  2. PGia
    Hybrid parallel
    I think the real-world situation may be more complex than what we’ve seen here so far. I took a look at the links that @SLW210 attached and decided to test the Lisp codes proposed up to this point. I looked through my drawings for something that could serve as an example for this problem, but it was like looking for a needle in a haystack. So, in the end, I decided to look for something in the real world that clearly corresponds to this issue — something like this: So I drew those margins and tested all the codes that have appeared in this thread so far. The result was… this! In the drawing, you can see the ones that managed to reach the end. However, the codes by BIGAL, GP_, GLAVCVS, and MarkoRibar couldn't even do that. Here’s the drawing EjeExple4.dwg
  3. Today
  4. pkenewell
    Create a stable true rectangle
    @Nikon Technically - your example could be done with object reactors. Alternatively, you can also use 2D constraints, which have been in AutoCAD since version 2010.
  5. If you only edit the rectangle with this the rectangle will stay true and the editing will be a bit more intuitive because the preview will be a true rectangle as well:
  6. I agree with you, I use these bindings. But when I found out how easy it is to change a true rectangle, I "fell in love" with it. I've been working in Autocad since 2000, but I don't remember that it was possible to build such a rectangle back then. I wonder in which version of Autocad was such a command available?
  7. pkenewell
    @Nikon Like I said - "For What It's Worth". Note also you can shorten the steps slightly by using the PERP object snap.
  8. With a true rectangle, there is much less movement to change the position of the sides.
  9. pkenewell
    @Nikon FWIW - you can use the midpoint grips to drag the rectangle in straight directions to keep it square.
  10. Maybe someone will be able to do it someday.
  11. It can be done, but it requires creating a custom object using ObjectARX (C++).
  12. It is a pity that there is no creation of a true rectangle in autocad itself!
  13. CyberAngel
    Pressure Pipe model wrong size
    Just a wild guess, did you try using architectural units instead of engineering? That might explain why a 10" pipe is less than 1"; could it be .833", that is, smaller by a factor of 12? or maybe change the drawing units to inches?
  14. I’m trying to work with Dynamic Blocks in AutoLISP. Question: Is it possible to read a Dynamic Block’s properties/parameters (for example visibility states, dynamic distances, flips, etc.) and then copy or apply those values to another block reference using plain AutoLISP/VLISP? If this is possible, what functions or example code should I look at? Thanksss.
  15. CivilTechSource
    Import Surface Styles
    @BIGAL From memory all it does is copy paste the coloring and range from the surface analysis and paste on the other surface. The file it exports it has ranges and colors. So I would imagine you should use the same surface style to make it work.
  16. Ugh I think I watched your video too fast. I haven't had much time to do anything slowly lately I believe object reactors only survive the current drawing session. You must consider that the reactor was created relative to an object name, and object names change between drawing sessions.
  17. Hi Nikon It seems your code is simply performing a scroll. You don't need Lisp to do that. Simply, select the grip and press the spacebar.
  18. Yes, but as it for as Title name for the topic. The plot is different. So, you're code will certenatly accomplish the desired result.
  19. RLX's doesn't change the color according to background. I use a black background and some objects are the color of the background. (This might be able to be adjusted in the PDFIMPORT options.) I tried some different PDF's and the original works fine in AutoCAD 2026 plus everything is white on black background, I need to try again with white background, but that also worked previously on the original, I might try 2025 later today if I get the time. IIRC, Adobe Acrobat, Bluebeam, and probably others have OCR options, but I usually don't bother converting text unless necessary, then I just manually use the one in AutoCAD, occasionally I have used the Acrobat OCR with mixed results. Of coarse, this would be much simpler if we just made the contractors give us the actual AutoCAD files instead of PDFs, me doing such a good job with the PDFs they don't seem to want to put forth the effort. I have had them send .dwg when they didn't convert well. Keeps me employed I guess.
  20. Saxlle
    problem with initget1
    Glad it works! You're welcome
  21. shokoufeh
    This solution worked perfectly Thank you so much
  22. Saxlle
    Inside the "initget" you use "Screening_50.ctb Fill_Patterns.ctb" with "_", and inside the "getkword" you use "Screening 50%.ctb/Fill Patterns.ctb", which is not equal as it in "initget". Everything must be equal. So, according from your's "initget", the "_" can't be in use, because it's in use for localization (for eg. "_RECTANG", "_LINE", etc.). From this link you can find this: Keyword Specifications The string argument is interpreted according to the following rules: 1. Each keyword is separated from the following keyword by one or more spaces. For example, "Width Height Depth" defines three keywords. 2. Each keyword can contain only letters, numbers, and hyphens (-). One of the possible solutions is to use this: (initget 1 "Monochrome.ctb acad.ctb Grayscale.ctb Screening50.ctb FillPatterns.ctb") (setq plotstyle (getkword "\nChoose plot style [Monochrome.ctb/acad.ctb/Grayscale.ctb/Screening50.ctb/FillPatterns.ctb] <Monochrome.ctb>:")) (cond ((equal plotstyle "Screening50.ctb") (setq plotstyle "Screening_50.ctb") ) ((equal plotstyle "FillPatterns.ctb") (setq plotstyle "Fill_Patterns.ctb") ) ) Best regards.
  23. Hi every one. I want to use initget to get the plot style from the user. In the code, the styles after Screening_50.ctb are not known by the Autocad. the same thing happens when I add Fill_Patterns.ctb before Screening_50.ctb. how do I solve the problem? (initget 1 "Monochrome.ctb acad.ctb Grayscale.ctb Screening_50.ctb Fill_Patterns.ctb") (setq plotstyle (getkword "\nChoose plot style [Monochrome.ctb/acad.ctb/Grayscale.ctb/Screening 50%.ctb/Fill Patterns.ctb] <Monochrome.ctb>: "))
  24. That AutoLISP code is an absolutely brilliant find! Dealing with those oversized dimension text boxes that throw off the text is such a pain, especially in legacy drawings. Seriously awesome work figuring out the MText width needed to be set to 0. This is going to save so much manual cleanup time for anyone else hitting this problem.
  25. Good day everyone! I've discovered new (old?) the possibilities of a true rectangle. It is very convenient to work with him! The only drawback is that the rectangle is unstable. You can create it and work with it only in the current file. If you then close and open this file, the properties of the true rectangle are lost. Is it possible to make it stable so that its properties are preserved? https://autocadtips1.com/2011/11/20/autolisp-make-a-real-rectacgle/ AutoLISP: Make a Real Rectangle Posted on November 20, 2011 by AutoCAD Tips A long time ago, AutoCAD used to make Rectangles and polygons as their own entities. When you made a rectangle and then did a LIST <enter> on it, it would show as a rectangle. Nowadays, these objects are those objects in their geometry but are made of polyline entities. So modifying these objects is sometimes hard. that’s where this routine steps in to help. This routine lets you create a rectangle and even after you continue working elsewhere in your drawing, you can come back to that rectangle and modify that object and it acts like how rectangles used to act in AutoCAD. Here’s how: TREC <enter> to start “True RECtangle” Create a rectangle how you normally create one When needed, this routine will let you drag a single corner and the rest of the rectangle’s geometry will adjust accordingly to keep its geometry as a rectangle. TrueRect.lsp
  26. Yes, this will substitued all layers into the UPPERCASE.
