SLW210 replied to HypnoS's topic in AutoLISP, Visual LISP & DCL
My code only gives that error if there are letters in the ATTRIBUTE, works no errors on the drawing you posted. Maybe you should post an actual drawing that you are using this on. Even the images you posted are different by a lot from the drawing you posted.- 30 replies
- autolisp
- block position
(and 3 more)
Tagged with:
Dynamic Block w/Rotation and Stretch
DATVO replied to Bill Tillman's topic in AutoCAD Drawing Management & Output
Is this what you're looking for ? DynBlock101_modified.dwg - Today
@devitgcode acts weird. It asks me to type distance,and when I do it places only one block and asks for distance again to pace another block, and on and on.- 30 replies
- autolisp
- block position
(and 3 more)
Tagged with:
Anyone see a routine in their travels that does this? (block numbering)
CivilTechSource replied to ILoveMadoka's topic in AutoLISP, Visual LISP & DCL
This is a good video that explains lisp and how to do autocount block -
DATVO started following Pan without losing current viewport zoom scale
DATVO replied to rcb007's topic in AutoLISP, Visual LISP & DCL
You may consider using this tool, which enables viewport panning with a customizable layer interface, retains coordinate memory, and functions even when the viewport is locked. I hope this helps you: https://lispautocad.gumroad.com/l/bgesj -
When copying layouts from one drawing to another the viewport layers change
DATVO replied to Steve Daley's topic in AutoCAD Drawing Management & Output
If your original drawing has saved Layer States, you can: - Open the original drawing. - Go to Layer Properties Manager → click Layer States Manager. - Export the layer state. - In the new drawing, import that layer state and apply it to the viewport. This preserves layer visibility, color, linetype... - Yesterday
where are experts of autocad no answer since five days
Adding data to property lookup tables
I agree with separating the constituent parts . have broken the assembly into separate dynamic blocks so that the central trusses, roof tracking , edge beams and ridge units are separate dynamics . I have run into a few issues that I have uploaded as a new thread . ive tried running the lisp above but struggling to see how I can use this to add data to the lookup tables?? -
jamami started following How to stop flip action reversing offsets in dynamic block
jamami posted a topic in AutoCAD Drawing Management & Output
I have developed the attached dynamic block which positions nested blocks according to the distance value set in a block properties table. To avoid text mirroring of the nested block labels I have used attributes and added a flip action. This all works well until I try and change the length after a flip. It appears the xpos value in the block properties table is applied as positive despite the flip state. I have tried changing the point parameters to stretch parameters but have similar problems, especially when rotating the assembly to different angles. I was hoping something as simple as adding a formulae into the block properties table ie dist*flipstate would work but there doesn't seem to be anyway to do this. Is there a way to solve this? jam3.dwg -
devitg replied to HypnoS's topic in AutoLISP, Visual LISP & DCL
@HypnoS Find attached cpy-blk-2-poly-01.lsp- 30 replies
- autolisp
- block position
(and 3 more)
Tagged with:
ILoveMadoka replied to ILoveMadoka's topic in AutoLISP, Visual LISP & DCL
Should have known.... LeeMac -
ILoveMadoka started following Anyone see a routine in their travels that does this? (block numbering)
ILoveMadoka posted a topic in AutoLISP, Visual LISP & DCL
Not sure how to even frame the question... Given a block like this: If it is inserted and is the first instance, change the text to 01, each additional insert will be numbered based upon the total number of that particular block being inserted. Can the text be text/mtext or would it have to be an attribute? I suppose it would search the block table when it is run and number additional inserts based upon the total existing in the drawing at the time of the insert. Has anyone seen such a routing/proggie that does that? If I used diesel (or other) could the numbers update automatically if one is deleted either by regen or some other trigger? Based upon their order within the blocktable? I do not even know how to search on something like this... Since I figured something would have to be written, I asked here but other forums might know of solutions.. -
Overall, Lisp works as expected. I mainly use it to draw simple cable trays. I know that creating things like T-junctions and branches will be impossible, so I'm not even asking for that. Width range we use between 50-500mm most often 100mm and 200mm.
Fillet Polylines with no Trim
SLW210 replied to Ahmed Khaled's topic in AutoCAD 2D Drafting, Object Properties & Interface
You should first ask at that thread in your link and let the author of that code amend it. -
I'll look into that, I might have posted the wrong one. I was working on one to just use the block clicked assuming a single attribute.- 30 replies
- autolisp
- block position
(and 3 more)
Tagged with:
It seems non productive to not get a FREE program to do what you need. Maybe I'll have time later today to look at them, I have these LISPs from a while back, though I may have skipped some versions. So just to make any time spent on this worthwhile, what exactly are you looking to do and what, besides the error and select elbow from dropdown, that you mentioned? What standards do you use? What size ranges do you work with? Are you doing pipe, ducts, cable trays, etc.
Lee Mac started following acet-laytrans
Use double-backslashes.
- 1 reply
- 1
tantbd44 started following Tharwat
jim78b started following acet-laytrans
hello i have problem loading acet-laytrans from scr file. (acet-laytrans "C:\Users\Utente\Dropbox\Lavoro\backup\AUTOCAD\Template\mauro\MOD.las" [1]) The specified file could not be found.; error: ADS request error why?
Weirdly for this one, I didn't check Lee Mac, I usually do. I did look at Taborder, but likely that the title blocks will be updated in the near future, tab order might change so this way was a bit future proofing (fewer later changes). Thanks for LISPs, I'll take a look at them this morning
Currently, I have to use pure CAD at work. I can't download the MEP version. We're slowly starting to implement REVIT, but it will take time.
@devitgYeh! Distance between blocks on a new straight polly. @SLW210Sorry but typing block atribute or even clicling on it seems to no work for me Enter the tag to use: ADRES ; error: bad argument type: numberp: ---- 30 replies
- autolisp
- block position
(and 3 more)
Tagged with:
Have a look at Lee-mac "page X of Y" does just that for title blocks. You can make a field that uses taborder for sheet number and count for the total of layouts., I would use these in attributes of a title block where I worked it had 25 attributes. Trying to find a shorter version. Had something the COUNT did not work in Bricscad V24. Just a second comment look here for DWGINDEX.lsp does just that makes a index of your layouts based on title block Tag names. InsertSheetofSheets.lsp Dwgindex.lsp
Ahmed Khaled replied to Ahmed Khaled's topic in AutoCAD 2D Drafting, Object Properties & Interface
in the link below https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/fillet-and-trim-just-one-entity/td-p/8885891 -
Please use Code Tags for your code in the future. (<> in the editor toolbar) Where did you find this LISP? -
Ahmed Khaled posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi all; I found this lisp below on the internet it works perfectly, but i have multiple lines i need to enter the radius for each line, so i was wondering if anyone can help me to let the lisp take the same fillet as regular fillet without asking each time and the lisp repeat it self untill pressing "ESC", Thanks in advance ; fillet with Radius, First keep, second trim (defun c:FCLL (/ *error* adoc oVAR nVAR getval e1 e2 entq p2 l l1 e er ss 1pt 2pt midpt ename param oblouk LayerName z1) ;******** (defun *error* (errmsg) (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break,end")) (princ (strcat "\nError: " errmsg))) (mapcar 'setvar nVAR oVAR) (vla-endundomark adoc) (princ)) ;;; GETVAL - returns the group value of an entity. ;;; like the wellknown (dxf) function but accepts all kinds of ;;; entity representations (ename, entget list, entsel list) (defun GETVAL (grp ele) ;"dxf value" of any ent... (cond ((= (type ele) 'ENAME) ;ENAME (cdr (assoc grp (entget ele))) ) ((not ele) nil) ;empty value ((not (listp ele)) nil) ;invalid ele ((= (type (car ele)) 'ENAME) ;entsel-list (cdr (assoc grp (entget (car ele)))) ) (T (cdr (assoc grp ele)))) ); end getval (vla-startundomark (setq adoc (vla-get-activedocument (vlax-get-acad-object)))) (setq oVAR (mapcar 'getvar (setq nVAR '(CMDECHO TRIMMODE PEDITACCEPT OSMODE)))) (mapcar 'setvar nVAR '(1 0 1 0 )) (setvar "filletrad" (cond ((getreal (strcat "\nSpecify fillet radius <" (rtos (getvar "filletrad") 2 2) ">: "))) (T (getvar "filletrad")))) (while (and (null (setq e1 (entsel "\nSelect first object (TO BE MODIFIED): "))) (wcmatch (getval 0 e1) "LINE,ARC,LWPOLYLINE"))) ;Identify the layer of the first selected entity (setq LayerName (cdr (assoc 8 (entget (car e1))))) (redraw (car e1) 3) (while (and (null (setq e2 (entsel "\nSelect second object (REMAINS THE SAME): "))) (wcmatch (getval 0 e2) "LINE,ARC,LWPOLYLINE"))) (redraw (car e2) 3) (setq p1 (cadr e1)) (setq e1 (car e1)) (if (= (getval 0 e1) "LWPOLYLINE") ;if 1nd polyline (progn (setq l (entlast)) (command "_.EXPLODE" e1) ;make it line or arc (would be trimed) (setq ss (ssadd)) (ssadd (setq e (entnext l)) ss) (while (setq e (entnext e)) (ssadd e ss)))) (if (= (getval 0 e2) "LWPOLYLINE") ;if 2st polyline (progn (setq ename (car e2) midpt (vlax-curve-getClosestPointTo ename (trans (cadr e2) 1 0)) param (vlax-curve-getParamAtPoint ename midpt) 1pt (vlax-curve-getPointAtParam ename (fix param)) 2pt (vlax-curve-getPointAtParam ename (1+ (fix param)))) (if (> (abs (- (- (vlax-curve-getDistAtPoint ename 2pt) (vlax-curve-getDistAtPoint ename 1pt)) (distance 2pt 1pt))) 0.002) (setq oblouk T)) (if oblouk (command "_.ARC" 1pt midpt 2pt) ;make it line or arc (would be keeped) (command "_.LINE" 1pt 2pt "")) (setq l2 (cons (entlast) (list (cadr e2)))))) ;if 1st line or arc (if (wcmatch (getval 0 e2) "LINE,ARC,CIRCLE") (progn (entmake (entget (car e2))) ;duplicat it (setq l2 (cons (entlast) (list (cadr e2)))))) (setvar "trimmode" 1) (command "_.FILLET" (nentselp p1) l2) ;new arc (setq er (entlast)) (command "_.CHANGE" er "" "_P" "_LAyer" LayerName "") ; change layer (entdel (car l2)) ;trim substitude of 1st erased (if ss (command "_.PEDIT" er "_J" ss "" "" ;if 2nd was pl, recreate pl "_.ERASE" ss "")) ;the rest of it (2nd side) erase (command "_.REGEN") (*error* "end") (princ) )
