  2. Try (defun c:todoA0 (/ cj e le n to p1 p2) (IF (setq cj (ssget "x" '((0 . "TEXT,MTEXT,INSERT,LINE,LWP*")))) (while (setq e (ssname cj (setq n (if n (1+ n) 0)))) (setq le (entget e) to (cdr (assoc 0 le)) p1 (assoc 10 le) ) (cond ((= to "LINE") (setq p2 (assoc 11 le)) (entmod (subst (cons 10 (list (cadr p1) (caddr p1) 0.0)) p1 le)) (entmod (subst (cons 11 (list (cadr p2) (caddr p2) 0.0)) p2 le)) ) ((= to "LWPOLYLINE") (entmod (subst (cons 38 0.0) (assoc 38 le) le)) ) ((member to '("TEXT" "MTEXT" "INSERT")) (entmod (subst (cons 10 (list (cadr p1) (caddr p1) 0.0)) p1 le)) ) ) ) ) (princ) )
  3. Today
  4. thank you. It seems that this lisp finds the lines with Z value problem and adds a label near them. It is great that it can find the lines, but I don't want this label to be added near this lines. I only need to select them. Can this lisp file be modified, so that it changes the Z values of the selected lines, to Zero? I mean, it selects the lines and modifies the "Start Z" and "End Z" to 0.
  5. thanks. I will see how I go creating the dynamic block. It does sound like what I want
  6. try this one. ZLABEL-Label Z Values On Topography Lines.fas
  7. Many years ago Civilcad Civil software we are talking at least 25 years ago had place a house on a lot. You could define various controls such as "Slide on line" so would move a shape based on say a fixed offset from the frontage, you could pick sides and it would show the distance form that side to a boundary, it was smarter than just use a point it would move the distance offset depending on the shape of the lot. Sounds like what you want. If you were to make a dynamic block that had all those constraints then you could have say a dcl front end change a value and the shape changes. Its pretty easy to draw that shape based on a rectang, but what if its not rectangular ?
  8. Hi everyone I am looking for a lisp to quick select different objects according to their specific properties in the entire drawing. The objects I am going to select are: 1- Every line that has "start Z" or "End Z" "Not Equal" to zero. 2- All "Text" that have "Position Z" "Not Equal" to zero. 3- All "Block References" that have "Position Z" "Not Equal" to zero. 4- All "Polyline" that have "Elevation" "Not Equal" to zero. Actually, I have so many files in which, Z values are not zero (Z values are about for example 0.000001). It makes the file so difficult to edit. I want to select every object and manually change the Z values to "zero". Also, it would be great if you guys can help me by any other way, to solve my problem and change the whole drawing's Z value to "zero", if possible. If not, it doesn't matter. Help me to write this Lisp, so that the selection of the objects get easier. Below, I attach a simple sample of my file, in which, some block, text, or lines have Z value other than zero. Z Value Problem.dwg
  9. Yesterday
  10. could someone help me with plate two please. I need a general idea of what it should look like and why my footings look so long pleasee
  11. I have been trying to create a lisp which will create a building envelope typical to the attached where offset vary depending on government and /or client requirements. Generally we draw each envelop individually and then copy and adjust where necessary, but I would like to automate the for use in very large concepts. The lot boundaries will generally be a closed polyline this is not necessary. From the attached image and dwg all components B to H are variable and depend on government and client requirements. Component I is variable and subject to variable A which is the lot frontage. If this frontage and less than 14m then component I is a solid line, if over 14m then it is a broken line. Component I is subject to engineering earthworks and would require a selection for which side or line to place that line (Built to Boundary Wall). As stated I would really like to automate the creation of the Building Envelope and all the entered variable are maintained until the lisp is closed. Hope this explains it enough BLE.dwg it would be great f the offsets could be conditioned so that depending on the frontage the lisp would automatically apply the correct offsets. The below is an example of offsets as required by a government. Generally they are not as complex as this table but it gives an idea of what is necessary.
  12. The Undo un-explodes them though. On my phone. Will have a look at the lsp tomorrow.
  13. Last week
  14. I have an idea but am about to leave for the long weekend.. Have an editable attribute for the Letter and the Number and when you enter that data, it sets another value for each of the 4 states. They can have a separate "non editable" attributes. Each state would have two attributes but they are all set by editing a single attribute in the main block. Edit the data once, set 8 attribute values from that. Can't explain it very well. Once I figure out the logistics, I'll ask for some help in the lisp section..
  15. I'm looking... Hard to follow indeed... hate videos with no audio... <thx!>
  16. Have a look at the video linked on this page. I can't quite follow it, but could you create an invisible attribute and echo it to the four positions?
  17. This is indeed a Section Marker. Lisp is always welcome but I don't know where to start. Maybe the 8 attribute solution is the closest I can get... The Text Alignment is different in each of the views. Creating a field as part of the Insert would work but It would have to take into consideration how many similar fields were existing in the drawing then increment the value/name then reassign the new field to the new block. Beyond my novice skill set..
  18. It would be nice if you could put the prompts and comments in English. I saw the Dogleglength when I did a dump on a Mleader. I'll see what I come up with. I know how to get a Spline length, I don't want to explode the Mleaders, defeats the purpose.
  19. BIGAL
    Block insert LISP
    The fix for the 1st and last arrow is easy, I look at the first point and is pline open if yes then just set angel_2 to the same ang as angel_1, Just add that extra line of code, same for last point, I just ignored and did not change. Same with your attributes how do you want to handle them so they are filled in correct.
  20. As a spline gives two answers the points answer and another with nodes. So any way if you explode the Mleader then you can get at the spline using this. Just need to check that the spline is last entity, tested in Bricscad. A disclaimer not sure if length is correct. I think it is short by length of arrow. Will try to find arrow length. Yep found it. (defun c:wow ( / plent pt len lenar) (setq plent (entsel "\nPick mleader ")) (setq lenar (cdr (assoc 140 (entget (car plent))))) (command "undo" "M") (command "explode" (car plent)) (setq ent (ssname (ssget "L") 0)) (setq len (getpropertyvalue ent "length")) (command "undo" "B") (alert (strcat "Total length is " (rtos (+ lenar len) 2 3))) (princ) ) (c:wow) I think you could do a "I want a length of 100 by drawing something close then move say arrow point till you get approx 100. Via lisp. It would be a two step process explode and move then undo and reset arrow head point.
  21. This is very similar to the problem of draw a section marker, if your happy with a lisp answer can be done very easy, you have 4 choices or can be based on say 3 point pick. Would use say 2 blocks. a HOR and VER arrow. The other way may be to look at the angle the block is inserted and rotate the attribute about a centre justification, not sure if can do that in a dynamic block. will have a play. Some one else may jump in with a new dynamic block. Did something similar in another post that stretches the gap between the arrows.
  22. Ivan N
    Block insert LISP
    Worked perfect, the scale and the color thing is nice. Thank you very much, for you time and help.
  23. Ivan N
    Block insert LISP
    I tested it it work perfect. Only thing that is a little bit difficult is selection but I think I can take care of it. Thank you very mach you help me solve my problem.
  24. Ivan N
    Block insert LISP
    I tested it, its work fine. Only tune that needs is the take care of the first and the last. Both arrows has to point in one direction. Thank you very much for you time and effort.
  25. Tsuky
    Block insert LISP
    Try an another version (vl-load-com) (defun c:BLOCKINSERT ( / ss blkname acadObj doc mspace n dxf_ent vlaobj pr nb_e scl_blk pt lst_pt nbs ang1 ang2 blk lst itm) (setq ss (ssget '((0 . "*POLYLINE") (-4 . "<NOT") (-4 . "&") (70 . 112) (-4 . "NOT>"))) blkname "Stalb" ) (cond ((and ss (tblsearch "BLOCK" blkname)) (setq acadObj (vlax-get-acad-object) doc (vla-get-activedocument acadObj) mspace (vla-get-modelspace doc) ) (if (null (tblsearch "LAYER" "EL_стълб_НН")) (vlax-put (vla-add (vla-get-layers doc) "EL_стълб_НН") 'color 1) ) (repeat (setq n (sslength ss)) (setq dxf_ent (entget (setq ent (ssname ss (setq n (1- n))))) dxf_210 (cdr (assoc 210 dxf_ent)) lst_pt nil) (setq vlaobj (vlax-ename->vla-object ent) pr -1 ) (repeat (setq nb_e (if (zerop (vlax-get vlaobj 'Closed)) (1+ (fix (vlax-curve-getEndParam vlaobj))) (fix (vlax-curve-getEndParam vlaobj)))) (if (not scl_blk) (progn (initget 6) (setq scl_blk (getreal "\nBlock scale?<1>: ")))) (if (not scl_blk) (setq scl_blk 1.0)) (setq pt (vlax-curve-GetPointAtParam vlaobj (setq pr (1+ pr))) lst_pt (cons pt lst_pt) ) (setq nbs (1- (length lst_pt))) ) (foreach pto lst_pt (if (and (not (zerop nbs)) (not (eq (1+ nbs) (length lst_pt)))) (setq ang1 (angle '(0.0 0.0 0.0) (vlax-curve-getFirstDeriv vlaobj nbs)) ang2 (+ pi (angle '(0.0 0.0 0.0) (vlax-curve-getFirstDeriv vlaobj (1- nbs)))) ) (setq ang1 (if (not (zerop nbs)) (+ pi (angle '(0.0 0.0 0.0) (vlax-curve-getFirstDeriv vlaobj (1- nbs)))) (angle '(0.0 0.0 0.0) (vlax-curve-getFirstDeriv vlaobj nbs)) ) ang2 ang1 ) ) (if (and (zerop nbs) (not (zerop (vlax-get vlaobj 'Closed)))) (setq ang1 (angle '(0.0 0.0 0.0) (vlax-curve-getFirstDeriv vlaobj nbs)) ang2 (+ pi (angle '(0.0 0.0 0.0) (vlax-curve-getFirstDeriv vlaobj (length lst_pt)))) ) ) (if (and (eq (1+ nbs) (length lst_pt)) (not (zerop (vlax-get vlaobj 'Closed)))) (setq ang1 (angle '(0.0 0.0 0.0) (vlax-curve-getFirstDeriv vlaobj nbs)) ) ) (setq nbs (1- nbs) blk (vla-InsertBlock mspace (vlax-3d-point pto) blkname scl_blk scl_blk scl_blk 0.0) ) (vlax-put blk 'Layer "EL_стълб_НН") (vlax-put blk 'Color 3) (setq lst (list (cons "Angel_1" ang1) (cons "Angel_2" ang2))) (foreach x (vlax-invoke blk 'getdynamicblockproperties) (if (setq itm (assoc (vla-get-propertyname x) lst)) (vla-put-value x (vlax-make-variant (cdr itm) (vlax-variant-type (vla-get-value x)))) ) ) ) ) ) ) (prin1) )
  26. ml.LSP
  27. Anyone have any hints on how to get Spline Leader lengths? Ultimately, I am looking to make several already drawn spline leaders the same length.
  28. I want to create a dynamic block with 4 visual states. I want two text values to appear in each state but in different places in each state. If I understand correctly you cannot move an attribute from state to state. Fields would work but I have no way of knowing how many of these blocks may be needed in a particular drawing. If I copy the attributes from VS to VS when creating the block, they only are available in the first state. The other states report there is no editable attributes but if I edit the state they are there. Here is a diagram of the 4 visual states. (the red is not part of the block, just a separator) I had created a block with 8 attributes but users found it confusing or difficult to navigate. Is there a way to achieve this in a simpler/better fashion?
  29. try using nentsel (nested entity select) Tho you will have to select the attribute itself and not just the block. might want to add some error handling like check for attribute or text. then after you edit will have to regen to update the drawing. (defun c:foo () (while (setq sel (nentsel "\nSelect Block Attribute : ") (setq ename (car sel)) ;check if sel is attribute (setq edata (entget ename)) (setq tag (cdr (assoc 2 edata))) ; Attribute tag (setq val (cdr (assoc 1 edata))) ; Attribute value (princ (strcat "\nTag: " tag ", Value: " val)) ) (princ) )
