lamensterms started following PDF Plot Shaded Visual Style = Sawtooth Edge
lamensterms posted a topic in AutoCAD Drawing Management & Output
Hey Got a small issue with some PDFs I am plotting on one of my ACAD PCs. I am plotting PDFs with Shaded visual style and one machine plots OK and the other has some sawtooth effect on the edges. Just wondering if anyone knows what setting or variable I can adjust to improve. It's not FACETRES, I have tried that a few times and not much improvement. it's almost as if it's JPEG compression or something. You can see image below the WORK PC has slightly better results Plot settings are the same for both machines, PC3 settings are the same for both machines -
Why does my block move to the wrong place when I insert it?
I would also like to add that users should first set UCS to World, then PLAN to World and then set BASE. -
Paul Li changed their profile photo
birdpeace23 joined the community
Dimensioning in paper space
I used to only work in model space and I would never have switched possibly if not for the new office that uses paper space templates.. I see only one advantage of this : publishing automatically all selected pages at once vs plot windows from model space. -
Back in the early 90s I had this letter size digitizer tablet by Calcomp called the WIZ. I was able to reduce the typical 12x12 AutoCAD digitizer tablet menu and map it on. Major advantages of this over the typical larger tablets being sold at the time was it's a lot smaller and light weight and cost less too. But after AutoCAD dropped support for DOS and went all out with running on Windows, Calcomp also dropped support for the WIZ and I had to give it up to go with a mouse. I actually wrote about this awhile back in an article I called "What Happened To The Digitizer?"
dcl Share the most elegant interface design under DCL limitations
Not sure if this is considered elegant but sure takes advantage of the number of image tiles that can be spread onto a giant custom dialog to preview slide files. This is a screen capture of SMV (SMVslide) which is one of the commands included in my free Script Magician App: -
I wish Autodesk would add the following features to DCL: 1) Expand and Shrink the size of custom dialog boxes 2) Floating dialog while command line is active 3) Horizontal slide bar to list box 4) Edit box that supports multiple lines of Text 5) Image tile & image button tile to support not only sld but also typical raster file types like jpg, png, bmp, dwg 6) A select file dialog box that supports dwg/txt/jpg/png/bmp file thumbnail previews 7) A multiple file selection, window style looking getfiled dialog box (which currently can be done using PowerShell)
CyberAngel replied to Discus84's topic in AutoCAD 2D Drafting, Object Properties & Interface
I've never dimensioned in paper space. Too many things to go wrong. Also dimensions are weird, it's like they wanted to please everybody but wound up disappointing everybody. -
LainiStudio3D joined the community
ymg3 started following Simplifying Polyline With Visvalingham-Whyatt Method + Zhou - Jones Effective Weight Area.
Here's another Net app to facilitate the simplification of polyline with lots of segments. I am including the code and a bat file to compile it for Autocad 2017. Once you've compiled VWSimplifyInteractive.cs into VWSimplifyInteractive.dll, Netload it into autocad. New comand VWSimplifyInteractive will now be available to trhe command line or Autolisp. If you run the command you will be asked to select a polyline. The selected poly will be copied in Magenta,then a dialog box with 3 sliders will appear to let you vary the parameter of the simplification. The polyline is simplified in real-time and you can adjust the parameters until you Accept or Cancel. Note that your original polyline remains untouched and that the simplified one is place on layer "Simplified Poly" with color Green. once you press Accept. Here's the C# code: // VWSimplifyInteractive.cs // Interactive Visvalingam + Zhou-Jones for AutoCAD 2017 using System; using System.Collections.Generic; using System.Drawing; using System.Windows.Forms; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.Geometry; using Autodesk.AutoCAD.Runtime; using AcApp = Autodesk.AutoCAD.ApplicationServices.Application; [assembly: CommandClass(typeof(VWSimplify.InteractiveCommands))] namespace VWSimplify { public class InteractiveCommands { [CommandMethod("VWSimplifyInteractive", CommandFlags.Modal | CommandFlags.Session)] public void Run() { Document doc = AcApp.DocumentManager.MdiActiveDocument; if (doc == null) return; Editor ed = doc.Editor; PromptEntityOptions peo = new PromptEntityOptions("\nSelect polyline to simplify: "); peo.SetRejectMessage("\nOnly LWPOLYLINE allowed."); peo.AddAllowedClass(typeof(Polyline), true); PromptEntityResult per = ed.GetEntity(peo); if (per.Status != PromptStatus.OK) return; ObjectId srcId = per.ObjectId; // Create and show the modeless form var form = new SimplifyForm(srcId); AcApp.ShowModelessDialog(form); } } public class SimplifyForm : Form { private ObjectId _srcId; private ObjectId _previewId = ObjectId.Null; private TrackBar tbPercent; private CheckBox chkFlat, chkSkew, chkConv; private TrackBar tbFlat, tbSkew, tbConv; private Label lblPercent, lblVertices, lblFlat, lblSkew, lblConv; private Button btnAccept, btnCancel; // Current parameters private double _percent = 15.0; private bool _useFlat = true; private bool _useSkew = false; private bool _useConv = true; private double _flatStrength = 1.5; // reasonable start private double _skewStrength = 1.0; private double _convStrength = 2.5; // reasonable start public SimplifyForm(ObjectId srcId) { _srcId = srcId; InitializeComponent(); this.Shown += SimplifyForm_Shown; } private void SimplifyForm_Shown(object sender, EventArgs e) { UpdatePreview(); // First preview once form is displayed } private void InitializeComponent() { this.Text = "VW Simplify – Interactive"; this.Size = new Size(380, 445); this.FormBorderStyle = FormBorderStyle.FixedDialog; this.MaximizeBox = false; this.StartPosition = FormStartPosition.CenterScreen; int y = 15; // Percentage lblPercent = new Label() { Left = 15, Top = y, Width = 330, Text = "Target Ratio: 15%" }; tbPercent = new TrackBar() { Left = 15, Top = y + 20, Width = 330, Minimum = 1, Maximum = 100, Value = 15, TickFrequency = 5 }; tbPercent.ValueChanged += (s, e) => { _percent = tbPercent.Value; lblPercent.Text = "Target Ratio: " + _percent + "%"; UpdatePreview(); }; y += 65; // Vertex Counter Label lblVertices = new Label() { Left = 15, Top = y, Width = 330, Text = "Vertices: Original: - | Current: - (-%)", ForeColor = Color.DarkBlue }; y += 25; // Flatness chkFlat = new CheckBox() { Left = 15, Top = y, Text = "Use Flatness weight", Checked = true, Width = 200 }; chkFlat.CheckedChanged += (s, e) => { _useFlat = chkFlat.Checked; tbFlat.Enabled = _useFlat; UpdatePreview(); }; y += 25; lblFlat = new Label() { Left = 30, Top = y, Width = 300, Text = "Flatness strength: 1.5" }; tbFlat = new TrackBar() { Left = 30, Top = y + 20, Width = 300, Minimum = 10, Maximum = 40, Value = 15, // 1.0 – 4.0 TickFrequency = 5 }; tbFlat.ValueChanged += (s, e) => { _flatStrength = tbFlat.Value / 10.0; lblFlat.Text = "Flatness strength: " + _flatStrength.ToString("0.0"); UpdatePreview(); }; y += 65; // Skewness chkSkew = new CheckBox() { Left = 15, Top = y, Text = "Use Skewness weight", Checked = false, Width = 200 }; chkSkew.CheckedChanged += (s, e) => { _useSkew = chkSkew.Checked; tbSkew.Enabled = _useSkew; UpdatePreview(); }; y += 25; lblSkew = new Label() { Left = 30, Top = y, Width = 300, Text = "Skewness strength: 1.0" }; tbSkew = new TrackBar() { Left = 30, Top = y + 20, Width = 300, Minimum = 10, Maximum = 30, Value = 10, Enabled = false }; tbSkew.ValueChanged += (s, e) => { _skewStrength = tbSkew.Value / 10.0; lblSkew.Text = "Skewness strength: " + _skewStrength.ToString("0.0"); UpdatePreview(); }; y += 65; // Convexity chkConv = new CheckBox() { Left = 15, Top = y, Text = "Use Convexity weight", Checked = true, Width = 200 }; chkConv.CheckedChanged += (s, e) => { _useConv = chkConv.Checked; tbConv.Enabled = _useConv; UpdatePreview(); }; y += 25; lblConv = new Label() { Left = 30, Top = y, Width = 300, Text = "Convexity strength: 2.5" }; tbConv = new TrackBar() { Left = 30, Top = y + 20, Width = 300, Minimum = 10, Maximum = 50, Value = 25, // 1.0 – 5.0 TickFrequency = 5 }; tbConv.ValueChanged += (s, e) => { _convStrength = tbConv.Value / 10.0; lblConv.Text = "Convexity strength: " + _convStrength.ToString("0.0"); UpdatePreview(); }; y += 70; // Buttons btnAccept = new Button() { Text = "Accept", Left = 80, Top = y, Width = 90 }; btnCancel = new Button() { Text = "Cancel", Left = 190, Top = y, Width = 90 }; btnAccept.Click += BtnAccept_Click; btnCancel.Click += BtnCancel_Click; this.Controls.AddRange(new Control[] { lblPercent, tbPercent, lblVertices, chkFlat, lblFlat, tbFlat, chkSkew, lblSkew, tbSkew, chkConv, lblConv, tbConv, btnAccept, btnCancel }); this.FormClosing += (s, e) => CleanupPreview(false); } private void UpdatePreview() { Document doc = AcApp.DocumentManager.MdiActiveDocument; if (doc == null) return; int originalCount = 0; int simplifiedCount = 0; using (DocumentLock dl = doc.LockDocument()) using (Transaction tr = doc.TransactionManager.StartTransaction()) { Polyline src = tr.GetObject(_srcId, OpenMode.ForRead) as Polyline; if (src == null) { tr.Commit(); return; } originalCount = src.NumberOfVertices; List<Point2d> simplified = Simplify(src, _percent, _useFlat, _useSkew, _useConv, _flatStrength, _skewStrength, _convStrength); if (simplified == null || simplified.Count < 2) { tr.Commit(); return; } simplifiedCount = simplified.Count; BlockTableRecord btr = (BlockTableRecord)tr.GetObject(doc.Database.CurrentSpaceId, OpenMode.ForWrite); // Erase old preview polyline if it exists if (!_previewId.IsNull && !_previewId.IsErased) { DBObject oldObj = tr.GetObject(_previewId, OpenMode.ForWrite, false); if (oldObj != null) { oldObj.Erase(); } _previewId = ObjectId.Null; } // Construct new polyline Polyline preview = new Polyline(); for (int i = 0; i < simplified.Count; i++) { preview.AddVertexAt(i, simplified[i], 0, 0, 0); } preview.Closed = src.Closed && simplified.Count >= 3; preview.ColorIndex = 6; // Magenta preview.ConstantWidth = 0; btr.AppendEntity(preview); tr.AddNewlyCreatedDBObject(preview, true); _previewId = preview.ObjectId; tr.Commit(); } // Update UI vertex stats if (originalCount > 0) { double reduction = 100.0 * (1.0 - ((double)simplifiedCount / originalCount)); lblVertices.Text = string.Format("Vertices: Original: {0} | Current: {1} ({2:0.0}% reduced)", originalCount, simplifiedCount, reduction); } AcApp.DocumentManager.MdiActiveDocument.Editor.Regen(); } private void BtnAccept_Click(object sender, EventArgs e) { Document doc = AcApp.DocumentManager.MdiActiveDocument; if (doc == null) return; using (DocumentLock dl = doc.LockDocument()) using (Transaction tr = doc.TransactionManager.StartTransaction()) { if (!_previewId.IsNull && !_previewId.IsErased) { Polyline preview = tr.GetObject(_previewId, OpenMode.ForWrite) as Polyline; if (preview != null) { // Ensure layer exists LayerTable lt = (LayerTable)tr.GetObject(doc.Database.LayerTableId, OpenMode.ForRead); ObjectId layerId; if (!lt.Has("Simplified Poly")) { lt.UpgradeOpen(); LayerTableRecord ltr = new LayerTableRecord(); ltr.Name = "Simplified Poly"; ltr.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex( Autodesk.AutoCAD.Colors.ColorMethod.ByAci, 3); // green layerId = lt.Add(ltr); tr.AddNewlyCreatedDBObject(ltr, true); } else layerId = lt["Simplified Poly"]; preview.LayerId = layerId; preview.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex( Autodesk.AutoCAD.Colors.ColorMethod.ByLayer, 256); // Add XData with parameters AddXData(preview, tr, doc.Database); _previewId = ObjectId.Null; // prevent cleanup from erasing it } } tr.Commit(); } this.Close(); } private void BtnCancel_Click(object sender, EventArgs e) { CleanupPreview(true); this.Close(); } private void CleanupPreview(bool erase) { if (_previewId.IsNull || _previewId.IsErased) return; Document doc = AcApp.DocumentManager.MdiActiveDocument; if (doc == null) return; using (DocumentLock dl = doc.LockDocument()) using (Transaction tr = doc.TransactionManager.StartTransaction()) { if (erase) { DBObject obj = tr.GetObject(_previewId, OpenMode.ForWrite, false); if (obj != null) obj.Erase(); } tr.Commit(); } _previewId = ObjectId.Null; } private void AddXData(Polyline pl, Transaction tr, Database db) { RegAppTable rat = (RegAppTable)tr.GetObject(db.RegAppTableId, OpenMode.ForRead); if (!rat.Has("VW_SIMPLIFY")) { rat.UpgradeOpen(); RegAppTableRecord reg = new RegAppTableRecord(); reg.Name = "VW_SIMPLIFY"; rat.Add(reg); tr.AddNewlyCreatedDBObject(reg, true); } ResultBuffer rb = new ResultBuffer( new TypedValue(1001, "VW_SIMPLIFY"), new TypedValue(1000, "Visvalingam-ZhouJones"), new TypedValue(1040, _percent), new TypedValue(1071, _useFlat ? 1 : 0), new TypedValue(1040, _flatStrength), new TypedValue(1071, _useSkew ? 1 : 0), new TypedValue(1040, _skewStrength), new TypedValue(1071, _useConv ? 1 : 0), new TypedValue(1040, _convStrength) ); pl.XData = rb; } //-------------------------------------------------------------------- // Simplification core with Zhou-Jones weights //-------------------------------------------------------------------- private List<Point2d> Simplify(Polyline src, double percent, bool useFlat, bool useSkew, bool useConv, double flatStr, double skewStr, double convStr) { int n = src.NumberOfVertices; if (n < 3) return null; List<Point2d> pts = new List<Point2d>(n); for (int i = 0; i < n; i++) pts.Add(src.GetPoint2dAt(i)); bool closed = src.Closed; if (closed && !pts[0].IsEqualTo(pts[pts.Count - 1], new Tolerance(1e-10, 1e-10))) pts.Add(pts[0]); int target = (int)Math.Max(2, Math.Round(n * percent / 100.0)); if (closed) target = Math.Max(target, 3); return VisvalingamZhouJones(pts, target, useFlat, useSkew, useConv, flatStr, skewStr, convStr); } private List<Point2d> VisvalingamZhouJones(List<Point2d> pts, int target, bool useFlat, bool useSkew, bool useConv, double flatStr, double skewStr, double convStr) { int n = pts.Count; if (n <= target) return new List<Point2d>(pts); Point2d[] points = pts.ToArray(); double[] areas = new double[n]; bool[] alive = new bool[n]; int[] prev = new int[n]; int[] next = new int[n]; for (int i = 0; i < n; i++) { alive[i] = true; prev[i] = i - 1; next[i] = i + 1; areas[i] = double.MaxValue; } prev[0] = -1; next[n - 1] = -1; var heap = new SortedSet<HeapItem>(); for (int i = 1; i < n - 1; i++) { double a = WeightedArea(points, i, prev, next, useFlat, useSkew, useConv, flatStr, skewStr, convStr); areas[i] = a; heap.Add(new HeapItem(a, i)); } double lastArea = 0.0; int live = n; while (heap.Count > 0 && live > target) { HeapItem item = heap.Min; heap.Remove(item); int idx = item.Index; if (!alive[idx] || Math.Abs(item.Area - areas[idx]) > 1e-12) continue; double a = Math.Max(item.Area, lastArea); lastArea = a; areas[idx] = a; alive[idx] = false; live--; int p0 = prev[idx]; int p2 = next[idx]; if (p0 >= 0) next[p0] = p2; if (p2 >= 0) prev[p2] = p0; if (p0 >= 0 && alive[p0] && prev[p0] >= 0) { double na = WeightedArea(points, p0, prev, next, useFlat, useSkew, useConv, flatStr, skewStr, convStr); if (na < lastArea) na = lastArea; areas[p0] = na; heap.Add(new HeapItem(na, p0)); } if (p2 >= 0 && alive[p2] && next[p2] >= 0) { double na = WeightedArea(points, p2, prev, next, useFlat, useSkew, useConv, flatStr, skewStr, convStr); if (na < lastArea) na = lastArea; areas[p2] = na; heap.Add(new HeapItem(na, p2)); } } List<Point2d> res = new List<Point2d>(); for (int i = 0; i < n; i++) if (alive[i]) res.Add(points[i]); return res; } private double WeightedArea(Point2d[] pts, int i, int[] prev, int[] next, bool useFlat, bool useSkew, bool useConv, double flatStr, double skewStr, double convStr) { Point2d a = pts[prev[i]]; Point2d b = pts[i]; Point2d c = pts[next[i]]; double ea = TriangleArea(a, b, c); if (ea < 1e-20) return 0.0; double wFlat = 1.0, wSkew = 1.0, wConv = 1.0; // Base length and height double baseLen = a.GetDistanceTo(c); if (baseLen < 1e-12) return ea; // Height double area2 = Math.Abs((b.X - a.X) * (c.Y - a.Y) - (b.Y - a.Y) * (c.X - a.X)); double height = area2 / baseLen; // ---- Flatness ---- if (useFlat) { double ratio = height / baseLen; wFlat = Math.Pow(Math.Max(ratio, 1e-6), flatStr); } // ---- Skewness (prefer isosceles) ---- if (useSkew) { double d1 = a.GetDistanceTo(b); double d2 = b.GetDistanceTo(c); double maxd = Math.Max(d1, d2); double mind = Math.Min(d1, d2); double skewRatio = (maxd > 1e-12) ? mind / maxd : 1.0; wSkew = Math.Pow(skewRatio, skewStr); } // ---- Convexity ---- if (useConv) { // Cross product sign to determine turn direction double cross = (b.X - a.X) * (c.Y - a.Y) - (b.Y - a.Y) * (c.X - a.X); if (cross > 0) wConv = convStr; // boost convex else wConv = 1.0; // concave stays normal } return ea * wFlat * wSkew * wConv; } private double TriangleArea(Point2d a, Point2d b, Point2d c) { return 0.5 * Math.Abs(a.X * (b.Y - c.Y) + b.X * (c.Y - a.Y) + c.X * (a.Y - b.Y)); } private class HeapItem : IComparable<HeapItem> { public double Area; public int Index; public HeapItem(double area, int index) { Area = area; Index = index; } public int CompareTo(HeapItem other) { int cmp = Area.CompareTo(other.Area); return cmp != 0 ? cmp : Index.CompareTo(other.Index); } } } } Bat file to compile for Acad 2017, From a powershell prompt issue: .\Build VWSimplifyInteractive @echo off if "%~1"=="" ( echo Error: No source file specified. echo Usage: build.bat SourceFileName exit /b 1 ) :: 1. Define Compiler and Directory Paths set CSC="C:\Windows\Microsoft.NET\Framework64\v4.0.30319\csc.exe" set NETFRAMEWORK=C:\Windows\Microsoft.NET\Framework64\v4.0.30319 set NETWPF=C:\Windows\Microsoft.NET\Framework64\v4.0.30319\WPF set ACAD=C:\Program Files\Autodesk\AutoCAD 2017 :: 2. Search Paths for /lib set LIBPATHS=/lib:"%NETFRAMEWORK%","%NETWPF%","%ACAD%" :: 3. Standard & Core .NET Assemblies set SYS_REFS=/r:System.dll /r:System.Core.dll /r:System.Data.dll /r:System.Drawing.dll /r:System.Xml.dll /r:System.Xml.Linq.dll :: 4. WPF, UI, & Windows Interop Assemblies set UI_REFS=/r:WindowsBase.dll /r:PresentationCore.dll /r:PresentationFramework.dll /r:System.Xaml.dll /r:System.Windows.Forms.dll :: 5. AutoCAD Assemblies set ACAD_REFS=/r:AcCoreMgd.dll /r:AcDbMgd.dll /r:AcMgd.dll :: 6. Optional Third-Party/Local DLLs in current folder set LOCAL_REFS= if exist "*.dll" ( set LOCAL_REFS=/lib:"%CD%" ) :: Execute Compilation %CSC% /target:library /platform:x64 /out:"%~1.dll" %LIBPATHS% %LOCAL_REFS% %SYS_REFS% %UI_REFS% %ACAD_REFS% "%~1.cs" if %ERRORLEVEL% equ 0 ( echo. echo Successfully built %~1.dll ) else ( echo. echo Compilation failed. ) VWSimplifyInteractive.cs Build.bat-
- 1
Discus84 posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi, I always annotate in model space-it complicates changes to the model as there is more objects to encapsulate in stretch frames. What is more effective - model or paperspace dimesioning -keeping annotations away from the model.? -
Why does a 3D object sometimes rotate in the wrong direction?
Have you ever selected a 3D object, used 3DROTATE, and found that it rotates around an unexpected axis? This can happen when the UCS is not aligned with the object. In 3D work, the UCS controls the direction of the X, Y, and Z axes. A simple fix is to use UCS → Face and select the face you want to work on. You can then use 3DROTATE or other 3D commands with the correct orientation. I’ve found this much easier than trying to guess which axis to rotate around. How many of you have had a 3D object rotate in the wrong direction? What was your fix? -
I'd like to be able to create this effect but specify min/max distance between lines. Any ideas appreciated. Thanks!
CyberAngel replied to indiancad's topic in AutoCAD 2D Drafting, Object Properties & Interface
Not sure how it happens, but some blocks seem to have insertion points at the origin or just some random point. Something to do with the way they were defined, I suppose. One problem is, many of these blocks define a location. They are useless if the insertion point isn't at a specific coordinate, such as the nut on a fire hydrant, which is where you typically measure from. Another problem is, if you want to locate them properly, you may not be able to redefine them with the right point and then move them all at once. A block that's been rotated, for instance, will not go where you want it to. Once again, we see what happens when you come across a problem and don't fix it as soon as possible; it just causes more problems. -
VicoWang started following Why does my block move to the wrong place when I insert it?
VicoWang replied to indiancad's topic in AutoCAD 2D Drafting, Object Properties & Interface
The origin point is set too far from the main subject, which is actually very uncomfortable. Using the Plan command to judge the entire drawing size and then going back to normal zoom can lead to confusion. The method I use to create a block is Shift+Ctrl+C, to set the origin point (usually on some object), and then use Shift+Ctrl+V to paste it as a block. I haven't encountered any problems. -
Once again I hope this was done by a coworker. The prevention of that is to properly set the base point, etc. when creating the blocks. Sometimes having the BASE set far from the block could be the correct location, depends on the block, you could be inserting it incorrectly. -
CharlieHiggs joined the community
Why can’t I join two lines even when they look connected?
imagetocad replied to indiancad's topic in AutoCAD 2D Drafting, Object Properties & Interface
One additional thing worth checking is the join tolerance. Even when two endpoints appear connected on screen, there may still be a very small gap between them. For imported or automatically generated geometry, I normally use this cleanup sequence: Use FLATTEN to make sure all objects have the same Z value. Run OVERKILL to remove duplicate or overlapping segments. Use PEDIT → Multiple → Join, with a small fuzz distance. Check any remaining endpoints with DIST or the Properties panel. I would avoid using a large fuzz distance because it may join nearby objects that should remain separate. It is also worth checking whether some objects are splines or arcs rather than lines or polylines. With geometry converted from PDFs or raster images, duplicate short segments and tiny overlaps are often the real cause rather than a clearly visible gap. -
imagetocad joined the community
Here is libreoffice code. Hopefully it is the correct one. Re display answers. The simplest is use Alert just add the "\n" in string for multi lines. Yes can do a dcl its made up of text paragraphs. And message boxes as last idea. (alert "This is line one\nline 2\nline 3") ;;;;;;;;;;;;;;;;;;;;; ; make text dcl from list ; By Alan H july 2026 (defun AHmakepara (lst / fo x dcl_id) (setq fo (open (setq fname (vl-filename-mktemp "" "" ".dcl")) "w")) (write-line "AHpara: dialog {" fo) (write-line (strcat " label = " (chr 34) "Current values" (chr 34) " ;") fo) (write-line " : column {" fo) (write-line " width =25;" fo) (write-line " : paragraph {" fo) (setq x 0) (repeat (length lst) (write-line " : text_part {" fo) (write-line (strcat "label = " (chr 34) (nth x lst) (chr 34) ";") fo) (setq x (1+ x)) (write-line " }" fo) ) (write-line " }" fo) (write-line "spacer_1 ;" fo) (write-line "ok_cancel ; }" fo) (write-line " }" fo) (close fo) (setq dcl_id (load_dialog fname)) (if (not (new_dialog "AHpara" dcl_id)) (exit) ) (action_tile "accept" "(setq ans 1)(done_dialog)") (action_tile "cancel" "(setq ans 2)(done_dialog)") (start_dialog) (unload_dialog dcl_id) (vl-file-delete fname) (princ ans) (princ) ) ; (if (not AHmakepara)(load "Multi para.lsp")) ; (setq lst (list "This is line 1 " "this is line 2" "line 3" "A big line 4 like this")) ; (AHmakepara lst) ;;;;;;;;;;;;;;;;;;;;;; ; this allows for a time so message closes. (defun MsgBox (title options message time / WshShell) (setq WshShell (vlax-create-object "WScript.Shell")) (vlax-invoke WshShell 'Run (strcat "mshta.exe vbscript:close(CreateObject(\"WScript.Shell\").Popup(\"" message "\"," (itoa time) ",\"" title "\"," (itoa options)"))" ) ) (vlax-release-object WshShell) ) (MsgBox "this is me" 0 "have a good day" 1) ; pretty sure can do multi line, using \n or \r ? libre2.lsp
One common reason is the base point of the block. If the base point was created far from the actual objects, the block can appear in an unexpected location. You can check the block with BEDIT and use BASE to set the correct insertion point. After fixing the base point, insert the block again and it should come in at the correct location. How many of you have had this problem with blocks? What was the cause in your case? -
Post that, I was working on some of that from the thread a while back, but do not remember how far I went.
I have all of that from you and @rlx, thanks though, I have a DCL built for this already, I made it a little fancy with the options, I might go simpler though. I made some improvements to the Metric side. When I have time I'll get it cleaned up and on here. I was thinking about instead of the commandline having the results in a DCL on screen and put options to make the CSV, Excel, Print, etc., though that will be when I have time. I am not sure how many actually would have use of this, but I plan to get it finished hopefully this week, hopefully I can wrap up my CAD work and get back on this. My grandkids are in a small town 268 km (167 mi) NE of Melbourne just into New South Wales and a little ways west of Lake Hume and 457 km (284 mi) SW of Sydney. I hate the time difference, but not too bad, they wake up when I'm eating supper or going to bed, they are getting ready for bed when I am getting to work.
SHa75 joined the community
@Danielm103 Interesting, so many ways to skin a cat.
all you would need to do is edit the bat file to point at the target platform. AI says you can jut create a project file next to the .cs, then use “dotnet build -c Release” <Project Sdk="Microsoft.NET.Sdk"> <PropertyGroup> <!-- Use net48 for AutoCAD 2021-2024, or net8.0-windows for AutoCAD 2025+ --> <TargetFramework>net8.0-windows</TargetFramework> <ImplicitUsings>enable</ImplicitUsings> <Nullable>enable</Nullable> <Platforms>x64</Platforms> </PropertyGroup> <!-- Reference your AutoCAD libraries --> <ItemGroup> <Reference Include="AcCoreMgd"> <HintPath>C:\Program Files\Autodesk\AutoCAD 2017\AcCoreMgd.dll</HintPath> <Private>False</Private> <!-- Prevents copying AutoCAD DLLs to your output folder --> </Reference> <Reference Include="AcDbMgd"> <HintPath>C:\Program Files\Autodesk\AutoCAD 2017\AcDbMgd.dll</HintPath> <Private>False</Private> </Reference> <Reference Include="AcMgd"> <HintPath>C:\Program Files\Autodesk\AutoCAD 2017\AcMgd.dll</HintPath> <Private>False</Private> </Reference> </ItemGroup> </Project>
Danielm103 started following KDTree as a NET application.
Nice! I used Nanoflann for the python wrappers, Ge.Point2dTree, Ge.Point3dTree https://github.com/jlblancoc/nanoflann it builds the tree multi-threaded. Nanoflann can be made dynamic in that it can add or remove points, though I didn’t add that in to the python wrappers. I also created a wrapper for AutoLISP here https://github.com/CEXT-Dan/ads_geo Wrappers are limited though, in C++ you can create a payload I.e. { Point Data } Otherwise, you have to create a hashmap to link the point with the payload. A professional C# version might use an interface for X,Y,Z, so you can expand the tree to allow any class or structure that has the proper interface
I am kind of a Green Horn when it comes to compiling. I don't even have vstudio. So I still use the legacy csc compiler. On top of that i only have access to acad 2017, so I am not aware of what would be needed to compile it for more recent version of Autocad.
Whilst I probably won't use it, have you looked at compiling for Non Acad, say Bricscad a lot of users here.
Yes outputting results as both may be the simplest way. Re make a dcl, I use say multi radio buttons.lsp as it only needs 3 lines of code to work, you comment out the vla-deletefile, so the dcl code remains, I then use the RLX convert dcl to lisp so paste the converted code into my programs, using the multi just saves typing to make the source dcl. Just another comment, I have a make a radio button dcl from a dwg. RLX was looking into doing similar. I have code also for Libreoffice Calc reading and writing plus more. Happy to post. Opening is not as straight forward as Excel. Where are the grand kids ? I am north of Sydney. Convert dcl 2 lisp rlx.lsp
