A routine automates the creation of 3D Polylines, level labels, and slope percentages for infrastructure projects (SUPPORTS FEATURE LINES TOO)
darshjalal replied to darshjalal's topic in AutoLISP, Visual LISP & DCL
Updating version of the previous code> Regards. 3DSLOPE-automates the creation of 3D Polylines, level labels, and slope percentages -R2.LSP -
You can use possibly OBDX which can edit a dwg without opening it. Using a script is much simpler as it will open a dwg make the edits then close it. Should be reasonably fast. The obvious first step is what are you trying to change ? You need say a text file with the new settings, layer name, color, linetype on/off and so on. So if I understand correct another way, the sequence may be open a dwg add the xref do the layer changes save and close do next dwg. So what I am asking here does original dwg always have the xref pre loaded. Need sample dwg, txt and a xref. Can be blank just need layers,
Civil drafting school project help
ReMark replied to Autocadstudent's topic in Student Project Questions
Definition: "Stationing in surveying is a linear measurement system used to pinpoint exact locations along a project's baseline or centerline. One full station equals 100 feet." It starts as 0+00 (0 feet) which in this case would be the center of the cul-de-sac and stops at the end of the project which would be station 3+78.90 (378.97 feet). In between there is station 0+50 for the point-of-curvature (PC), station 1+93.87 for the point of tangency (PT) along with stations 1+00, 2+00, 3+00 and any others deemed necessary to call out. -
pkenewell started following Set Pline Z value by selecting text
pkenewell replied to PaulyPHI's topic in AutoLISP, Visual LISP & DCL
@PaulyPHI Give this a try.SetPlineZ_Updated.lsp- 1 reply
- 1
EmeraldSynth replied to Autocadstudent's topic in Student Project Questions
I've seen that photo in this chat. I'm just confused about how to even start it . What is it referring to when it says for example "Station 2+20"? -
Hi, I have been racking my brains to amend this lisp to do what i want and have failed.... so i ask you the gods of lisp for some help. I have acquired a lisp file via google AI that will set the elevation (z axis) of a poly line, easier to just select the pline and type in the elevation i hear you cry.... But my cunning plan was to amend the elevation of said pline by selecting the pline then select the text/mtext next to it..... I thought i could add some command to do this by looking at another lisp i have that does a similar thing, but i am a numpty and have given up.... I know there are many wise men out there that could just type some lines with their eyes shut and solve my problem... Obviously i would be greatly indebted to such persons and wish boundless fortune upon them granting wishes galore if i could... Also I just want an easy life as i approach retirement and thinking for gets in the way of thinking for myself..... Begging you nicely.. Paul SetPlineZ.lsp
ababs started following LAYER PROPERTIES
Hi everyone, I’m working on a project with multiple AutoCAD drawings (building floors), and each floor contains several XREF layers. I want to know if there is a way or tool to change XREF layer properties (such as color, linetype, lineweight, etc.) for multiple drawings at once without opening each file individually. For example: I have many floor plans. Each drawing has the same XREF attached. I want to directly modify the XREF layer overrides across all drawings in bulk. Is there a built-in AutoCAD feature, script, LISP, Sheet Set method, Layer States Manager workflow, or Autodesk tool that can do this automatically?
romzi joined the community
BABAR45 joined the community
froxen1 joined the community
I forgot all about this thread, meant to get back to it. My apologies. Elmer FEM – open source multiphysical simulation software CALCULIX: A Three-Dimensional Structural Finite Elemente Program use with PrePoMax Structural Analysis & Steel Design Software | AutoCalcs Free Online 3D Structural Finite Element Analysis Software There are some more open-source and free programs out there. These have a free trial. Finite Element Analysis (FEA) Software | Autodesk Download Inventor | Inventor Free Trial | Autodesk FEA Simulation Basics | Autodesk Inventor 2023
Hello all. Now I'm struggling with the same issues as everyone one else. So I've gotten to the cut and fill portion, and I'm stuck trying to figure out how to show this part of the instructions. Ms. Capitano decides to keep the driveway and the house level at elevation 180. Her surveying company recommends an angle of repose of 1.5:1. Draw the driveway layout cut and fill in the lower-left corner of your drawing. Use the information listed here to show the new contours on both sides of the driveway. How am I supposed to start off this, and how does the "angle of repose" factor in? Don't remember reading about that... Here's what my drawing looks like so far. Thanks! -
From what I can tell, you don't need to specify a particular update of Civil 3D to get the right application code. For instance, "AeccXuiLand.AeccApplication.13.1" will work for any flavor of Civil 3D 2019. Then just add a 1 for each successive year. Civil 3D 2019: 13.0 Civil 3D 2020: 13.2 Civil 3D 2021: 13.3 Civil 3D 2022: 13.4 Civil 3D 2023: 13.5 Civil 3D 2024: 13.6 Civil 3D 2025: 13.7 Corrections/suggestions welcome. Of course, they'll break the sequence as soon as it becomes widely known and useful.
EmeraldSynth started following Civil drafting school project help
zhorzh joined the community
inlajaus joined the community
as072260 joined the community
MultiPLine (MPL) — polyline-based MLINE replacement with per-line layers, presets, and auto-sync [Free + Pro]
BIGAL replied to SkillAmplifier's topic in AutoLISP, Visual LISP & DCL
The equal linetype as supplied is just a dashed linetype that has a length of one unit and a gap of one unit. By setting its LTSCALE to the length of a pipe you can get an idea of the number of pipes involved. I have somewhere also convert an existing line to two lines as per right hand image, The GIS used to dump out a single line on a size layer so we wanted 2 dashed lines to imply existing drainage. Will try to find I think that is what you want. -
Emmanuel Delay started following A toolkit is designed to streamline the conversion of raw survey texts ,and markers into professional MLeaders
Emmanuel Delay replied to darshjalal's topic in AutoLISP, Visual LISP & DCL
Hey, that's useful. I'm keeping this one- 1 reply
- 1
L_1szt joined the community
rcarson joined the community
Barneyy joined the community
Nikon replied to SkillAmplifier's topic in AutoLISP, Visual LISP & DCL
What should be the type of line to make a line like in the picture? If you use the EQUAL line type, you get just two dashed lines. The line type "Divide" is set in the code? (setq lt "Divide") -
tarek joined the community
What 3D printer do you have? I just recalled, there used to be an APP at the Autodesk APP store, but no longer there, works on older AutoCAD, but it is also posted here at CADTutor and the Swamp. I use Bambu Labs and it comes with Bambu Studio which has a 3D Text that is very easy, I can do a custom name plate with text directly on the machine. -
SkillAmplifier replied to SkillAmplifier's topic in AutoLISP, Visual LISP & DCL
@BIGAL — the Pipe offsets approach is practical — hardcoded OD values per size as named commands (P300, P450 etc) is exactly the kind of thing that saves time on repetitive civil work. Applies the offset and switches to Divide linetype in one shot. Clean for a site-specific workflow. The Fillet offset circle reactor is a nice trick — using :vlr-unknowncommand to intercept custom prefixed strings like F100 or O234 is a different approach than what I went with. Avoids the willstart/ended pair entirely by hooking into unrecognised input instead. Here's the core VLR setup from the Pro version for comparison: (vlr-command-reactor nil '((:vlr-commandWillStart . mpla-on-cmd-willstart) (:vlr-commandEnded . mpla-on-cmd-ended) (:vlr-commandCancelled . mpla-on-cmd-cancel) (:vlr-commandFailed . mpla-on-cmd-cancel)) ) The willstart handler snapshots vertex lists and widths of all MPL masters into a global cache (*mpla-master-cache*). The ended handler diffs and rebuilds only the groups that changed. Went this route to watch standard commands passively without requiring any special input syntax. Happy to share more if useful. -
Good to know about "Gstarcad 2023" some of the other CAD programs do have little hidden issues that pop up now and then. But to Cadtutor's credit it is not a one platform forum.
Taking your example video this is convert a p/line to a drainage pipe written for civil road works, with most common AUS sizes. Needs linetype Equal the length of dashed is set to 2.4 which is a length of a concrete pipe. Handy for civil works. It is not dynamic. *EQUAL,_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ A,1.0,-1.0 Pipe offsets.lsp If you post here a VLR function can test. Fillet offset circle.lsp Have a look at "Fillet offset circle" uses reactors. -
I doubt if IT would allow that either, I have it at home so might see how that would work out. I believe Ghostscript's txtwrite is improved and should be capable as well, as noted an OCR is needed for images, Tesseract OCR — The World's Best Open Source OCR Engine. There may still be errors in the conversions. I know Adobe Acrobat has issues at times, I haven't used it in a few months though.
You have multiple locations using a redundant entget. (vlax-ename->vla-object (cdr (car (entget e1))) == (vlax-ename->vla-object e1)
Another way to get the text from a pdf is the AI option 'OCR text & table from Microsoft PC manager, normally just available in the US store. But if you have VPN or are a really good singer (Queen : Oh...yes , I'm the great pretender lalala.. applause , oh thank you , you're so kind) you should be able to get it. Open pdf , use button et voila... but its still manual labor
In fact, I haven't updated my profile: I no longer use the 2012 version but I use Gstarcad 2023 and sometimes Autocad LT 2026 (subject of the question). I apologize to all of you for not having read the new posts anymore.
Tried this out some yesterday, this will be useful for sure! The things we have to do to bypass security features that don't work. I remember in high school a few teachers would tell the kids that didn't make passing grades that the world needs ditch diggers, too. Now they probably say the world needs IT techs. Some of the things they do defy any sort of normal thought processes. I received a call last week, one of the main people that use my drawings called and stated they couldn't open drawings after IT installed a new computer. You guessed it, no AutoCAD. A normal person should see what was on the old computer that was necessary and needs to move to the new computer. At least they installed the software for the waterjet, plasma cutter, etc.
This may help you set up for checking your LISPs Graebert LISP Extension[FLISP] - ARES Commander Partner Documentation - Confluence
Thanks both for the honest feedback — exactly what I was hoping for. @pkenewell — appreciate the link, I'm aware of Lee Mac's MPLine and have a lot of respect for his work. His implementation is elegant and handles the core offset drawing well. MultiPLine goes in a different direction: DCL-based configuration dialog, per-line layer assignment, named presets that persist across drawings, and the Pro version adds a command reactor for auto-sync. Different scope rather than a direct replacement for what he built. Worth knowing about either way so thanks for flagging it. @BIGAL — fair points across the board. BricsCAD: honestly didn't design for it and can't make promises there. The reactor implementation in Pro leans on AutoCAD-specific VLR functions. Lite might load fine in BricsCAD but I haven't tested it — if any BricsCAD users try it I'd be curious to hear the result. On the "why pay" question: fair challenge. The free Lite version covers the core workflow for most users. The Pro is aimed at teams and daily-driver users who want auto-sync and a preset library they can share across a team. Whether that's worth $29 is genuinely up to the buyer — I'm not trying to oversell it. The package suggestion is actually something I've been thinking about. MultiPLine is my first commercial release but I have other tools in progress. A bundle makes more sense as a value proposition and I'll keep that in mind for when there's more to package together. One more thing — I've added the full .lsp source to the Lite download on Gumroad. Free to inspect, modify for personal use, and learn from. Thanks again for taking the time — this kind of feedback from experienced users is more useful than any marketing. Zlatislav
