Been playing quite a bit with Gilles Chanteau's kdtree lisp app published at theSwamp kd-tree (AutoLISP).
So decided to turn it into a dll to use from autolisp.  I am attaching the C# code below and a bat file to compile
it for Autocad 2017.
The dll will create the following function for autolisp:
KDtreeLisp.dll   Reference & Command
SyntaxIn AutoLISP documentation standards, optional parameters are enclosed in square brackets [optional].
   (KD-BUILD pointList [dimensions] [customHandle])
      Builds a KD-Tree spatial index from a list of points.
   Arguments:
      pointList: LIST — List of 2D or 3D point lists ((x y z) ...).
      dimensions (optional): INT — 2 for 2D $(X,Y)$ or 3 for 3D $(X,Y,Z)$. Default is 2.
      customHandle (optional): STR — Custom string handle identifier.
   Returns: STR handle (e.g., "<KD-TREE-1>" or "<KD-TREE-SURVEY>"), or nil on failure.
   (KD-NEAREST handle targetPoint [count] [maxRadius])
      Finds the nearest n points to a target point.
   Arguments:
      handle: STR — KD-Tree handle string.
      targetPoint: LIST — Target point (x y z).
      count (optional): INT — Number of nearest points to retrieve. Default is 1.
      maxRadius (optional): REAL or INT — Maximum search radius limit. Points farther
                                          than this distance are ignored.
   Returns:If count = 1 (or omitted): A single point (x y z).
           If count > 1: A list of points ((x1 y1 z1) (x2 y2 z2) ...).
   (KD-NEAREST-INFO handle targetPoint [count] [maxRadius])
      Finds nearest points with detailed metadata.
   Arguments:
      count (optional): INT — Number of points to retrieve. Default is 1.
   Returns:
      A list of detailed entries (((x y z) index distance) ...).
   (KD-RANGE handle centerPoint radius)
      Finds all points inside a fixed search radius without a count limit.
   Arguments:
      centerPoint: LIST — Center search coordinate (x y z).
      radius: REAL or INT — Search radius.
   Returns:
      A list of all enclosed points ((x1 y1 z1) (x2 y2 z2) ...) sorted by distance,
      or nil if none are found.
   (KD-FREE [handle])
      Frees tree memory.
   Arguments:
      handle (optional): STR — Tree handle to free. If omitted, clears all active trees.
   Returns: INT — Number of trees removed.
Once you've compiled the C#, kdtreelisp.dll will be created and ready to use in Autocad.
using System;
using System.Collections.Generic;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
namespace KdTreeLisp
    // 1. DATA STRUCTURES & TREE ENGINE
    public class KdItem
        public Point3d Point { get; set; }
        public int Id { get; set; }
        public KdItem(Point3d pt, int id)
            Point = pt;
            Id = id;
    public class KdNode
        public KdNode Left { get; set; }
        public KdNode Right { get; set; }
        public KdNode(Point3d point, int id)
            Point = point;
            Id = id;
    public class NeighborResult : IComparable<NeighborResult>
        public KdNode Node { get; set; }
        public double DistanceSq { get; set; }
        public NeighborResult(KdNode node, double distSq)
            Node = node;
            DistanceSq = distSq;
        public int CompareTo(NeighborResult other)
            return other.DistanceSq.CompareTo(this.DistanceSq);
    public class KdTree
        public KdNode Root { get; private set; }
        public int ActiveDimensions { get; private set; }
        public void Build(List<KdItem> items, int activeDimensions)
            ActiveDimensions = Math.Max(1, Math.Min(3, activeDimensions));
            Root = BuildRecursive(items, 0);
        private KdNode BuildRecursive(List<KdItem> items, int depth)
            if (items == null || items.Count == 0) return null;
            int axis = depth % ActiveDimensions;
            items.Sort(delegate(KdItem a, KdItem b)
                return GetAxisValue(a.Point, axis).CompareTo(GetAxisValue(b.Point, axis));
            int medianIndex = items.Count / 2;
            KdNode node = new KdNode(items[medianIndex].Point, items[medianIndex].Id);
            node.Left = BuildRecursive(items.GetRange(0, medianIndex), depth + 1);
            node.Right = BuildRecursive(items.GetRange(medianIndex + 1, items.Count - (medianIndex + 1)), depth + 1);
            return node;
        public double CalculateDistanceSq(Point3d p1, Point3d p2)
            double dx = p1.X - p2.X;
            double dy = p1.Y - p2.Y;
            if (ActiveDimensions == 2)
                return dx * dx + dy * dy;
            double dz = p1.Z - p2.Z;
            return dx * dx + dy * dy + dz * dz;
        // K-Nearest Neighbor Search with Optional Maximum Radius Limit
        public List<NeighborResult> FindNearest(Point3d target, int count, double maxRadius = double.MaxValue)
            List<NeighborResult> heap = new List<NeighborResult>();
            if (Root == null || count <= 0) return heap;
            double maxDistSq = (maxRadius == double.MaxValue) ? double.MaxValue : maxRadius * maxRadius;
            SearchNearest(Root, target, count, maxDistSq, heap, 0);
            // Sort ascending by distance before returning
            heap.Sort(delegate(NeighborResult a, NeighborResult b)
                return a.DistanceSq.CompareTo(b.DistanceSq);
            return heap;
        private void SearchNearest(KdNode current, Point3d target, int count, double maxDistSq, List<NeighborResult> heap, int depth)
            if (current == null) return;
            double distSq = CalculateDistanceSq(current.Point, target);
            // Accept point only if inside maximum distance threshold
            if (distSq <= maxDistSq)
                if (heap.Count < count)
                    heap.Add(new NeighborResult(current, distSq));
                    heap.Sort();
                else if (distSq < heap[0].DistanceSq)
                    heap[0] = new NeighborResult(current, distSq);
                    heap.Sort();
            double diff = GetAxisValue(target, axis) - GetAxisValue(current.Point, axis);
            KdNode primary = diff < 0 ? current.Left : current.Right;
            KdNode secondary = diff < 0 ? current.Right : current.Left;
            SearchNearest(primary, target, count, maxDistSq, heap, depth + 1);
            // Pruning condition: check if secondary subtree could contain points closer than current worst candidate
            double currentSearchRadiusSq = (heap.Count < count) ? maxDistSq : Math.Min(heap[0].DistanceSq, maxDistSq);
            if (diff * diff < currentSearchRadiusSq)
                SearchNearest(secondary, target, count, maxDistSq, heap, depth + 1);
        // Range Search: Retrieves ALL points within radius
        public List<NeighborResult> RangeSearch(Point3d center, double radius)
            List<NeighborResult> results = new List<NeighborResult>();
            if (Root == null || radius < 0) return results;
            double radiusSq = radius * radius;
            SearchRangeRecursive(Root, center, radiusSq, results, 0);
            results.Sort(delegate(NeighborResult a, NeighborResult b)
            return results;
        private void SearchRangeRecursive(KdNode current, Point3d center, double radiusSq, List<NeighborResult> results, int depth)
            double distSq = CalculateDistanceSq(current.Point, center);
            if (distSq <= radiusSq)
                results.Add(new NeighborResult(current, distSq));
            double diff = GetAxisValue(center, axis) - GetAxisValue(current.Point, axis);
            if (diff < 0)
                SearchRangeRecursive(current.Left, center, radiusSq, results, depth + 1);
                if (diff * diff <= radiusSq)
                    SearchRangeRecursive(current.Right, center, radiusSq, results, depth + 1);
            else
        private double GetAxisValue(Point3d pt, int axis)
            switch (axis)
                case 0: return pt.X;
                case 1: return pt.Y;
                default: return pt.Z;
    // 2. AUTOLISP INTERFACE BRIDGE
    public class LispBridge
        private static readonly Dictionary<string, KdTree> _trees = new Dictionary<string, KdTree>();
        private static int _treeCounter = 1;
        // Signature: (KD-BUILD pointList [dimensions] [customHandle])
        [LispFunction("KD-BUILD")]
        public static TypedValue BuildTree(ResultBuffer args)
            if (args == null) return new TypedValue((int)LispDataType.Nil);
            TypedValue[] arr = args.AsArray();
            List<KdItem> items = new List<KdItem>();
            int idCounter = 0;
            int requestedDimensions = 2;
            string customHandle = null;
            foreach (TypedValue tv in arr)
                if (tv.TypeCode == (int)LispDataType.Point3d)
                    items.Add(new KdItem((Point3d)tv.Value, idCounter++));
                else if (tv.TypeCode == (int)LispDataType.Point2d)
                    Point2d pt2 = (Point2d)tv.Value;
                    items.Add(new KdItem(new Point3d(pt2.X, pt2.Y, 0.0), idCounter++));
                else if (tv.TypeCode == (int)LispDataType.Int16 || tv.TypeCode == (int)LispDataType.Int32)
                    requestedDimensions = Convert.ToInt32(tv.Value);
                else if (tv.TypeCode == (int)LispDataType.Text)
                    customHandle = Convert.ToString(tv.Value);
            if (items.Count == 0) return new TypedValue((int)LispDataType.Nil);
            KdTree tree = new KdTree();
            tree.Build(items, requestedDimensions);
            string handle = string.IsNullOrEmpty(customHandle)
                ? string.Format("<KD-TREE-{0}>", _treeCounter++)
                : string.Format("<KD-TREE-{0}>", customHandle.ToUpper());
            _trees[handle] = tree;
            return new TypedValue((int)LispDataType.Text, handle);
        // Signature: (KD-NEAREST handle targetPoint [count] [maxRadius])
        [LispFunction("KD-NEAREST")]
        public static ResultBuffer FindNearest(ResultBuffer args)
            if (args == null) return null;
            List<TypedValue> values = ExtractValues(args);
            if (values.Count < 2) return null;
            if (values[0].TypeCode != (int)LispDataType.Text) return null;
            string handle = Convert.ToString(values[0].Value);
            if (!_trees.ContainsKey(handle)) return null;
            KdTree tree = _trees[handle];
            if (tree.Root == null) return null;
            Point3d target;
            if (values[1].TypeCode == (int)LispDataType.Point3d)
                target = (Point3d)values[1].Value;
            else if (values[1].TypeCode == (int)LispDataType.Point2d)
                Point2d p2 = (Point2d)values[1].Value;
                target = new Point3d(p2.X, p2.Y, 0.0);
            else
                return null;
            int count = 1;
            if (values.Count > 2 && (values[2].TypeCode == (int)LispDataType.Int16 || values[2].TypeCode == (int)LispDataType.Int32))
                count = Convert.ToInt32(values[2].Value);
            double maxRadius = double.MaxValue;
            if (values.Count > 3)
                TypedValue v = values[3];
                if (v.TypeCode == (int)LispDataType.Double || v.TypeCode == (int)LispDataType.Int16 || v.TypeCode == (int)LispDataType.Int32)
                    maxRadius = Convert.ToDouble(v.Value);
            List<NeighborResult> results = tree.FindNearest(target, count, maxRadius);
            if (results.Count == 0) return null;
            ResultBuffer res = new ResultBuffer();
            if (count == 1)
                res.Add(new TypedValue((int)LispDataType.Point3d, results[0].Node.Point));
            else
                res.Add(new TypedValue((int)LispDataType.ListBegin));
                foreach (NeighborResult item in results)
                    res.Add(new TypedValue((int)LispDataType.Point3d, item.Node.Point));
                res.Add(new TypedValue((int)LispDataType.ListEnd));
            return res;
        // Signature: (KD-NEAREST-INFO handle targetPoint [count] [maxRadius])
        [LispFunction("KD-NEAREST-INFO")]
        public static ResultBuffer FindNearestInfo(ResultBuffer args)
            Point3d target;
                target = new Point3d(((Point2d)values[1].Value).X, ((Point2d)values[1].Value).Y, 0.0);
            else
                return null;
            int count = 1;
                res.Add(new TypedValue((int)LispDataType.Int32, item.Node.Id));
                res.Add(new TypedValue((int)LispDataType.Double, Math.Sqrt(item.DistanceSq)));
            return res;
        // Signature: (KD-RANGE handle centerPoint radius)
        [LispFunction("KD-RANGE")]
        public static ResultBuffer RangeSearch(ResultBuffer args)
            if (values.Count < 3) return null;
            Point3d center;
                center = (Point3d)values[1].Value;
                center = new Point3d(((Point2d)values[1].Value).X, ((Point2d)values[1].Value).Y, 0.0);
            else
                return null;
            double radius = 0.0;
            TypedValue rVal = values[2];
            if (rVal.TypeCode == (int)LispDataType.Double || rVal.TypeCode == (int)LispDataType.Int16 || rVal.TypeCode == (int)LispDataType.Int32)
                radius = Convert.ToDouble(rVal.Value);
            else
                return null;
            List<NeighborResult> results = tree.RangeSearch(center, radius);
            return res;
        // Signature: (KD-FREE [handle])
        [LispFunction("KD-FREE")]
        public static TypedValue FreeTree(ResultBuffer args)
            if (args == null)
                int count = _trees.Count;
                _trees.Clear();
                return new TypedValue((int)LispDataType.Int32, count);
            if (values.Count == 0 || values[0].TypeCode != (int)LispDataType.Text)
                _trees.Clear();
            bool removed = _trees.Remove(handle);
            return new TypedValue((int)LispDataType.Int32, removed ? 1 : 0);
        private static List<TypedValue> ExtractValues(ResultBuffer resbuf)
            List<TypedValue> list = new List<TypedValue>();
            foreach (TypedValue tv in resbuf.AsArray())
                if (tv.TypeCode != (int)LispDataType.ListBegin &&
                    tv.TypeCode != (int)LispDataType.ListEnd)
                    list.Add(tv);
            return list;
ymg
KDtreeLisp.cs Build.bat
  • Like 2
Whilst I probably won't use it, have you looked at compiling for Non Acad, say Bricscad a lot of users here.
I am kind of a Green Horn when it comes to compiling.  I don't even have vstudio.  So I still use the legacy csc compiler.  On top of that i only have access to acad 2017, so I am not aware of what would be needed to compile it for more recent version of Autocad.
  • Agree 1
Nice! I used Nanoflann for the python wrappers, Ge.Point2dTree, Ge.Point3dTree https://github.com/jlblancoc/nanoflann
it builds the tree multi-threaded. Nanoflann can be made dynamic in that it can add or remove points, though I didn’t add that in to the python wrappers.
I also created a wrapper for AutoLISP here https://github.com/CEXT-Dan/ads_geo
Wrappers are limited though, in C++ you can create a payload I.e.
                Point
                Data
Otherwise, you have to create a hashmap to link the point with the payload.
A professional C# version might use an interface for X,Y,Z, so you can expand the tree to allow any class or structure that has the proper interface
Edited by Danielm103
all you would need to do is edit the bat file to point at the target platform.
AI says you can jut create a project file next to the .cs, then use “dotnet build -c Release”
<Project Sdk="Microsoft.NET.Sdk">
  <PropertyGroup>
    <!-- Use net48 for AutoCAD 2021-2024, or net8.0-windows for AutoCAD 2025+ -->
    <TargetFramework>net8.0-windows</TargetFramework>
    <ImplicitUsings>enable</ImplicitUsings>
    <Nullable>enable</Nullable>
    <Platforms>x64</Platforms>
  </PropertyGroup>
  <!-- Reference your AutoCAD libraries -->
  <ItemGroup>
    <Reference Include="AcCoreMgd">
      <HintPath>C:\Program Files\Autodesk\AutoCAD 2017\AcCoreMgd.dll</HintPath>
      <Private>False</Private> <!-- Prevents copying AutoCAD DLLs to your output folder -->
    </Reference>
    <Reference Include="AcDbMgd">
      <HintPath>C:\Program Files\Autodesk\AutoCAD 2017\AcDbMgd.dll</HintPath>
    </Reference>
    <Reference Include="AcMgd">
      <HintPath>C:\Program Files\Autodesk\AutoCAD 2017\AcMgd.dll</HintPath>
    </Reference>
  </ItemGroup>
</Project>
  • Like 2
Hi,
The GeometryExtensions.NET library provides a generic KdTree<T> class which uses parallel computation for building the tree.
It also provides an example of Point3dTree class but can used with any type of object providing a 'getPosition' function.
// public KdTree(IEnumerable<T> source, Func<T, Point3d>?getPosition, int dimension)
var tree = new KdTree<BlockReference>(blockList, br => br.Position, 2);
Edited by gile
  • Like 2
@gile,
Quote
Did not know that.  At least I learned something while doing mine.
I've look at the extension and there are many interesting things in there.
Edited by ymg3
@gile,
Here I build a bridge to your GeometryExtensions.NET library, exposing essentially the same command that I had in mine .
The only addition being GC:KD-MINNODE.
I have also built a concavehull in C# using your kd-tree if anybody is interested.
ymg
using System;
using System.IO;
using System.Linq;
using System.Globalization;
using Autodesk.AutoCAD.ApplicationServices;
using Gile.AutoCAD.R20.Geometry;
namespace LispGileBridge
   public class ExtensionLoader : IExtensionApplication
      public void Initialize()
         try
            var ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
            // Extracts the absolute running file path dynamically via Reflection
            string assemblyPath = System.Reflection.Assembly.GetExecutingAssembly().Location;
            string assemblyName = System.IO.Path.GetFileName(assemblyPath);
            ed.WriteMessage($"\n--> Assembly File Loaded: \"{assemblyName}\"");
            ed.WriteMessage($"\n--> Full Path: {assemblyPath}");
            ed.WriteMessage("\n--> Available commands:");
            ed.WriteMessage("\n       (GC:KD-BUILD pointList [dimensions] [customHandle])");
            ed.WriteMessage("\n       (GC:KD-NEAREST handle Point [count] [maxRadius] [sortFlag])");
            ed.WriteMessage("\n       (GC:KD-NEAREST-INFO handle Point [count] [maxRadius])");
            ed.WriteMessage("\n       (GC:KD-RANGE handle Point radius)");
            ed.WriteMessage("\n       (GC:KD-MINNODE handle dimension)");
            ed.WriteMessage("\n       (GC:KD-FREE [handle])");
         catch
            // Fallback safety silent escape check
      public void Terminate()
   public class KdTreeBridge
      // Thread-safe dictionary tracking string handles to their specific tree instances and properties
      private static readonly Dictionary<string, (Point3dTree Tree, bool Is2D)> _registry =
      new Dictionary<string, (Point3dTree, bool)>(StringComparer.OrdinalIgnoreCase);
      private static int _autoId = 1;
      // 1. (gc:kd-build pointList [dimensions] [customHandle])
      [LispFunction("GC:KD-BUILD")]
      public static object GileKdBuild(ResultBuffer args)
         if (arr.Length == 0) return null;
         try
            List<Point3d> pts = ParseLispPoints(arr, 0, out int pointsReadCount);
            if (pts.Count == 0) return null;
            // Default dimension to 2D unless explicitly specified as 3
            int dimensions = 2;
            if (arr.Length > pointsReadCount)
               int nextIdx = pointsReadCount;
               if (arr[nextIdx].TypeCode == (int)LispDataType.Int32 || arr[nextIdx].TypeCode == (int)LispDataType.Int16)
                  dimensions = Convert.ToInt32(arr[nextIdx].Value);
                  nextIdx++;
               if (arr.Length > nextIdx && arr[nextIdx].TypeCode == (int)LispDataType.Text)
                  customHandle = Convert.ToString(arr[nextIdx].Value);
            bool is2D = (dimensions == 2);
            // Gilles' constructor: ignoreZ parameter directly matches our is2D rule
            Point3dTree tree = new Point3dTree(pts, is2D);
            string handle = string.IsNullOrEmpty(customHandle) ? $"<KD-TREE-{_autoId++}>" : customHandle;
            _registry[handle] = (tree, is2D);
            return handle;
         catch (System.Exception ex)
            Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage($"\nError in KD-BUILD: {ex.Message}\n");
            return null;
      // 2. (gc:kd-nearest handle targetPoint [count] [maxRadius] [sortFlag])
      [LispFunction("GC:KD-NEAREST")]
      public static object GileKdNearest(ResultBuffer args)
         if (arr.Length < 2) return null;
         try
            string handle = Convert.ToString(arr[0].Value);
            if (!_registry.TryGetValue(handle, out var entry)) return null;
            if (arr[1].TypeCode != (int)LispDataType.Point3d) return null;
            Point3d targetPt = (Point3d)arr[1].Value;
            int count = 1;
            int sortFlag = 1; // Default: Sort by Angle
            if (arr.Length >= 3) count = Convert.ToInt32(arr[2].Value);
            if (arr.Length >= 4) maxRadius = Convert.ToDouble(arr[3].Value);
            if (arr.Length >= 5) sortFlag = Convert.ToInt32(arr[4].Value);
            var searchCollection = entry.Tree.GetNearestNeighbours(targetPt, count);
            if (searchCollection == null) return null;
            // Filter by radius limit and compile working list
            List<Point3d> filtered = new List<Point3d>();
            foreach (Point3d pt in searchCollection)
               double dist = entry.Is2D ? targetPt.DistanceTo(new Point3d(pt.X, pt.Y, targetPt.Z)) : targetPt.DistanceTo(pt);
               if (dist <= maxRadius) filtered.Add(pt);
            if (filtered.Count == 0) return null;
            // Execute selected Sort mode
            if (sortFlag == 0)
               filtered = filtered.OrderBy(p => entry.Is2D ? targetPt.DistanceTo(new Point3d(p.X, p.Y, targetPt.Z)) : targetPt.DistanceTo(p)).ToList();
            else
               filtered = filtered.OrderBy(p => {
                  double angle = Math.Atan2(p.Y - targetPt.Y, p.X - targetPt.X);
                  return angle < 0 ? angle + (2 * Math.PI) : angle;
               }).ToList();
            // API Standard Rule Check: If count is 1, return single item. Else, return list.
            if (count == 1)
               return filtered[0];
            ResultBuffer rb = new ResultBuffer();
            rb.Add(new TypedValue((int)LispDataType.ListBegin));
            foreach (Point3d pt in filtered) rb.Add(new TypedValue((int)LispDataType.Point3d, pt));
            rb.Add(new TypedValue((int)LispDataType.ListEnd));
            return rb;
         catch { return null; }
      // 3. (gc:kd-nearest-info handle targetPoint [count] [maxRadius])
      [LispFunction("GC:KD-NEAREST-INFO")]
      public static object GileKdNearestInfo(ResultBuffer args)
         try
            int count = 1;
            // Re-locate matches to extract array index mappings cleanly
            int idx = 0;
                  rb.Add(new TypedValue((int)LispDataType.Int32, idx)); // Metadata index placement
                  rb.Add(new TypedValue((int)LispDataType.Double, dist));
               idx++;
            return rb;
      // 4. (gc:kd-range handle centerPoint radius)
      [LispFunction("GC:KD_RANGE")]
      public static object GileKdRange(ResultBuffer args)
         if (arr.Length < 3) return null;
         try
            Point3d centerPt = (Point3d)arr[1].Value;
            double radius = Convert.ToDouble(arr[2].Value);
            // Passing a double directly to GetNearestNeighbours switches Gilles' engine to range search
            var searchCollection = entry.Tree.GetNearestNeighbours(centerPt, radius);
            // Enforce distance sort ordering
            var sorted = searchCollection.OrderBy(p => entry.Is2D ? centerPt.DistanceTo(new Point3d(p.X, p.Y, centerPt.Z)) : centerPt.DistanceTo(p)).ToList();
            foreach (Point3d pt in sorted) rb.Add(new TypedValue((int)LispDataType.Point3d, pt));
            return rb;
      // 5. NEW! (gc:kd-minnode handle dimension) -> Useful for Concave Hull base logic
      [LispFunction("GC:KD-MINNODE")]
      public static object GileKdMinNode(ResultBuffer args)
         try
            int dimension = Convert.ToInt32(arr[1].Value); // 0=X, 1=Y, 2=Z
            // Target standard range query over all nodes to run aggregate matching
            var allPoints = entry.Tree.GetNearestNeighbours(Point3d.Origin, double.MaxValue);
            if (allPoints == null || !allPoints.Any()) return null;
            Point3d minPoint;
            switch (dimension)
            case 0: // Minimum X coordinate
               minPoint = allPoints.OrderBy(p => p.X).First();
               break;
            case 1: // Minimum Y coordinate
               minPoint = allPoints.OrderBy(p => p.Y).First();
               break;
            case 2: // Minimum Z coordinate
               minPoint = allPoints.OrderBy(p => p.Z).First();
               break;
            default:
               return null;
            return minPoint;
      // 6. (gc:kd-free [handle])
      [LispFunction("GC:KD-FREE")]
      public static object GileKdFree(ResultBuffer args)
         int removedCount = 0;
         if (args == null)
            removedCount = _registry.Count;
            _registry.Clear();
            _autoId = 1;
         else
            if (arr.Length > 0 && arr[0].TypeCode == (int)LispDataType.Text)
               if (_registry.Remove(handle)) removedCount = 1;
            else
               _registry.Clear();
               _autoId = 1;
         GC.Collect();
         GC.WaitForPendingFinalizers();
         return removedCount;
      // INTERNAL ROUTINE: Streamlined input coordinate list extractor
      private static List<Point3d> ParseLispPoints(TypedValue[] arr, int startIndex, out int readCount)
         var collected = new List<Point3d>();
         readCount = 0;
         for (int i = startIndex; i < arr.Length; i++)
            if (arr[i].Value is Point3d pt)
               collected.Add(pt);
               readCount++;
            else if (arr[i].TypeCode == (int)LispDataType.ListEnd || arr[i].TypeCode == (int)LispDataType.Int32 || arr[i].TypeCode == (int)LispDataType.Text)
               break; // Stopped at non-point parameter boundaries
         return collected;
essentially the same command that I had in my post.
  • Thanks 1
@Danielm103,
I did build gile's code to autocad 2017 and ran it  testmore.dwg
Results for  PLWT_KDTREE:
--------- TIMING-------------------------------
Collecting entities:      315 milliseconds
Building kdTree:          69 milliseconds
Pairing lines and texts:  28 milliseconds
Coloring lines and texts: 121 milliseconds
Total Elapsed Time:       533 milliseconds
Total Number of Colors:   102 colors
With that kind of results, I don't see what I could improve on here.
I am attaching the cs file converted for acad 2017 and Gile.AutoCAD.R20.Geometry
ymg
pairs.cs
Edited by ymg3
Added the intermediate timing.
@Danielm103
Well I did managed to scrape some milliseconds. However not where it counts in the pairing.
Most of the gain in collection of entities.
So in the end it is still gile's code.
ymg
Command: PAIRKD
--------- TIMING -------------------------------
Collecting entities:      236 milliseconds
Building kdTree:          67 milliseconds
Pairing lines and texts:  34 milliseconds
Coloring lines and texts: 123 milliseconds
Total Elapsed Time:       460 milliseconds
Total Number of Groups:   102
using System;
using System.Diagnostics;
using System.Linq;
using System.Threading.Tasks;
using Autodesk.AutoCAD.EditorInput;
using AcAp = Autodesk.AutoCAD.ApplicationServices.Core.Application;
[assembly: CommandClass(typeof(PairLinesWithTextsR17.Commands))]
namespace PairLinesWithTextsR17
    public class Commands
        private struct EntityPosition
            public Entity Entity { get; }
            public Point3d Position { get; }
            public EntityPosition(Entity entity, Point3d position)
                Entity = entity;
                Position = position;
        [CommandMethod("PAIRKD")]
        public void ParallelPairTextsWithLines3()
            // Force GC collection prior to timing to avoid GC halts during execution
            GC.Collect();
            Stopwatch stopwatch = Stopwatch.StartNew();
            Document doc = AcAp.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            RXClass lineClass = RXObject.GetClass(typeof(Line));
            RXClass textClass = RXObject.GetClass(typeof(DBText));
            // Pre-allocate generous capacity to prevent memory reallocations
            List<EntityPosition> midLines = new List<EntityPosition>(16384);
            List<EntityPosition> textList = new List<EntityPosition>(16384);
            using (doc.LockDocument())
            using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
                LayerTable lt = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead);
                ObjectId lineLayerId = lt.Has("1") ? lt["1"] : ObjectId.Null;
                ObjectId textLayerId = lt.Has("4") ? lt["4"] : ObjectId.Null;
                BlockTableRecord modelSpace = (BlockTableRecord)tr.GetObject(
                    SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead);
                // 1. Fast Collection Phase
                foreach (ObjectId id in modelSpace)
                    RXClass rxClass = id.ObjectClass;
                    if (rxClass == lineClass)
                        Line line = (Line)tr.GetObject(id, OpenMode.ForRead);
                        if (line.LayerId == lineLayerId)
                            Point3d midPoint = new Point3d(
                                (line.StartPoint.X + line.EndPoint.X) * 0.5,
                                (line.StartPoint.Y + line.EndPoint.Y) * 0.5,
                                (line.StartPoint.Z + line.EndPoint.Z) * 0.5
                            midLines.Add(new EntityPosition(line, midPoint));
                    else if (rxClass == textClass)
                        DBText text = (DBText)tr.GetObject(id, OpenMode.ForRead);
                        if (text.LayerId == textLayerId)
                            Point3d pos = (text.Justify == AttachmentPoint.BaseLeft) ? text.Position : text.AlignmentPoint;
                            textList.Add(new EntityPosition(text, pos));
                EntityPosition[][] textGroups = textList
                    .GroupBy(t => ((DBText)t.Entity).TextString)
                    .Select(g => g.ToArray())
                    .ToArray();
                long t1 = stopwatch.ElapsedMilliseconds;
                // 2. KdTree Construction
                KdTree<EntityPosition> lineTree = new KdTree<EntityPosition>(midLines, ml => ml.Position, 2);
                long t2 = stopwatch.ElapsedMilliseconds;
                // 3. Parallel pairing (Math + Spatial Search)
                int numGroups = textGroups.Length;
                HashSet<Entity>[] uniqueGroupEntities = new HashSet<Entity>[numGroups];
                Parallel.For(0, numGroups, i =>
                    EntityPosition[] group = textGroups[i];
                    HashSet<Entity> uniqueSet = new HashSet<Entity>(group.Length * 2);
                    for (int j = 0; j < group.Length; j++)
                        EntityPosition textItem = group[j];
                        uniqueSet.Add(textItem.Entity);
                        Entity nearestLine = lineTree.GetNearestNeighbour(textItem.Position).Entity;
                        uniqueSet.Add(nearestLine);
                    uniqueGroupEntities[i] = uniqueSet;
                long t3 = stopwatch.ElapsedMilliseconds;
                // 4. Sequential Database Modification Phase
                for (int i = 0; i < numGroups; i++)
                    int colorIndex = (i % 255) + 1;
                    HashSet<Entity> uniqueSet = uniqueGroupEntities[i];
                    foreach (Entity entity in uniqueSet)
                        if (entity.ColorIndex != colorIndex)
                            if (!entity.IsWriteEnabled)
                                entity.UpgradeOpen();
                            entity.ColorIndex = colorIndex;
                long t4 = stopwatch.ElapsedMilliseconds;
                stopwatch.Stop();
                ed.WriteMessage($"\n--------- TIMING -------------------------------");
                ed.WriteMessage($"\nCollecting entities:      {t1} milliseconds");
                ed.WriteMessage($"\nBuilding kdTree:          {t2 - t1} milliseconds");
                ed.WriteMessage($"\nPairing lines and texts:  {t3 - t2} milliseconds");
                ed.WriteMessage($"\nColoring lines and texts: {t4 - t3} milliseconds\n");
                ed.WriteMessage($"\nTotal Elapsed Time:       {t4} milliseconds");
                ed.WriteMessage($"\nTotal Number of Groups:   {numGroups}");
                tr.Commit();
pairkd.dll
Edited by ymg3
  • Thanks 2
Well done, nice use of Parallel.For! Kdtree’s are definitely a must have in the CAD programmer’s tool box.
  • Agree 1
