  2. Have a look at lee-mac dynamic block properties there is a get current visibility name in there, also get all visibility names into a list.
  3. Look at (getvar 'extmax) & (getvar 'extmin) these are the size of your dwg wether your zoomed or not.
  4. BIGAL
    subfix in dimension...
    Something I have done for attributes in a block is pop up a dcl with the current attribute values so there is no reason why could not do the same just set a maximum number of lines 1 2 3 4 etc. If you leave a line blank that would be considered end of multi line input. It uses my library Multi getvals.lsp to make the dcl. Some example code can be changed to work with a Dimension. Have a go. ; Change an attribute value in blocks ; Using creation order rather than by tag name ; BY Alan H Sept 2025 (defun AH:blchange( / ss1 blname x inc atts) (if (not AH:getvalsm)(load "Multi Getvals.lsp")) (setq obj (vlax-ename->vla-object (car (entsel "\nPick block object ")))) (setq atts (vlax-invoke obj 'Getattributes)) (setq lst '()) (setq lst '("Enter new values ")) (foreach att atts (setq lst (cons (vlax-get att 'tagstring) lst)) (setq lst (cons 19 lst)) (setq lst (cons 20 lst)) (setq lst (cons (vlax-get att 'Textstring) lst)) ) (setq lst (reverse lst)) (setq ans (AH:getvalsm lst)) (setq x -1) (foreach att atts (vlax-put att 'Textstring (nth (setq x (1+ x)) ans)) ) (princ) ) (aH:blchange) Multi GETVALS.lsp
  5. BIGAL
    Find in Notepad
    Look for Notepad your Acad.pgp make code even shorter. This the bat file I use. d: cd\alan\lisp findstr %1 *.lsp
  6. Today
  7. You can private message me if you are after a custom program.
  8. Hi everyone When I open a dwg file and use the attached lisp to change the Qleader settings, no changes are made to the settings. Please fix the problem for me. qlset.lsp.lsp test.dwg
  9. (defun update-attributes ( / bln idx ins map obj sel tag val ) (setq ;; List of ;; ((lower-left point) (upper-right point) "attribute value") map '( ((-1179.5 -1006.0) (1179.5 1006.0) "S3.0") ) ;; Block name bln "Detail Cut" tag "SHEETNUMBER" ) (setq bln (strcase bln) tag (strcase tag) ) (if (setq sel (ssget "_X" (list '(0 . "INSERT") '(66 . 1) (cons 2 (strcat "`*U*," bln))))) (repeat (setq idx (sslength sel)) (setq idx (1- idx) obj (vlax-ename->vla-object (ssname sel idx)) ) (if (= bln (strcase (vlax-get-property obj (if (vlax-property-available-p obj 'effectivename) 'effectivename 'name)))) (progn (setq ins (vlax-get obj 'insertionpoint) val (vl-some '(lambda ( itm ) (if (vl-every '<= (car itm) ins (cadr itm)) (caddr itm))) map) ) (if val (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (progn (if (vlax-write-enabled-p att) (vla-put-textstring att val) ) t ) ) ) (vlax-invoke obj 'getattributes) ) ) ) ) ) ) (princ) ) (defun block-position-callback ( rtr arg ) (if (and arg (wcmatch (strcase (car arg) t) "qsave,save,saveas,plot,publish,regen,regenall")) (update-attributes) ) (princ) ) ( (lambda ( key ) (vl-load-com) (foreach rtr (cdar (vlr-reactors :vlr-command-reactor)) (if (= key (vlr-data rtr)) (vlr-remove rtr) ) ) (vlr-set-notification (vlr-command-reactor key '( (:vlr-commandwillstart . block-position-callback) ) ) 'active-document-only ) (update-attributes) (princ) ) "block-position-reactor" ) For whatever reason the code you posted wasn't agreeing with my CAD. I inverted the logic to test if true, and added a nil guard to ensure attributes are only updated when a valid value is found in the area map Thanks for pointing me in the right direction!
  10. Yesterday
  11. Hi, Very often the selection window is large enough for the drawing to be really zoomed out. In this case it's hard to point the window exactly where it should be. Zooming in is not possible because whatever is not on the screen will not be selected. Am I missing something here? Is there a way to zoom in and for the window to still catch whatever is not on the screen? Thanks. Lu
  12. GLAVCVS
    I think the best way to explain it is to include a picture of the DIMENSION before and after it was modified. Although perhaps other, more awake minds than mine have already understood it.
  13. leonucadomi
    @GLAVCVS IT'S OKAY, I JUST NEED IT WITHOUT HAVING TO ADD THE TEXT TO THE BEGINNING, SO TEXTS 1 AND 2 WILL ALREADY BE DEFINED WITHIN THE ROUTINE I mean I just select a dimension and the result is... true dimension accompanied by the "+" sign and below the line "text 1" and below this "text 2" (defun c:dimsub ( / enx grp idx new pos sel str ) (princ "\nColoca subfijo a dimension por debajo de linea con opcion de cambio") (if (setq sel (ssget "_:L" '((0 . "*DIMENSION")))) (repeat (setq idx (sslength sel)) (setq idx (1- idx) enx (entget (ssname sel idx)) grp (assoc 1 enx) ) (if (setq pos (vl-string-search "\\X" (cdr grp))) (setq new (cons 1 (strcat (substr (cdr grp) 1 pos) "\\X" str))) (setq new (cons 1 (strcat "+" "<>\\X" "TEXT 1))) ) (entmod (subst new grp enx)) ) ) (princ) ) this routine is from the master @Lee Mac I mean I'm looking to add a second line
  14. @Tharwat Sorry for opening this old post. Lisp works perfect but i get an error when extracting my dynamic block. My block has other visibilities do not share the same tag names. Is there a way for the lisp to read the current visibility?
  15. GLAVCVS
    @leonucadomi You should copy the code again. I changed a small thing to prevent NOMUTT from staying at 1.
  16. GLAVCVS
    To add all the text lines you need
  17. GLAVCVS
    Another option (defun c:subTexta (/ e le txa tx cj para) (if (/= (setq tx (getstring "\nType TEXT to add?: ")) "") (while (setq n (not (setvar "NOMUTT" 1)) x (princ (strcat "\rAdd \'" tx "\' to DIMENSIONs...")) cj (ssget "_:L" '((0 . "*DIMENSION")))) (while (setq e (ssname cj (setq n (if n (1+ n) 0)))) (entmod (subst (cons 1 (cond ((or (wcmatch (setq txa (cdr (assoc 1 (setq le (entget e))))) "*<>\n*") (wcmatch txa "*<>\\X*")) (strcat txa "\n" tx)) (T (strcat txa "<>\\X" tx)))) (assoc 1 le) le ) ) ) ) ) (setvar "NOMUTT" 0) (princ) )
  18. leonucadomi
    I NEED TO ADD A SECOND TEXT BELOW THE FIRST
  19. leonucadomi
    master , I am trying to do the following (defun c:dimsub ( / enx grp idx new pos sel str ) (princ "\nColoca subfijo a dimension por debajo de linea con opcion de cambio") ; (if (= "" (setq str (getstring t "\nSpecify string <TYP>: "))) ;(setq str "TYP") ; ) (if (setq sel (ssget "_:L" '((0 . "*DIMENSION")))) (repeat (setq idx (sslength sel)) (setq idx (1- idx) enx (entget (ssname sel idx)) grp (assoc 1 enx) ) (if (setq pos (vl-string-search "\\X" (cdr grp))) (setq new (cons 1 (strcat (substr (cdr grp) 1 pos) "\\X" str))) (setq new (cons 1 (strcat "+" "<>\\X" "TEXT 1"))) ) (entmod (subst new grp enx)) ) ) (princ) )
  20. Lee Mac
    Field
    But if you were curious as to what the entmake route looks like - consider the following thread: https://www.theswamp.org/index.php?topic=20446
  21. PGia
    Find&open files
    You're right. The file opens now. Thank you again.
  22. PGia
    Find&open files
    @CyberAngel I'm having recurring issues with the open file history in Visual Lisp. I asked about this issue here a while back. @rlx explained that the history is stored in the vlide.dsk file. I tried using the GLAVCVS code to open it.
  23. Lee Mac
    Field
    If you wish to entmake a field, you need to also entmake the FIELD entity within the TEXT entry of the ACAD_FIELD dictionary found within the extension dictionary attached to the entity - this is theoretically possible, but a lot of work and wheel reinvention. Instead, if you either create the MText object using vla-addmtext or convert the MTEXT entity into a VLA object and set the textstring property to a field expression, the CAD platform will automatically parse the field expression and configure the corresponding dictionaries for you.
  24. GLAVCVS
    Find&open files
    And try again
  25. GLAVCVS
    Find&open files
    It’s possible that vlide.dsk is not located in AutoCAD’s Support File Search Path. Find it using Windows Explorer and add its location to AutoCAD’s Support File Search Path.
  26. issammesk
    text field
    THANK YOU SIR
  27. CyberAngel
    Find&open files
    Not sure what you're trying to do. VLIDE is an AutoCAD command to open the Visual Lisp Integrated Development Environment.
  28. PGia
    Find&open files
    @GLAVCVS I type vlide@dsk in the command line, but it doesn’t do anything.
