Automated tool for converting unreferenced AutoCAD DWGs to georeferenced GIS Shapefiles in 12s
BIGAL replied to Pramod Kumar's topic in AutoCAD Drawing Management & Output
I previously worked for a Municipal Authority and they had a Licensed Surveyor so he had the problem of tying things together. Sometimes easy sometimes very complex. Most of our projects were field surveyed so were current and tied to world co-ordinates. -
Soton joined the community
Thanks for the clarification, SLW210. Appreciate the guidance. I'll keep contributing new topics and discussions.
- 10 replies
- network nodes
- data extraction
(and 2 more)
Tagged with:
@AONE_LED has received the message about reviving old posts. So should be good now. @indiancad creates new posts, so no problem there, some are interesting at least. @BIGAL that's a good idea, as they do seem quite helpful, just a decade or so late.
- 10 replies
- network nodes
- data extraction
(and 2 more)
Tagged with:
Converting scanned engineering drawings into accurate editable CAD geometry
Even if left as a scan, the scan will last longer than the paper (maybe). Saying that, I work for a very old company (about a century), we still have some pretty decent old blueprints, but the decent ones look to have been copies of the originals. Luckily a quality scanner has a BLUEPRINT mode and makes some pretty good scans of those most of the time. We use a lot of contractors, so lucky for me they do a lot of that as well. Sometimes I do it for them if my boss requests. Here lately we have had a company do some laser scanning, further reducing the need for the old drawings. There is no guarantee the old drawing are correct either, so yes you always have to verify. I previously worked for a company that did quite a bit of work in the automobile industry, you know some of those factories are very old, that was the company that sent them out to be digitized. And yet, due to all of the different work (some not documented apparently) and different companies that do work, everything needs field verification. So all of that had to be budgeted into the job bids. Several competitors went under for having low bids and having to eat all of those costs. I never said anything about not verifying everything. I actually have to take worn out parts and create a .dwg of it, that takes a whole lot of verifying and redrawing. -
VicoWang started following Looking to hire a programmer to update our AutoCad Lisp routines and menu's.
VicoWang replied to TommyB's topic in AutoLISP, Visual LISP & DCL
If there is a need for mass distribution, you can try the VedaCAD.com I developed (supports AutoCAD 2006 to the latest version) 1. For individual developer distribution scenarios, you can use VCID to distribute it for free to the target users 2. For enterprise scenarios, you can centrally manage the plugins (such as AutoLISP, ARX, DLL, etc.) and environment configurations (such as CTB, SHX, DWT, etc.) for the entire company (even across regional multi-offices) -
MosesM joined the community
Steven P replied to indiancad's topic in AutoCAD Drawing Management & Output
However.... I have been working for 30 years now, never picked up a set of pencils or sat at a drawing board, always CAD and electronic formats, we really shouldn't be accepting scanned drawings! OK so I work on utilities, and some of the kit is 50 years and more old there is still those drawings to work through but I push in every project for the budget to redraw what we can. -
bodi joined the community
Maintaining Model Stability When Editing Complex 3D Features
When working with complex 3D parts, small changes to an earlier feature can sometimes cause several downstream features to fail, particularly when fillets, chamfers, cuts, and face references depend on the original geometry. This can make seemingly simple design changes unexpectedly time-consuming. How do you structure your 3D models to minimize these failures? Do you prefer building simpler features first, delaying fillets until the end, avoiding references to unstable faces, or using a different modelling strategy altogether? -
Interesting approach.I think verification against known dimensions is still necessary even after vectorization. -
Good point about using surrounding references to infer missing dimensions. Correcting parallax and distortion before tracing can make a significant difference, particularly with older scans. Reconstructing critical geometry from known dimensions still seems the safest option. -
Scaling in X and Y can correct some distortions, but it won't fix local warping across the sheet. For badly distorted scans, do you also check intermediate dimensions after scaling? -
Agreed. Redrawing from known dimensions is often the most reliable approach, especially when the scan itself is distorted. The challenge is when only a few dimensions are available and the rest of the geometry has to be reconstructed. -
Tracking Design Changes When Multiple Engineers Modify the Same DWG
indiancad posted a topic in CAD Management
When several engineers work on the same project, keeping track of design changes can become difficult, particularly when drawings are exchanged through email or shared folders rather than a centralized system. Comparing two DWG files may reveal geometric differences, but it doesn't always explain why a change was made or whether it affects connected components, dimensions, or downstream drawings. How do you manage drawing revisions in a multi-person CAD environment? Do you rely on revision clouds and revision tables, drawing comparison tools, file naming conventions, or a formal version-control system? What has worked reliably for your projects? -
Paul Li started following Chat
Pramod Kumar replied to Pramod Kumar's topic in AutoCAD Drawing Management & Output
Spot on, BIGAL—that's a critical distinction between diagrammatic cadastral field sketches and true-scale engineering infrastructure models. You've hit on the classic COGO (Coordinate Geometry) dilemma: Australian field notes and title plans are drafted for A3/A4 paper-space readability, where a 1 km tie to a State Survey Mark (PSM) or recovery rivet is visually condensed or broken with a dimension annotation, rather than drawn at 1:1 ground distance. If you just take raw polyline vertices from those sketches, the geometry is obviously distorted. Our pipeline currently targets 1:1 ModelSpace engineering drawings—like civil water networks, road corridors, and solar EPC layouts where 1 CAD unit = 1 meter (or 1 foot) in real space, and surveyors shoot 3+ GCPs at boundaries/manholes to compute a rigid Helmert 7-parameter or affine transformation into MGA2020 / GDA2020. For diagrammatic field notes, automated OCR/COGO parsing of bearing-and-distance text is an active research challenge. In your day-to-day workflow, do you manually traverse and key in the bearings/distances in BricsCAD, or do you use a specific LISP/Civil routine to reconstruct the boundary? -
"surveyor's GCP tie-points to snap the CAD geometry to real-world ground truth" Here in Australia a lot has a Field notes plan submitted as part of lot registration, tying to known PSM's, Rivets, Nails etc But the plan is hand drawn you can have a plan that shows details at say a few metres and has a tie to a point a Km away all in the one plan so there is no true scale to the plan. They are drawn and have to be printable so no points a Km away. You would have to redraw it at true scale. -
@AONE_LED seems to be dredging all posts about lighting. Maybe put all his responses in one post, with a link and an answer, under the heading Lighting appliances and CAD. Maybe its @indiancad brother.
- 10 replies
- network nodes
- data extraction
(and 2 more)
Tagged with:
You are 100% right @BIGAL and @SLW210. An unreferenced CAD drawing cannot replace SUE Quality Level A potholing/survey. Our tool is designed to ingest the surveyor's GCP tie-points to snap the CAD geometry to real-world ground truth -
I am pretty positive you are correct.
- 10 replies
- 1
- network nodes
- data extraction
(and 2 more)
Tagged with:
TommyB replied to TommyB's topic in AutoLISP, Visual LISP & DCL
I am located in Texas. -
Steven P started following Automatically drawing blocks
Where I see posts dug up from many years ago - particularly if there are several answers years later from the same accout - I am starting to assume there is some 'computer aided searching' going on.. not saying a AI bot explicitly but.....
- 10 replies
- 3
- network nodes
- data extraction
(and 2 more)
Tagged with:
SLW210 replied to Pramod Kumar's topic in AutoCAD Drawing Management & Output
Your YouTube video wasn't very helpful. This also looks to be a paid service you are advertising. I wouldn't work off of old drawings in those cases, like @BIGAL, I would get a field survey. -
SLW210 replied to TommyB's topic in AutoLISP, Visual LISP & DCL
Welcome to CADTutor!! -
How to bring OpenStreetMap streets and buildings into AutoCAD (DWG/DXF) — what actually works
SLW210 replied to OSM2CDR's topic in AutoCAD Drawing Management & Output
Yes, they look to be selling a service to me. -
We have sent old blueprints and microfiche out to a company to be put to digital at a previous company, they did a pretty good job, no telling the cost, this was quite a while ago. My boss did ask a few years ago about getting some paid interns to do some old blueprints that need scanned. Yes, if your company wants to spend the money, there are some pretty good software choices out there to make it easier. After a short learning curve I did very well with Raster Design and a few LISPs. I plan to see if my work will get this... HP AI Vectorization | HP® Official Site | HP® Official Site, at least see about a trial. -
Yes, they have already been warned twice about this.
- 10 replies
- 2
- network nodes
- data extraction
(and 2 more)
Tagged with:
EnM4st3r started following Automatically drawing blocks
@AONE_LED you do realize those are decade old posts you are answering to?
- 10 replies
- 2
- network nodes
- data extraction
(and 2 more)
Tagged with:
