lrm started following Hybrid parallel
Here's a simpe solution that doesn't use LISP. Change the elevation of one of the polylines to 1.0 then use the loft command to create asurface. Section the resulting surface with an XY plane at 0,0,0.5.
Copy and paste error (blocks changes!)
rlx replied to X11start's topic in AutoLISP, Visual LISP & DCL
I'm a little confused , you say the first lisp gives a warning about duplicate block names in the second drawing and that's also dbx , so maybe its the renaming part that uses commands not supported by GStarCad? -
GLAVCVS replied to X11start's topic in AutoLISP, Visual LISP & DCL
If you have a debugger (for GStarCAD, VS Code I suppose), the ideal would be to put a breakpoint in the code at the end of this line: "(setq acApp (vlax-get-acad-object) acDoc (vla-get-ActiveDocument acApp))" and this: "(setq dbx (vl-catch-all-apply 'vla-getinterfaceobject (list acApp (dbx_ver))))" And then run it again If the code runs up to the first breakpoint and then continues execution and doesn't stop again at the next breakpoint because the error occurs first, the problem is access to DBX -
Then it is possible that your version of GStarCAD does not have access to DBX from Lisp. - Today
like i said its not really the avg per say because its missing data points. should probably use the larger/longer poly to pull points from (or maybe both and avg it out). The blue line is suffering from not enough detail since its only calculating off the vertex. i can't test right now but see if the selecting order changes anything. Also change the following and should get a better path. tho it will create a poly with 10x the vertex of selected one. (setq i (+ i 0.1))
Objects move away from Basepoint with Move Parameter (and they shouldn't)
CyberAngel replied to ColinPearson's topic in AutoCAD 2D Drafting, Object Properties & Interface
Is this a dynamic block? If not, that might be the way to handle this situation. -
Thanks again for your code, @mhupp It seems that the differences in the turning zones between the resulting geometry and the expected geometry persist. I must say that the goal is to obtain an axis that remains equidistant from the reference polylines at all times. I thought this problem would easily find a solution here. Maybe I was wrong
X11start replied to X11start's topic in AutoLISP, Visual LISP & DCL
... I tried replacing 'objectdbx.axdbdocument' with 'GStarX.axdbdocument': it keeps giving me the error VLA-OBJECT #<%catch-all-apply-error%> -
Precisely selecting with a window
Then you need to upgrade or follow my recommendation on searching the web for workarounds. I gave you a start with two relevant links. -
That's an Express Tool not available in AutoCAD LT. I was going to suggest the Excel Macro method. Maybe a Script can be used. Was an AutoCAD LT expert around here that did all kinds of customizations, including using Excel, before LT had AutoLISP function. @steven-g IIRC.
How can I modify this LISP routine to use millimeters instead? ;; CAB 05.12.09 ;; Draw Electric Wire (defun c:ew (/ ew_layer p1 p2 msg) (setq ew_layer "Wire") ; layer name (defun draw-ew (p4 p1 lay / p2 p3) (setq p2 (polar p1 (- (angle p1 p4) (/ pi ) 57.40259411) p3 (polar p4 (+ (angle p4 p1) (/ pi ) 57.40259411) ) (entmakex (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline") (cons 8 lay) (cons 90 4) '(70 . 0) ; 1 for closed 0 overwise (cons 10 p1) '(40 . 0.0) '(41 . 0.0) '(42 . 0.198912) (cons 10 p2) '(40 . 0.0) '(41 . 0.0) '(42 . 0.0) (cons 10 p3) '(40 . 0.0) '(41 . 0.0) '(42 . 0.198913) (cons 10 p4) '(40 . 0.0) '(41 . 0.0) '(42 . 0.0) ) ) ) (setq p1 (getpoint "\nPick start point (Draw clockwise")) (setq msg "\nPick next point clockwise.") (while (setq p2 (getpoint p1 msg)) (draw-ew p1 p2 ew_layer) (setq p1 p2) ) (princ) ) (prompt "\nElectric Wire loaded, Enter EW to run.") (princ)
syketchupls2 joined the community
Tengo un lisp que pone grilla en un viewport, funciona bien, pero solo en viewport que no estan rotados, no se mucho de lisp, casi nada, pero buscando por aqui y alla, lo logre contruir. el caso es que ya no pude hacer que ponga la grilla si esta rotado, otra cosa es que si el viewport no es completamente rectangular o cuadrado, se sale del limite del viewport, aqui esta grilla v2.lsp
pedro 47 joined the community
mhupp started following Excel link - Sanity check please
attout and attin?
Ok a few comments, Lets start, as mentioned when they added lisp to LT they decided to leave the smart stuff out, typical Autodesk, so you can not talk direct to Excel, Full Acad, or Bricscad, plus I believe a few others no problem. Just a side comment can also use Libre Calc. From Cad, yes can get range used," so get a list of all "A" column values no user input. Then find the one your looking for this will give you a row value. So put the attributes values into a cell. I have "Alan Excel.lsp" which is a lot of defuns that do different tasks I have saved the latest version in the download section. I have acknowledged those that have helped in putting it together the extra defuns, I keep adding to it depending on task. One thing you can do is check (setq xlApp (vlax-get-or-create-object "Excel.Application")) if it errors or returns NIL that would occur in LT. Please let me know. If its a simple nil then do the export to csv and use say (alert "Run the macro to import the csv file"), as a side note pretty sure in full version could call the macro, so one common code only. There is one little glitch when you need to go to Excel to do something user wise you must click on Excel window, but I did find a way around it using Powershell that is called from the CAD so it auto jumps to Excel. Should be able to do same in excel jump back to cad. Just google about your Excel macro questions there is huge amount of info out there use VBA answers and convert to Lisp sometimes.
HI, I'm running version 12, Regards, Lu -
Hello The problem may be in ObjectDBX. Try replacing "objectdbx.axdbdocument" with "GStarX.axdbdocument" -
Vova_l joined the community
The request for verification can be turned off with the BATTMAN command.
I checked: it works on Autocad... on GstarCAD it doesn't work. It doesn't matter, I use your previous file that reported the error but didn't allow renaming (CAPFD) thank you so much RLX for your effort! -
Thanks a lot, @mhupp I'll try your code.
bobm1475 joined the community
For completeness, the key here is the "Repeat" option of the -INSERT command - though, I'm unsure in which version this relatively new keyword was introduced.
Thank you very much eldon for your reply
As Lee says, it doesn't know, it is a bit of a blunt LISP that does the job and no more. Lees is much better but I had a mental block yesterday, couldn't remember cmdactive.
If you need more information, check the documentation on the CMDACTIVE system variable.
It won't - it will continue indefinitely until the user presses Esc to force it to exit.
Looped -Insert Command
I am still new with Lisp, but it feels that this is more elegant by checking if a command is active?
