xurshid_viewport Posted 3 hours ago Posted 3 hours ago Hello all. I draw small residential projects in LT 2022 at a two-person bureau, and I keep running into the same thing with xrefs. The architect I work with sends me his site plan as a DWG, I attach it as an overlay, and everything looks fine in model space. But when I plot the layout to PDF, some of his hatches come out solid black and a few of his text styles change to a different font. On his machine the same file plots correctly. I'm guessing it's either missing shape/font files on my side or his plot style table not travelling with the drawing. He uses a CTB, I use the same CTB name, but maybe the files are not identical. What is the usual way you handle this when you get drawings from outside: eTransmit from the sender, or bind the xref before plotting? I'd rather not explode anything, I already learned that lesson. Quote
SLW210 Posted 55 minutes ago Posted 55 minutes ago Maybe try XREFOVERRIDE and VISRETAIN. How does it look in the plot preview? How does it look when plotted to paper? You might go through THIS. Quote
