mhupp replied to MSHR's topic in AutoLISP, Visual LISP & DCL
Yes but as I have had to do things working with the government or local municipalities isn't so cut and dry. just easier to do it the way they want it - Today
A big table of all the boreholes can be made looking like this. Think of it as more than two vertically, yes can have a color background. Is that ok ? Can be sorted by date or name. -
PGia replied to MSHR's topic in AutoLISP, Visual LISP & DCL
Hi, I suppose it must be as you say, but wouldn’t it be easier to associate the information with each manhole and display it when selecting each one with the mouse? In my opinion, with your method the information is difficult to relate, because it appears too concentrated. - Yesterday
PAHo joined the community
Bummer extra work to be overcomplicated and hard to update probably by design. -
TimC replied to TimC's topic in AutoCAD 3D Modelling & Rendering
I'm looking to make it kind of a side gig but nothing real major. Honestly, I have a love hate relationship with AutoCAD. Penn Foster really put a bad taste in my mouth for it with the lack of true instruction and having to lean on this forum for 90% of my problems while they were getting paid to "teach" me. However, the more I've used it the more I'm really starting to enjoy it. It's just little quirks like this that are aggravating. I messed around with TinkerCAD a little and I'm really trying to learn Fusion 360 but I just don't like fusion after using AutoCAD. It seems like everything is backwards from AutoCAD. I'm gonna take your advice and play with TinkerCAD some more -
Do you actually have or want a job using AutoCAD? If so, learning to do 3D Text, models, etc. is worth the effort. There used to be some LISPs and other programs around to make it better, but it seems some of those do not work in newer AutoCAD now. If you just want to create nice 3D prints, something more specific to that task would be more worth the effort. TinkerCAD is pretty easy, designed for elementary school kids about 8 years old and up. Introduction to TinkerCAD: Part 5 - Adding Text -
My thought was I would be able to edit font and change text when needed but obviously I was wrong...lol -
Drawing space obscured by command line
SAFeSTeR replied to SAFeSTeR's topic in AutoCAD Drawing Management & Output
Ok I've sussed it now. I had to drag it to the bar/area to the right of the model and paper space tabs, not the bottom of the drawing area where it also snaps to, leading me to believe this was the correct position. Thanks for your response SLW210. -
SLW210 replied to SAFeSTeR's topic in AutoCAD Drawing Management & Output
Then possible some sort of bug, maybe a restart of AutoCAD if you haven't, maybe a repair. Could be Windows related. -
Yep, pretty sure I did that but I've just double checked and still the problem is there. -
That was nice of you, but what if they need a font change. While it is possible to quickly do the 3D texts in AutoCAD, it is much better to learn to add it with the 3D Printer software, easy changes and adjustments. Just look at the YouTube video I linked in my previous post. No doubt learning to do 3D Text in AutoCAD is going to take some work and practice since you have to start a new to make font changes. Though with proper planning, it works OK. how to make 3d text in autocad | 3d text in autocad -
OK so this might sound like a dumb question, but you said you did each character one at a time. Does that mean I'm inputting my text wrong? I'm creating a text box, so therefor when I attempt to extrude or presspull, it's trying to extrude the whole name or number at once -
Looks like you need to "dock" the commandline. > Click and drag the command line window to the top or bottom edge of the application window until it snaps into place. This also fixes the F2 issue, should be a separate window when commandline is docked. -
Pinx888 joined the community
What external software are you using? You will most likely need a custom solution.
SAFeSTeR started following Drawing space obscured by command line
SAFeSTeR posted a topic in AutoCAD Drawing Management & Output
I've just started at a new company, have had AutoCAD LT 2027 installed and am currently setting up my preferences etc. What I've noticed is that the command line now obscures the visible drawing area which didn't happen with previous versions of CAD I have used. In the attached image I have highlighted in red the affected areas, including the UCS and balloon notification. When I zoom extents the bottom of the drawing is also obscured and it happens in both model and paper spaces. I thought it was to do with the lock settings for toolbars and widows but changing those does not seem to help (I always have them locked by default). What I have just noticed is that when I press F2 to view the command history it no longer opens in a separate window but instead just extends vertically so am wondering if it's anything to do with that but I cannot find any relevant settings. Does anyone have any idea how to fix this please? -
OKBuddyCAD joined the community
a0908211022 joined the community
I thought I posted something already, I agree with @mhupp making a single table is much easier, it can be sorted via borehole name and so on. Yes you can have it now, many of us here have done that request many times. Or can do say a couple of tables rather than lots. Yep found at Theswamp. https://www.theswamp.org/index.php?topic=60630.0 Need sample dwg and a Excel or csv. -
BIGAL replied to TimC's topic in AutoCAD 3D Modelling & Rendering
I think you just need to practice creating 3d objects more, you need to look at how Extrude, Union, Subtract, Presspull work. one thing you need to do in this task is take advantage of extrude in -ve direction. so the base goes down, but all the rest get extruded up with correct height. Anyway you have something now so can scale a character and use presspull to change its height. Make sure your in a 3d view when using presspull to change height as must pick top face edge. Just a comment I did every character one at a time to make sure I did them correct. -
I understand there are ways of selecting which XREFS you want to change. ; Set all xref colors in a dwg ; By AlanH May 2026 ; Multi choice added by AlanH (defun c:setxrefcol ( / lst blk lays xname tc) (setq lst '()) (setq blk (tblnext "BLOCK" T)) (while blk (if (member (logand (cdr (assoc 70 blk)) 4) '(4)) ; bit‑4 = xref (setq lst (cons (cdr (assoc 2 blk)) lst)) ) (setq blk (tblnext "BLOCK")) ) (if (not AH:Toggs)(load "Multiple toggles.lsp")) (setq ans (reverse (ah:toggs (cons "Choose Xrefs " lst)))) (setq lays (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))) (setq tc (vla-GetInterfaceObject (vlax-get-acad-object) "AutoCAD.AcCmColor.20")) (setq lst2 '()) (repeat (setq x (length ans)) (if (= (nth (setq x (1- x)) ans) "1") (setq lst2 (cons (nth x lst) lst2)) ) ) (foreach lname lst2 (vlax-for lay lays (if (wcmatch (vlax-get lay 'name) (strcat "*" lname "*")) (progn (if (= lname "Defpoints")(alert "defpoints")) (vla-SetRGB tc 180 180 180) (vla-put-TrueColor lay tc) ) ) ) ) (princ) ) (c:setxrefcol) You must save multi Toggles.lsp in a support path as its auto loaded, it will display the names of your xref's, up to about 20 xref's by name, then just tick on the ones you want to change. Multi toggles.lsp
Ch-Ch-Ch-Ch-Changes – AutoCAD Change Commands: Tuesday Tips With Frank
You never know what might inspire a Tuesday Tip. This time, it came from my favorite streaming music service when it played David Bowie’s 70s hit, Changes. I immediately thought about the awesome AutoCAD command, CHSPACE, or Change Space. It’s certainly worth discussing here, but I felt there wasn’t enough meat there to write a full blog on it. This happens occasionally, and I’ve been known to package them up into an AutoCAD Potpourri post. You can find the latest one here. But how do I play off the song for the blog? Well, the answer came in the lyrics; there are four “Ch’s” before Changes (is it in your head yet?) Fortunately, I know of three other AutoCAD Change commands that start with CH, so here we go! AutoCAD Change Commands #1: Ch – CHSPACE The main entry here gets top billing. Have you ever run into a situation where the text, dimensions, or other objects were drawn in the wrong space? As a Tuesday Tip reader, we’ll assume it was someone else who made the mistake, and you’re tasked with fixing it. This is where CHSPACE comes in. This handy command will move your objects from paper space to model space (or vice versa), all while preserving the scale of the objects. No need to redraw or rescale anything. CHSPACE does it all for you. Plus, it’s an easy workflow. Issue the command (see the image below for the ribbon location, or just type it in). First of all, this only works from a layout tab. You can’t use it in the Model Space tab. If you do make that mistake, it will remind you. You’ll be prompted to select your desired objects. If they are currently in paper space, you’ll be asked to select the viewport to send them into its model space. If the objects are within an activated viewport (model space), CHSPACE will move them into paper space for you. And again, your scaling will be preserved. AutoCAD Change Commands #2: Ch-Ch – CHANGE Boy, this one goes back a long way. There was a time when changing an object’s properties wasn’t as easy as it is now. We had to use the CHANGE command, which does not appear in the ribbon and is only available from the command line. It prompts you to select your objects, then you can select or enter change points (the coordinates of the object – a most inefficient way of doing that), or you can specify Properties from either the command line or your dynamic input. Doing so will present you with a menu (see below) of the available properties you can change. Be aware that if you select something named, like Layer, you’ll have to type it manually, so you’ll probably need to memorize all of your layers and their proper spelling. Riiiight… Okay, I get it. There are many easier ways to accomplish this these days. However, it can come in handy if you’re writing scripts or AutoLISP routines. In fact, I’ve used it in the latter myself. Please note that if you do, you might want to turn off DYNPROMPT first. AutoCAD Change Commands #3: Ch-Ch-Ch – CHPROP The third “Ch” command is a more direct approach to the previous Change command; it’s called CHPROP, which means Change Prop(erties). And again, it’s command line only. It doesn’t have the option to change an object’s coordinates, and it goes right to the Properties option instead. Streamlining your workflow by saving a few clicks? Who doesn’t like that? You’ll get the same menu as you see above, and it works the same way. Well, almost. Notice entry number two in the menu. For some reason, Elevation is not included in the CHPROP menu. I’ll just leave you to ponder that strange omission. But hey, it made for a third “Ch” entry. AutoCAD Change Commands #4: Ch-Ch-Ch-Ch – CHURLS Last but not least is a member of the AutoCAD All-Name team. It is called CHURLS, and it stands for Change URL’s. And check this out, you can find it in the menu. It’s in the last panel of the Express Tools tab. Yes, it’s an Express Tool, but like a lot of ET’s it can come in quite handy. In today’s world, it’s not uncommon to attach hyperlinks to certain objects. And, like most things in AutoCAD, they sometimes need to be changed or edited. Granted, you could use the HYPERLINK command, but CHURLS acts as a shortcut for you. After launching the command, select your object with the attached URL. Hit enter, and you’ll get the dialog as shown below, showing the current URL, already highlighted. I suggest already having the new URL on your clipboard so you can just paste it over the highlighted old one. That’s All Folks I’d like to thank the late David Bowie for inspiring this post. I was also lucky to know that AutoCAD has these four “Change” commands. Granted, a couple of them aren’t too useful in today’s world, but two of them are. So arm yourself with these CH-powered changes, and make your drawings Hunky Dory** again. (** The name of the 1971 album that Changes was on.) You’ll also be glad to know that no AutoCAD command begins with “HUN.“ More Tuesday Tips Check out our whole Tuesday Tips series for ideas on how to make AutoCAD work for you. The post Ch-Ch-Ch-Ch-Changes – AutoCAD Change Commands: Tuesday Tips With Frank appeared first on AutoCAD Blog. View the full article -
Jesper Hedlund joined the community
The problem is that CTAB is always set to current tab value, which is no pronblem when cycling the different layouts and plotting them. The problem is when using external software where all layouts will display the CTAB name. For a drawing saved in TILEMODE 1: Drawing Tab Attribute value Drawing1.dwg Model Model Drawing1.dwg Layout1 Model Drawing1.dwg Layout2 Model This is what you want to see: Drawing Tab Attribute value Drawing1.dwg Model Model Drawing1.dwg Layout1 Layout1 Drawing1.dwg Layout2 Layout2
Set Pline Z value by selecting text
pkenewell replied to PaulyPHI's topic in AutoLISP, Visual LISP & DCL
@darshjalal Nice work! Your added Automatic mode, and the code to strip numbers out of the text is over and above! -
@PaulyPHI Here is a quick walk-though: This uses Visual LISP to pull the text string from the selected object and convert it to a real number. See the added comments below. (if (and ;; Logical AND = All conditions must be met. ;; 1) an object must be selected. (setq es (entsel "\nSelect Text Object: ")) ;; 2) The selected object must have a text string property, i.e. TEXT, MTEXT, ATTRIBUTE, MLEADER, etc. (vlax-property-available-p (vlax-ename->vla-object (car es)) 'TextString) ;; 3) Retrieve the textsting value if the above conditions are met. (setq newZ (vla-get-textstring (vlax-ename->vla-object (car es)))) ;; 4) The textstring value must evaluate to greater than 0 when converted to a real number. This only works if the text is numerical. (> (setq newZ (distof newZ)) 0.0) ) ;; if all conditions are met, then continue to the (progn) block that performs the changes. -
Bill Wan joined the community
mhupp started following Automatically placing borehole tables with leaders without overlap
Welcome. To make a cleaner look I would make a master Chart (or multiple BH SW MW or by area with a box around them) with all the relative call outs. this would allow a larger view of the area. eliminate the use/need of leaders that aren't really doing anything but cluttering the drawing. -edit Then updating would be adding borehole location and adding to the chart. -
I agree 100% I've been on several of the "free STL" sites and that stuff is nice, especially for new people, but I like the satisfaction of knowing I built that and you're definitely right with some of that stuff needing tweaked. I've run into that a few times. I have a Flashforge AD5X and I'm still learning to use the software. If I remember correctly, I just used the STLOUT command to export the file from AutoCAD, then I open Flashforge and click/drag it from my desktop onto my slicer -
Like I stated, I still like leaning on AutoCAD for making things for the 3D printer, but also learning Blender and playing with TinkerCAD, etc. The main goal is getting nice 3D Prints, I can tell you from experience, the stuff you get from online, supposedly ready to print, sometimes needs a little tweaking or outright re-modeled. I also have been learning to work in the 3D printer software, in my case, Bambu Studio, it's a lot easier cleaning up, scaling, adding text, etc. right before slicing. Like anyone that uses tools to do a job, learning what tools to use, how to use them, when to use what, etc. is usually the best way to go forward, it's a learning process. By all means start with AutoCAD and improve, we are here to help. Do you know how to export to STL and import that into your slicer?
