)) dxf_42 (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 42)) dxf_obj)) dxf_210 (cdr (assoc 210 dxf_obj)) ) (if (not (zerop (boole 1 (cdr (assoc 70 dxf_obj)) 1))) (setq dxf_10 (append dxf_10 (list (car dxf_10))) dxf_40 (append dxf_40 (list (car dxf_40))) dxf_41 (append dxf_41 (list (car dxf_41))) dxf_42 (append dxf_42 (list (car dxf_42))) n (cdr (assoc 90 dxf_obj)) ) (setq n (1- (cdr (assoc 90 dxf_obj)))) ) (repeat n (entmake (append (list (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity") (assoc 67 dxf_obj) (assoc 410 dxf_obj) (assoc 8 dxf_obj) (if (assoc 62 dxf_obj) (assoc 62 dxf_obj) (cons 62 256)) (if (assoc 6 dxf_obj) (assoc 6 dxf_obj) (cons 6 "BYLAYER")) (if (assoc 370 dxf_obj) (assoc 370 dxf_obj) (cons 370 -1)) (cons 100 "AcDbPolyline") (cons 90 2) (cons 70 (boole 1 (cdr (assoc 70 dxf_obj)) 128)) (cons 38 dxf_38) (cons 39 dxf_39) (cons 10 (car dxf_10)) ) (cond (dxf_43 (list (cons 43 dxf_43) (cons 40 dxf_43) (cons 41 dxf_43) ) ) ((equal (car dxf_40) (car dxf_41)) (list (cons 43 (car dxf_40)) (cons 40 (car dxf_40)) (cons 41 (car dxf_41)) ) ) (T (list (cons 40 (car dxf_40)) (cons 41 (car dxf_41)) ) ) ) (list (cons 42 (car dxf_42)) (cons 10 (cadr dxf_10)) ) (cond (dxf_43 (list (cons 43 dxf_43) (cons 40 dxf_43) (cons 41 dxf_43) ) ) ((equal (car dxf_40) (car dxf_41)) (list (cons 43 (car dxf_40)) (cons 40 (car dxf_40)) (cons 41 (car dxf_41)) ) ) (T (list (cons 40 (car dxf_40)) (cons 41 (car dxf_41)) ) ) ) (list (cons 42 (cadr dxf_42)) (assoc 210 dxf_obj) ) ) ) (setq dxf_10 (cdr dxf_10) dxf_40 (cdr dxf_40) dxf_41 (cdr dxf_41) dxf_42 (cdr dxf_42)) ) (entdel ent) ) (print (sslength js)) (princ " LWpolyline(s) breaked at its vertexs.") ) ) (prin1) ) -
Nikon replied to Mohamed Haytham's topic in AutoLISP, Visual LISP & DCL
If a polyline consists of several segments and they have different widths, then the global width is not defined in the properties. If a polyline from the same segment has different starting and ending widths, then the global width is also not defined in the properties. The global width in the properties is displayed only for a polyline of several segments of the same width or a polyline of the same segment with the same starting and ending widths. If you want to set the same global width of the polylines, simply select all the polylines and set the desired width in the properties. Or did I misunderstand what you want to do?.. -
@devitg Yours seams to not work for me at all @BIGAL I can't quite go through this routine to see final result. nothing happens after i daw a line. Also I already have a polyline that goes though all blocks that I need, so the part in lisp that tells me to draw line over blocks is unnecessary To be more precise. Lisp CopyBlockstocurve works great, the only part i want to change is that I dont want to click on each block to copy it to straight line. I want them to be copied automaticlly acording to pline that is existing- 10 replies
- autolisp
- block position
(and 3 more)
Tagged with:
Mohamed Haytham replied to Mohamed Haytham's topic in AutoLISP, Visual LISP & DCL
Thanks all for providing different lisps. All worked perfect in terms of breaking the poly, but I have one small issue, the global width is remained undefined. Is there a way even with a different lisp to assign the Global width from the start / End segment width? -
BIGAL replied to HypnoS's topic in AutoLISP, Visual LISP & DCL
Another give it a try. ; https://www.cadtutor.net/forum/topic/98615-copy-blocks-to-curve-according-to-another-curve/ ; get blocks along a pline at any XY then redo as a straight line. ; By AlanH July 2025 (defun c:wow ( / bname co-ord ent obj plent pt spac ss x) (setq oldsnap (getvar 'osmode)) (setvar 'osmode 0) (setq plent (car (entsel "\pick pline joining blocks "))) (setq obj (vlax-ename->vla-object (car (entsel "\nPick block object ")))) (setq pt (getpoint "\nPick left point ")) (setq spac (getreal "\Enter spacing ")) (setq bname (vlax-get obj 'effectivename)) (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget plent)))) (setq ss (ssget "F" co-ord '((0 . "INSERT")))) (command "line" pt (mapcar '+ pt (list (* (- (sslength ss) 1) spac) 0.0 0.0)) "") (repeat (setq x (sslength ss)) (setq ent (ssname ss (setq x (- x 1)))) (setq obj (vlax-ename->vla-object ent)) (if (= (vlax-get obj 'effectivename) bname) (progn (command "copy" ent "" (vlax-get obj 'Insertionpoint) pt) (setq pt (mapcar '+ pt (list spac 0.0 0.0))) ) ) ) (princ) )- 10 replies
- autolisp
- block position
(and 3 more)
Tagged with:
Convert Map Drawing From meter to FEET
BIGAL replied to smitaranjan's topic in AutoLISP, Visual LISP & DCL
If you have a reference point X&Y in metres and in feet then you can move the dwg to that point and apply a scale factor. 1 foot = 0.3048 m. There may be a conversion program for where you are in the world, feet to metres converting a point XY. It is easy to do a direct conversion but often with Geo stuff scale factors, world zones and so forth creep in. X=259975.41 Y=5129431.27 Z=0.00 : (/ 259975.41 0.3048) 852937.696850394 -
@HypnoS Please give it a try cpy-blk-2-poly.lsp- 10 replies
- autolisp
- block position
(and 3 more)
Tagged with:
smitaranjan started following Convert Map Drawing From meter to FEET
As the drawing has Geomap, it is not converting from M to Ft. Can't use scale, -dwgunits, Classicinsert too. Is there an y lisp to convert without changing position? as layout and Geomap is there. HM25E - Permit & Design 1.dwg
mhupp replied to Mountain_XD's topic in AutoLISP, Visual LISP & DCL
I know he uses BricsCAD and I used it for the last 5 years when I was still working in CAD. liked it a lot more the AutoCAD. there are differences but mostly for the better like double extend. -
Dear irneb, pBe, Your code is excellent, but I have an issue that I need help with. The code works fine when selecting only annotative objects. However, when selecting multiple objects for the code to automatically detect and process, it doesn’t completely remove all the excess annotation scales. Could you please help me revise the code to fix this?
AutoCAD System Variables List: Tuesday Tips With Frank
To summarize a recent discussion in a forum, User A mentioned the usefulness of TEXTALLCAPS in AutoCAD, and User B said they didn’t know about that command. The pedantic tips guy (me) chimed in and explained that it was actually a system variable. Always looking for subject matter for this space, I thought I’d explore the world of AutoCAD system variables, looking for diamonds in the rough. And I had plenty to choose from. I have no idea what the actual number is, but I counted 897. I’ll present some here today and label them (according to me) as either Cool, Useful, or Interesting. As always, your mileage may vary. The list will be presented in alphabetical order. Before we dive in, a little bit about AutoCAD system variables as all fall into a few categories. Their values are either saved in the drawing, the registry, or not at all. Most values are integers, but some are real numbers or even strings. I’ll label each accordingly for you. ATTIPE Integer | Registry | Interesting This controls whether or not the text formatting toolbar is displayed with the in-place editor when modifying multiline text. Are you looking for the same functionality for regular Mtext? You can find it in the ribbon, but the variable is called MTEXTTOOLBAR. MAXSORT Integer | Registry | Useful Have you ever called up a large drawing, maybe with a lot of Xrefs, and the layer list doesn’t sort alphabetically? That’s what MAXSORT does – it sets the maximum number for sorting these named items. It defaults to 1000, so set it to something higher, but beware, 32767 is the limit (which is, of course, the maximum value of a 16-bit signed integer.) MIRRHATCH Integer | Registry | Useful When we learned AUTOCAD, we were all taught about MIRRTEXT, but did you know it has a close cousin called MIRRHATCH? Since you know what the former does, I won’t explain the latter, but now you know. MTJIGSTRING String | Registry | Cool Our first “cool” entry is MTJIGSTRING. You know that little piece of preview text that appears in the corner of your box as you’re creating Mtext? That’s called the Jig String. And with this variable, you can change it to whatever you want, limited to 10 characters or under. NOMUTT Short | Not Saved | Cool Another cool entry and a card-carrying member of the AutoCAD All Name Team, NOMUTT, just had to be included here. But unless you’re a hardcore programmer, you’ll never use it. It was internal to Autodesk only for years and was finally made public sometime around 2006. It turns off Muttering, which is the normal command line messaging that is displayed. PEDITACCEPT Integer | Registry | Useful Do you convert lines or other objects into Polylines a lot? Do you get tired of AutoCAD asking you if you want to turn your selection into a Polyline? Set PEDITACCEPT to 1 to automatically convert it without the prompt. Now that’s useful. REPORTERROR Integer | Registry | Interesting This variable will suppress the display (and, therefore, submission of) the Customer Error Report (CER) if AutoCAD closes unexpectedly. I wasn’t aware of this one until I started researching this post. Let’s just say I immediately put it to good use for a client. TEXTALLCAPS Switch | Registry | Useful Ah, the variable that started it all. For many of us, it was drilled into us at an early age that lettering (now typing) was to be done in all caps. For the most part, that drafting standard has continued into today, with a few outliers choosing sentence case – which is generally what we use outside of AutoCAD. Better yet, it’s a registry variable, so turn it on once, and you’re good to go without having to remember to use that pesky Caps Lock key. TEXTGAPSELECTION Integer | Registry | Useful I recently trained a new user and quickly realized he was having problems selecting text. In a word, he often missed, thinking he was hovering over a text element when he actually wasn’t. Setting TEXTGAPSELECTION to 1 (on) solves that problem. With it enabled, you can select the text object by selecting the gaps or spaces between characters. Definitely useful. USER USERR USERS 12345 Integer, Real, String | Drawing | Cool If you’re a veteran AutoLISP coder, you probably know that AutoCAD gives you 15 blank variables that you can use for yourself. There are 5 of each type. USER holds integers, USERR gets real numbers, and USERS takes strings. These are all saved in the drawing, so they’re only valid while you’re still in your drawing session. VTENABLE Integer | Registry | Useful If you’re like me, and you may want your zoom to just happen and not use the cool, animated transition between views, set VTENABLE to zero and save some valuable milliseconds. It’s actually a true integer variable, as there are eight total settings you can choose from. Here is a link to the help file to assist you in making a wise choice. But, if you like the transitions, you’d like them to happen either faster or slower. Set VTDURATION to something other than its default 750 milliseconds. Please note that valid entries are between 0 and 5000 – and zero would also effectively turn VTENABLE off. And In The End How interesting. If you noticed, I listed two other SysVar types; “Short” and “Switch” to be exact. The learning never ends with AutoCAD, does it? If you want to further explore AutoCAD’s world of System Variables, the best place is from the System Variables tool found in the Tools panel of the Express Tools ribbon tab. There are 897 in there, and surely you’ll find your own little diamond. Happy hunting! More Tuesday Tips Check out our whole Tuesday Tips series for ideas on how to make AutoCAD work for you. The post AutoCAD System Variables List: Tuesday Tips With Frank appeared first on AutoCAD Blog. View the full article
