  2. Hello everyone! Today, I’d like to share with you an AutoLISP routine for STEEL PLATE FABRICATION. Download: https://drive.google.com/drive/folders/1aJmLA-P5mX8ykPFYp5ShD5DTIBxQkDKm?usp=sharing DOC_DCC_PlateDim.lsp
  3. Today
  4. mhupp
    Fillet Polylines Multiple
    Sorry Nikon I removed a call to another sub function at the start that had the vl-load-com.
  5. Trial and Error most likely, if that seems it should produce a correct solution. As mentioned previously, sometimes just creating a new 3D Solid shape as needed and Union or Subtract.
  6. SLW210
    I like that one @mhupp. Luckily our waterjet and plasma don't seem to have issues, but smoothing couldn't hurt. I had the same error as Nikon, so I cleaned this up a bit. PolySmooth_1.0.lsp
  7. SLW210
    CAD Learning Game
    Seems interesting. Welcome to CADTutor!
  8. Paul Li
    Blocks and library
    @xurshid_viewportNow that you mentioned about wblocking each block as a dwg my free BlockApps actually comes with a new command called DDBlkCat which automates this process: https://marketplace.autodesk.com/apps/6d9671d7-7999-4998-b6a2-3fb959ee8a46?priceId=33599053-c530-44ac-9260-a1283eceb325
  9. xurshid_viewport
    Blocks and library
    @peterg one thing that caught me out when I started with LT: the Blocks palette on the "Current Drawing" tab only lists blocks that live inside the drawing you have open. If you made the blocks in a drawing and then purged or never saved it, they are gone from the panel, and a new drawing will not show them either. What I do now is save each block to its own file with WBLOCK into one folder, for example D:\Blocks\Doors and D:\Blocks\Furniture. In the Blocks palette there is a Library tab, and you can point it at that folder, so every file in it shows up as an insertable block in any drawing. LT 2022 has it, I use it daily for doors and windows. Tool palettes work too if you prefer dragging from a panel.
  10. I was modifying an existing 3D solid using SOLIDEDIT and ran into a situation where offsetting a face became difficult. The selected face was straightforward, but the surrounding geometry made the result less predictable than expected. I’m particularly interested in cases where the offset creates intersections with adjacent faces or causes the operation to fail, even though the requested distance seems reasonable. For those who use SOLIDEDIT regularly, how do you diagnose whether the problem comes from the face geometry, the offset distance, or the surrounding solid? Do you try another face-editing operation first, or modify the geometry another way?
  11. Nikon
    After applying the code and selecting the object, the closed polyline is split into separate lines. And the code terminates with an error. ; error: no function definition: VLA-GET-ENTITYNAME
  12. Attached is code SlbShow.lsp that ChatGpt help me generate which would run on AutoCAD on Windows OS. It'll first open a file window to select an existing slide library file like acad.slb Then run a vbscript to extract the names of the slides inside the selected slide library and place this into a text file. Next, the slides inside the selected slide library will be displayed in a custom dcl made up of a row of 4 x 5 column image buttons. Finally, when an Image button is clicked another window appears showing the slide in a larger image button view. I would like to know when vbscript or wscript is restricted does the code handle this and exit properly. Any other feedback is welcome. SlbShow.lsp
      • 2
      • Like
      • Thanks
  13. Yesterday
  14. mhupp
    I made this to run on our CNC profiles. It would always throw a tool path error if the polyline had corners the tool couldn't fit into. Because our profiles where generated from a laser outline and then cleaned by hand. A lot of the poly segments were very small and tedious to fix. using poly fillet would update all vertex and fillets to the radius you set. so if your profile had a larger radi it would create big wings. (see example) This only fillets if the radi is smaller then the tool dia or if two joined line segments can run fillet command. creates an old red outline poly on check layer to compare against. leans heavily on vlax-curve visual lisp functions. I think this took me about 2 week on and off to write up. updating the one profile could take 10 mins to multiped hours to fix manually. switching between AutoCAD and the CNC software to see if it would throw an error or finally pass. I think it became obsolete with the update to the CNC software. PolySmooth.lsp example.dwg
  15. Hi all, I am in the early stages of developing (vibe coding) something I have been thinking about for a minute: a videogame where you CAD. It's called CADcade and I've got a whole vision for it and everything. Right now it's just some beginner lessons, a sandbox mode, and an arcade mode with 36 drafting challenges of varying difficulties. It runs in your computer browser, and one of the goals is to help students and beginners learn the basics of navigating CAD products and spatial thinking for free online. This is kind of a demo of it that I would like to get feedback on (not selling or monetizing anything). I just wanted to share it here and see what you guys think. How does it feel? Ai slop? Not enough commands? Dumb concept? Every reply helps. cadcade.net Thank you!
  16. Steven P
    Select Entity or Enter Value
    Inspired by SWL210 tonight... An update to this one.... it is a bit more complex then just grabbing an entity or entering a text value... Went down the grread route which gave the results I want. Command is (entortext "Message" '(List 1) '(List 2) ) Message: Text message such as "Enter a value, or select some text" '(List 1) - Control characters to end the selection process in ASCII codes: 13 = Enter, 32 = Space ('List 2) - Text Control for selections: "A" - Alphabetical characters only (a, A - z, Z) as text entry or any text entity selection "N" - Numerical Characters only (1-9 .) as text entry, or pure numerical text entity selection "P" - Punctuation characters (< > , . / ?.....) as "A" but text is only punctuation "M" - Mathematical modifiers (+ - / *.....) as "A" but text is only numerical modifiers (I should change this t be the same as "N") "E" - any entity is selectable. Without E is selection is text only List 2 can be joined eg '("A" "M" "N" "P") to select any text (also '("N" "P") works and enter any text Special option: If 'N' is used only numerical text is selectable, 'A' will allow any text entity to be selectable. Combined also works for selecting any text (but only entering A-Z, 1-9 here no punctuation) For example "Select an entity or 'O' for Options") '(79 111) '("E") Note: Distinguishes between cases.... Note here 'O' for options, for example, excludes that as part of a text string to be returned - selection is ended on 'O' There are examples, entorent, entorstring, entorvalue to look at in there. Returns: If text is entered: '("text", ASCII of enter method (13, 32..), nil) If Entity is selected: '(<entity name>, point selected, insert point of selection If Escape pressed: ("Lucky escape" 27 nil) - escape is captured and returned to the calling function - handy if selecting in a while loop If that makes sense, have a play. Oh, and an easter egg for you which might or might not work... ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun EntorCommand (/ *error* RunLispCommand RunNativeCommand MyCommand LispCheck Result ErrorMessage CommandStatus ) (defun *error* (Msg) (if (> (getvar "CMDACTIVE") 0) (command) ) ; ;; Cancel any native command still running. (cond ((null Msg) (princ "\nCommand ended with error.")) ((wcmatch (strcase Msg) "*BREAK*,*CANCEL*,*EXIT*" ) (princ "\nCommand cancelled.") ) (t (princ (strcat "\nCommand error: " Msg ))) ) ; End Cond (princ) ) ; End Defun *error* (defun RunLispCommand (LispFunction /) (apply LispFunction nil) ) ; End Defun RunLispCommand (defun RunNativeCommand (CommandName /) (command CommandName) (while (> (getvar "CMDACTIVE") 0) (command pause) ) ; End While ) ; End Defun RunNativeCommand (setq MyCommand (strcase (getstring "\nPausing Text Selection.\n(Command Line to) Enter Command: " ))) (setq LispCheck (vl-catch-all-apply 'eval (list (read (strcat "C:" MyCommand) )))) (if (and LispCheck (not (vl-catch-all-error-p LispCheck)) ) ; end and (progn ; LISP (setq Result (vl-catch-all-apply 'RunLispCommand (list (read (strcat "C:" MyCommand))))) (if (vl-catch-all-error-p Result) (progn ; LISP Error (setq ErrorMessage (vl-catch-all-error-message Result)) (if (wcmatch (strcase ErrorMessage) "*BREAK*,*CANCEL*,*EXIT*,*ABORT*" ) (princ (strcat "\nLISP command " MyCommand " cancelled: " ErrorMessage )) (princ (strcat "\nLISP Command " MyCommand " ended with an error: " ErrorMessage )) ) ; End If ) ; End Progn (progn ; LISP Completed (setq CommandStatus "completed") ) ; End Progn ) ; End If ) ; End Progn (progn ; Native AutoCAD Command (setq Result (vl-catch-all-apply 'RunNativeCommand (list MyCommand) )) (if (vl-catch-all-error-p Result) (progn ; Native Command Error (setq ErrorMessage (vl-catch-all-error-message Result)) (if (> (getvar "CMDACTIVE") 0) (command) ) ; Ends command if running (if (wcmatch (strcase ErrorMessage) "*BREAK*,*CANCEL*,*EXIT*,*ABORT*") (princ (strcat "\nCommand " MyCommand " cancelled: " ErrorMessage )) (princ (strcat "\nCommand " MyCommand " ended with an error: " ErrorMessage )) ) ; End If ) ; End Progn (progn ; Native Command Completed (setq CommandStatus "completed") ) ; End Progn ) ; End If ) ; End Progn ) ; End If (princ "\nEnded Command") (princ) ) ; End Defun ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;Ent Or Text options: ;;msg: Message to user ;;EndString: ASCII character code List '(13 32....) that will end the selection process. Note: add upper and lower cases ;;TextTypes: A list of letters to accept A: Alphabet, E: Entities, M: Mathematical symbols, N: Numbers, P: Punctuation symbols (defun EntOrEnt (msg EndString / TextTypes)(EntorText msg EndString '("E"))) ; entities only ; Equivalent to EntSel + Escape! (defun EntOrStr (msg EndString / TextTypes)(EntorText msg EndString '("N" "M" "A" "P" "E"))) (defun EntOrVal (msg EndString / TextTypes)(EntorText msg EndString '("N" "M" "E"))) (defun EntorText ( msg EndString TextTypes / MyTextType EndLoop grsel sela sel MyEnt MyValue MyCharacters MyCommand enta entb pt lw MyList MyTextString EscapeCode NestedSelection) (setq EscapeCode nil) (if (= (type EndString) 'LIST) (progn) (setq EndString (list 13 32)) ;; 13: Enter, 32: Space ('T' in getstring) ) ; End String (if (= (type msg) 'Str) (princ msg) (princ (setq msg "Select or enter text: ")) ) (if (= (type TextTypes) 'LIST) (progn) (setq TextTypes (list "A" "N" "P" "M")) ;; A: Alphabet, N: Numerical, P: Punctuation, M: Mathemtatical ) ; End String ;;Starting values (setq MyValue "") (setq MyEnt (list)) (setq EndLoop "No") (setq MyCommand 0) (setq MyTextType nil) (if (or (member "N" TextTypes)(member "n" TextTypes)) (setq MyTextType (strcat (if (= MyTextType nil) "" MyTextType) "1234567890.,"))) ; Numerical (if (or (member "A" TextTypes)(member "a" TextTypes)) (setq MyTextType (strcat (if (= MyTextType nil) "" MyTextType) "ABCDEFGHIJKLMNOPQRSTUVWXYZ"))) ; Alphabet (if (or (member "P" TextTypes)(member "p" TextTypes)) (setq MyTextType (strcat (if (= MyTextType nil) "" MyTextType) "`#`~`@\\|<`,>`.`?/¬``!\"£$%^&`*()`-_="))) ; Punctuation (if (or (member "M" TextTypes)(member "m" TextTypes)) (setq MyTextType (strcat (if (= MyTextType nil) "" MyTextType) "=/+-`*`.`,"))) ; Maths Functions (if (or (member "E" TextTypes)(member "e" TextTypes)) (setq MyTextType (strcat (if (= MyTextType nil) "" MyTextType) ""))) ; Entity (implied in code if not listed) (if (= MyTextType nil)(setq MyTextType "1234567890ABCDEFGHIJKLMNOPQRSTUVWXYZ")) ;;Loop for grread function (while (= EndLoop "No") (setq grsel (vl-catch-all-apply 'grread '(nil 13 2))) ; catch errors (escape key) (if (vl-catch-all-error-p grsel) ;; escape pressed, end loop (progn (setq EndLoop "Yes") (princ (strcat "\n" (setq MyValue "Lucky escape"))) (setq escapecode 27) (setq MyEnt nil) (if lw (redraw lw 4) ) ) ;end progn escape pressed (progn (setq sela (car grsel)) (if (= sela 5) ; Highlight on hover (progn (if lw (redraw lw 4) ) ;Remove any highlight (if (and (setq pt (cadr grsel) ) (setq lw (ssget pt)) (setq lw (ssname lw 0)) ) ; end and (redraw lw 3) ) ; end if ) ; end progn ) ; end if (if (or (= sela 2)(= sela 3) ) ; text entry or mouse click (progn (setq sel (nth 1 grsel)) (if (= (type sel) 'LIST) (progn (setq MyList '("TEXT" "MTEXT" "RTEXT" "ATTRIB" "ATTDEF" "DIMENSION" "INSERT")) ; list of entity types allowed to select (if (or (member "E" TextTypes)(member "e" TextTypes)) (setq MyList (append MyList (list "LINE" "POLYLINE" "3DPOLYLINE" "LWPOLYLINE" "MLINE" "SPLINE" "POLYGON" "MPOLYGON" "VIEWPORT" "WIPEOUT" "ELLIPSE" "CIRCLE" "ARC" "POINT" "HATCH" "SURFACE" "SOLID3D" "SHAPE" "FACE" "3DFACE" "SOLID" "3DSOLID" "TRACE" "RAY" "XLINE" "RASTER" "XREF" ))) ) ;;SP TO complete this list with: ;;ACAD_PROXY_ENTITY, BODY, HELIX, IMAGE, LEADER LIGHT, MULTILEADER, MLEADERSTYLE, ;;OLEFRAME, OLE2FRAME, REGION, SECTION, SEQEND, SHAPE, SUN, TABLE, TOLERANCE,UNDERLAY, VERTEX, (setq MyEnt (nentselp sel)) (cond ((or (= nil MyEnt) (= (member (cdr (assoc 0 (entget(car MyEnt)))) MyList) nil) ) ; Endor (progn (Princ "\nMissed! Try again.\n")(princ msg) ;; or add in here 'ssget' (setq MyEnt nil) ) ) ( T ;; Text selected (if (equal TextTypes '("E"))(princ ": Ahh, you selected a thing")(princ ": Fantastic selecting ability.")) ;;Check if numerical only selection (if (or (equal TextTypes '("N")) (equal TextTypes '("n")) ) ; endor (progn (setq entb (last (last (nentselp (last grsel))))); grsel point value (if (and (/= entb nil) (/= (type entb) 'real)) (if (wcmatch (cdr (assoc 0 (entget entb))) "ACAD_TABLE,*DIMENSION,*LEADER")(setq MyEnt (list entb (last grsel)))) (progn) ) (setq MyTextString (cdr (assoc 1 (entget (car MyEnt)))) ) (setq mytextString (LM:Unformat MytextString nil)) ; Unformat string (if (or (wcmatch (strcat MyTextString) "*[~1234567890`.`,]*") (and (vl-string-search "." MyTextString) (vl-string-search "." MyTextString (+ (vl-string-search "." MyTextString) 1)) ) ; end and ) ; endor (progn (princ (strcat " However, selection is not numerical,\n" Msg ", or [esc]: ")) (setq MyEnt nil) ) ; end progn (progn (setq EndLoop "Yes") ) ) ; end if number check ) ; end progn numerical (progn (setq EndLoop "Yes") ) ; end progn ) ; end if ) ; end cond T ) ; end conds (if lw (redraw lw 4)) ; remember to (redraw xyz 3) in originating code to keep highlight (setq sel nil) ) ; end progn ; selection is list (progn (setq MyCharacters (list 137)) ; list of single characters to accept (if (member 32 Endstring)(progn)(setq MyCharacters (cons 32 MyCharacters))) ; add [space] if 't' (if (or ;;limit characters able to able to be used ;; remove escape keys later (wcmatch MyTextType (strcat "*" (strcase (chr sel)) "*"));; Strcase to include caps (= sel 92) ; '\' character for commands (member sel MyCharacters) ) ; endor (progn (if (= sel 92) ;; If double '\\' enter commands - check if '\' entered (progn (setq MyCommand (+ MyCommand 1)) (if (= MyCommand 2) (progn (princ (chr 8)) ; remove last '\' from command line (setq MyValue (vl-string-right-trim (chr 92) MyValue)) ; remove '\' from result (EntorCommand) (setq MyCommand 0) (setq sel nil) (princ "\nResume Text Selection.\n")(princ MSG)(if MyValue (princ MyValue)) ) ; end progn command = 2 (progn (if (member sel EndString) ;; remove escape keys from MyValue (progn) (progn (princ (chr sel)) (setq MyValue (strcat MyValue (chr sel) )) ) ; end progn ) ; end if ) ; end progn ) ; end if ) ; end progn (progn (setq MyCommand 0) (if (member sel EndString) ;; remove escape keys from MyValue (progn) (progn (princ (chr sel)) (setq MyValue (strcat MyValue (chr sel) )) ) ; end progn ) ; end if ) ; end progn ) ; end if ) ) (if (member sel EndString) ; enter (progn (setq EndLoop "Yes") (setq EscapeCode sel) ) ; end progn (progn ) ) ; end if (if (= sel 8) ; backspace (progn (if (> (strlen MyValue) 0) (progn (setq MyValue (substr MyValue 1 (- (strlen MyValue) 1))) (princ (chr sel)) ) ; end progn ) ; end if ) ; end progn (progn ) ) ; end if ) ; end progn ) ; end if list ) ; end progn ) ; end if text / mouse entry ) ; end progn ) ; end if catch-all-error ) ; end while (if (or ( = (length MyEnt) 0)(= MyEnt nil)) ;; if no entity selected.. text entry (progn ;; If text is entered ) ; end progn (progn (setq enta (car MyEnt)) (setq pt (cdr (assoc 10 (entget enta))) ) (setq entb (last (last (nentselp pt)))) ;; use sel? ;; nested entities (if (and (/= entb nil) (/= (type entb) 'real) (wcmatch (cdr (assoc 0 (entget entb))) "ACAD_TABLE,*DIMENSION,*LEADER") ) ; end and (setq MyValue entb) ; If entity is DIM, Table, Leader (setq MyValue enta) ; ELse entity ) ; end if ) ; end progn ) ; end if ;;Result - '(MyValue Pt) ;;'Ended ##' : An escape character code if entered ;;'Lucky Escape' : Escape key pressed ;;<Entity name: ##> : The selected entity ;;Other character : Entered Characters ;;(cadr grsel) - mouse point ;;pt - entity insert point (assoc 10) (if EscapeCode (setq MyValue (list MyValue EscapeCode nil)) (setq MyValue (list MyValue (cadr grsel) pt)) ) MyValue ) Al Still thinks this is a native command "EntOrText" by the way...
  17. mhupp
    Update
    I don't know if you use php here but might want to upgrade if you haven't already. https://www.php.net/archive/2026.php#2026-10-21-5
  18. Hi, I'm building a generator that outputs ISO 5457 borders and ISO 7200 title blocks as DXF (R12 and R2000). I'm the author, and I'm here to ask rather than to promote. Things I'd like your experience on: 1. Units: R12 has no INSUNITS, so how do you make sure a 420 x 297 sheet stays 420 x 297 in a .dwt? 2. Attributes: do you edit them in place or redefine the block? 3. Text style: any trouble with arial.ttf on machines with different fonts? I can attach a sample DXF if that helps the discussion. Thanks.
  19. Double posted
  20. Typically etransmit should be used. This way any fonts and plot styles can be packaged along with xrefs in the zip file. This is what I would request from the architect. But hatches plotting solid black is very odd. Could you share a sample dwg that includes theses hatches for us to test?
  21. LIU
    ucs and drawing problem
    THANKS ,
  22. So in keeping with posting some of my LISPs, I used this just the other day, and just was reminded with the recent resurrection of the Fillet 0 issue thread where the OP was doing 40,000, not sure what LISP they used. Per the latest resurrection, setting FILLETPOLYARC setting may or may not help depending on what you are trying to fillet. The few times I have seen Fillet 0 fail with the P option was when the fillet radii completed something like a half circle when adjacent corners are filleted (something like the ends of a slot). This can be handy dandy. There are others like this around. For my use this was better than a few of the ones I tried. You may need to change the FILLETPOLYARC=0 if you have issue using this with Radius=0. In those situations when I had an issue, the LISP just doesn't do anything to those fillets, so I just go back with a small radius and change them, then you should be able to Fillet=0 those. (defun c:MF () (c:MultiPolyFillet) ) (defun c:MultiPolyFillet (/ radius ss i ent) (setq radius (getdist "\nFillet radius: ")) (if radius (progn (setvar "FILLETRAD" radius) (setq ss (ssget '((0 . "LWPOLYLINE,POLYLINE")))) (if ss (progn (setq i 0) (while (< i (sslength ss)) (setq ent (ssname ss i)) (command "_.FILLET" "_P" ent) (setq i (1+ i)) ) ) ) ) ) (princ "MultiPolyFillet complete.") (princ) ) (princ "\nMultiPolyFillet loaded. Type MultiPolyFillet or MF to run." ) (princ)
  23. The OP and the 2nd person with a problem fixed their issues with resetting AutoCAD and resetting their profile. FILLETPOLYARC, can be handy set to 1 if you need to Fillet arc segments. Though it has it's faults.
  24. Hi everyone, I've just read about this thread because I encountered the same issue of not being able to fillet a polyline with radius 0 when using the p-option. It works fine if I select separate straight sections of the polyline though, but that's not what I want. So, looking a bit further, I found the resolution to my problem in the systemvariable 'FILLETPOLYARC'. When setting this variable to '1', fillet radius 0 on polylines doesn't work. Setting this variable to '0', however, results in expected behaviour, filleting with another radius, thereby changing the existing arc segments by their new radius - including radius of 0. Let this tip help us all further in our (sometimes) struggle with Autodesk adding variables in new releases which change our expected ways of working. And remember, set the 'FILLETPOLYARC' variable to '0' Cheers! Peter
  25. Last week
  26. That really depends on the situation. If pretty simple to begin with it may be quicker to redo from the beginning. If not simple to redo, face editing can be quick and accurate and many options there, though just creating a new solid and using Subtract and/or Union could be the better option. Like I stated it really depends on the model and the change required.
  27. Especially welcome and invite developers, especially those in retirement status, to share and update the tools (plugins) you have created through VedaCAD, so that more people can benefit from your creations. These repositories for VCID's results will no longer fade away with time; they will enable those in need to obtain and use them. Especially, VedaCAD is now able to handle the release of plugins at the MSI level (official store). For any VedaCAD usage issues and suggestions, please feel free to contact me directly: vico@vedacad.com
  28. Why would that be interesting? STEP is very common and maintains information and accuracy. So if unknown usage why wouldn't that be the choice? I usually work with AutoCAD, so ACIS or .dwg is my first choice, then STEP if I need information retained for other programs, for 3D Printing simple objects, I sometimes will just do the .stl export. My 3D Printer slicing software can handle STEP files, I have yet to test some more intricate models, but, it eventually creates .stl and then a .3mf g-code file for the printing. It's very tedious painting multicolor parts in the slicer software, so I'll need to see how pre-coloring in AutoCAD>STEP works and which is better. That's just in reference to what AutoCAD can do (Mechanical for STEP), there are other options for different programs.
