  1. Yesterday
  2. GLAVCVS
    Hybrid parallel
    Obviously, this has now become something more than just the search for a solution to a single user’s problem. First of all, I should say that I myself was also reluctant to accept the concept of equidistance advocated by @GP_ and @dexus For the simple reason that applying this principle forced me to accept that the centerline should be the same in these two drawings. Equidistance requires ignoring those areas of the margins that do not geometrically affect the axis. This, which initially caused me some resistance, I eventually came to accept conceptually when I realized that it could serve as a criterion for defining what is a “recodo/inlet” and what is not. So I have abandoned my previous approach and adapted it to this new situation. Having made this clarification, I must say that this concept of equidistance makes the calculation of a centerline more feasible. I’ve been running some tests with Dexus’s latest code, which is the best so far. However, I’ve discovered some “holes” that I hadn’t noticed before. I’m attaching a few images showing this. In my view, these are conceptual errors rather than geometric limitations. And what can we consider “geometric limitations”? I believe that, in any case, every vertex of the centerline must be equidistant from both margins. If this is not the case, the result is not correct. However, the intermediate regions along each segment may be subject to geometric limitations depending on the desired precision. Therefore, in bends or turns, the points taken within the adjustment or “problematic” segments may deviate (within a tolerance) from strict equidistance. The goal, therefore (in my opinion), should be to achieve equidistance at every vertex and to remain within a tolerance in the intermediate zone of each segment. After everything written here so far, some might wonder: is it really possible to obtain a centerline that meets these requirements? As far as I’m concerned, I’m running some tests. GusanoAcad.mp4 I’ll post something over the weekend
  3. Sooo thanks.It hadn't occurred to me.
  4. It unmirrors blocks.
  5. Hard to say with what little information you are giving. Is it just happening on the MacBook Pro? Can you post the .dwg? What are the computer specifications, graphics card, and driver?
  6. See on archive of the web: UNMI.LSP
  7. I’m trying to obtain the UNMI.LSP AutoLISP routine previously hosted at: http://my.sterling.net/~bdeshawn/unmi.lsp The site has been offline for a long time, and I haven’t been able to reach the original author. If anyone here has the source code, has used this routine before, or can provide details about what the program exactly does, I would greatly appreciate any help or pointers. Thank you in advance to anyone who can share documentation, the LISP file, or a functional equivalent.
  8. Buenos días Me parece muy interesante, se pudiera colocar un guion en el archivo de DWG. Ejemplo: el Archivo de llama Tomo.dwg y tengo varias presentaciones, 001,002, etc. ya la hora de crear el archivo independiente de cada una de las presentaciones me crea un fichero Tomo001.dwg, Tomo002.dwg, etc. y en mi caso me haría falta que saliera Tomo-001.dwg, Tomo-002.dwg, etc.
  9. james9710
    XREF PATH - COPY TO CLIPBOARD
    Great! it worked, thank you so much!
  10. PGia
    Hybrid parallel
    In general, we work with plans for projects of various kinds: engineering, cadastral mapping, and so on. Sometimes we submit proposals for public tenders, but so far without success. @dexus, the performance of your code looks different in that last drawing compared to what I’m seeing on my end. In any case, I think this topic has now entered the realm of a real challenge. @BIGAL: I agree. I think that’s the correct way to draw the centerline in the inlets.
  11. Last week
  12. SLW210
    Revit -> PDF -> Autocad
    You need to search for convert Raster to Vector programs. You can use Raster Design on the image files, but still requires some work, it doesn't work on the PDFs though. If they refuse to properly create Vector PDFs or give you a .dwg, your only option is to do them in a separate Raster/Vector program, Raster Design or trace them in AutoCAD.
  13. Welcome aboard. The use of "C:" in a defun name implies the command name, so in code above type "Test" after loading. I would also rename "test" to something that you would call it. (defun c:test ............. ........ ) ; end defun add this a last line and it will run on load ) ; end defun (c:test)
  14. Ok the "add" is only needed if you start excel as it would normally ask to select a fiel including "Blank", if you have Excel already open it will find current workbook. I need to put the add in correct spot not sure why I did not do before. This should work just replace in code. ; Count will be 0 if no excel open but if no workbooks also may return same value. Nil names. ; So a double check count /=0 and wb not "" (princ "\nOpening Excel...") ;; Try to get or create Excel instance (setq myxl (vl-catch-all-apply 'vlax-get-or-create-object '("Excel.Application"))) (if (vl-catch-all-error-p myxl) (progn (prompt "\nError: Could not start Excel.") (exit) ) ) (if (= (vlax-get-property (vlax-get-property myXL 'WorkBooks) 'count) 0) (vlax-invoke-method (vlax-get-property myXL 'WorkBooks) 'Add) ) (vla-put-visible myXL :vlax-true) (vlax-put-property myxl 'ScreenUpdating :vlax-true) (vlax-put-property myXL 'DisplayAlerts :vlax-true)
  15. ILoveMadoka
    I do not have Revit or the original files. The PDFs were provided to me. I would LOVE the .dwg files but we may not be able to get them from a third party vendor.
  16. I have trouble with the model space viewport - it's on 1/3 of the screen. I try to slide it to enlarge it but it just keeps returning to the initial state. I tried turning all the viewports on and off, command "WSCURRENT", every classical way to resolve the issue but nothing works. The problem occured on a AUTOCAD2024 for MacBook Pro. Thank you in advance.
  17. Danielm103
    Create a stable true rectangle
    Not too hard to create, a real pain to maintain as it must be compiled every time Autodesk decides to break binary compatibility
  18. lido
    Cursor color
    Try this. ;;Changing the color of CrossHair (transparent command) (DEFUN C:CHCOL (/ c d l m n o p) (setq c (quote ("Black" "Red" "Yelow" "Green" "Cyan" "Blue" "Magenta" "White" "8" "9")) l (quote ( 0 255 65535 65280 16776960 16711680 16711935 16777215 8421504 12632256)) d (vla-get-display (vla-get-preferences (vlax-get-acad-object))) m l o (vlax-variant-value (vlax-variant-change-type (if (= (getvar "TILEMODE") 0) (vla-get-layoutcrosshaircolor d) (vla-get-modelcrosshaircolor d) ) vlax-vbLong ) ) n (member o l) ) (cond ;;Rearrange list l with the First item = Current color from the list l ( (and n (/= o 0)) (setq l (append n (vl-remove-if (function (lambda (x) (member x n))) l))) ;;(v1 v2 n v3 v4 v5 ...) -> (n v3 v4 v5 ... v1 v2) ) ;;Add current color to lists ( (not n) (setq l (cons o l) m l c (cons (strcat (itoa (lsh (lsh o 24) -24)) "," (itoa (lsh (lsh o 16) -24)) "," (itoa (lsh o -16))) c) ) ) (T nil) ) (princ (strcat "\nCurrent color: " (nth (vl-position (car l) m) c) ". [Right Mouse Button/Enter Key/Space Key] to accept or any key to cycle CrossHair colors." ) ) (while (and (not (vl-catch-all-error-p (setq p (vl-catch-all-apply (function grread))))) ;;<Esc> (not (equal p (quote (2 13)))) ;;<Enter> (not (equal p (quote (2 32)))) ;;<Space> (/= (car p) 25) ;;Right mouse button ) (setq l (append (cdr l) (list (car l)))) (if (= (getvar "TILEMODE") 0) (vla-put-layoutcrosshaircolor d (car l)) (vla-put-modelcrosshaircolor d (car l)) ) (princ (strcat "\nCrossHair Color: " (nth (vl-position (car l) m) c))) ) (princ) ) ;;CHCOL
  19. SLW210
    You need to properly set up Revit. PDF is not fully vectorized after exporting it from Revit "Revit will use raster printing because this view uses..." while printing a sheet to PDF format in Revit And check the links at the bottom of those pages. You should be able to Export to a .dwg if that's what you want.
  20. Had the same issue before - the quickest fix for me was just updating the DIMSTYLE and then using DIMUPDATE on the whole selection. It forces all the oversized boxes to follow the current style settings instead of whatever weird scaling they picked up. Select all your dims → type DIMUPDATE → done. Usually cleans things up in one go.
  21. mhupp
    Need to pull the effective block name and check it against the block table. That is where the path is stored. updated code.
  22. james9710
    Hi mhupp, Thank you for the response. the result says: ; error: ActiveX Server returned the error: unknown name: IsXRef
  23. it didn't works
  24. BIGAL
    Cursor color
    Options, Display, there is an item cross hair color, in Bricscad. Its X Axis color Y axis color. I run Black background so colors like red are good. No code required.
  25. mhupp
    Untested I remember Lee Mac saying it was important to release the html obj as it could cause a memory leak or something. ;;----------------------------------------------------------------------------;; ;; Copy Selected Xref Path to Clipboard with prompt. ;; https://www.cadtutor.net/forum/topic/98871-xref-path-copy-to-clipboard (defun c:XrefToClipBoard (/ SS Blk Path html) (vl-load-com) (if (setq SS (ssget "_+.:E:S" '((0 . "INSERT")))) (progn (setq blk (vla-get-effectivename (vlax-ename->vla-object (ssname SS 0)))) (setq blk (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) blk)) (if (= (vla-get-isxref blk) :vlax-true) (progn (setq Path (vla-get-Path blk)) (vlax-invoke (vlax-get (vlax-get (setq html (vlax-create-object "htmlfile")) 'ParentWindow) 'ClipBoardData) 'setData "Text" Path) (vlax-release-object html) (alert (strcat "\nPath Sent to Clipboard\n Xref Path: " Path)) ) (princ "\nSelected Block isn't an Xref.") ) ) (princ "\nNothing Selected") ) (princ) ) -edit updated code.
  26. Lee Mac
    Cursor color
    Some food for thought - https://www.theswamp.org/index.php?topic=56816.msg605115#msg605115 To obtain the colour numbers, you can use my RGB<->OLE conversion functions: https://lee-mac.com/colourconversion.html#rgbole
