  2. My comments "Decades-old municipal or plant drawings ", yes that is where the water main is located according to the onsite meeting with the water authority representative, We then got a service locator to really confirm where is water main. It took a meandering path due to road conditions not a straight line as shown on the water plan. So the plans are only asgood as "Ist baout here somewhere. Another telecommunication authority its a line on a plan no idea of actual offsets etc, conduits do not go square out of pits rather run along a boundary then cross a road so many stories about services, a 22,000KV elec underground cable missed by 100mm because another crew took on doing some trenching, we had already dug and deptrhe id. For us a day to day task. Just have to work out how to solve. Solution may need a current field survey tying known points to world co-ordinates etc.
  3. Today
  4. Raster images - Tiffs - complete redraw using whatever dimensions are available, what I don't know you can infer a lot (for example a wall thickness near a known dimension can infer another dimension) and after that it is down to experience and knowledge with the odd "go over there with a tape measure". Mapping websites are OK for buildings - use 2 or 3 and average out the distances can help if there are absolutely no known dimensions (again inferring distances from known things... including counting bricks from a street view), mapping I have a tool to draw perpendicular polylines off the first line angle which helps a lot. Small parts are often drawn to fractions of the scale (0.5mm, 1mm, 2.5mm etc.... 1/100th inch or whatever) - so once drawn can snap entities to a grid... gets close enough which is all you can do if you cannot be supplied with dimension or a part / site visit to work more accurately from Used to have Paintshop Pro (7 I think) that had a tool to correct parallax errors somewhat.
  5. We’re looking for an experienced programmer to update our AutoCAD LISP routines and menus. Our routines are used in AutoCAD 2011 and include a parcel script. If you have experience with AutoLISP and customizing AutoCAD, please reply with a brief description of your experience, examples of similar work, and your availability. Please include your preferred rate and how you’d like to discuss the project. Thanks!
  6. Thanks for the question and the sharp reality check, @SLW210! To answer your first question: It works for standard AutoCAD (.DWG / .DXF), Civil 3D, and Map 3D drawings. The parser extracts 2D/3D polylines, pipe network linework, layer hierarchies, and block attributes directly without requiring an active Autodesk Map 3D / Civil 3D seat on the client machine. Regarding subcontractors submitting incomplete drawings: You are 100% right on contract protocol. On new builds under active contract, non-compliant CAD files should definitely be rejected and kicked back to the sub. Where our users run into the real headache is in scenarios where "sending it back" is no longer an option: 1. Legacy archives & brownfield utility assets: Decades-old municipal or plant drawings where the original drafter/firm is long gone, drawn in local 0,0 plant coordinates with zero projection metadata. 2. Cross-team handoffs: When civil drafters (who only work in 2D AutoCAD LT) hand off files to municipal GIS teams who need instant OGC Shapefiles or PostGIS layers with invert depths and pipe diameters intact. 3. Rapid feasibility & bidding: When estimating contractors receive messy tender CAD files and need to overlay them onto Google Earth KMZ or GIS parcel boundaries in minutes rather than spending half a day rubber-sheeting. We're trying to eliminate that tedious manual linework cleaning and coordinate mapping when teams are stuck with what they have. Would love your thoughts on what edge cases you see break Map 3D exports most frequently!
  7. I have used Raster Tools with some great success before. For badly distorted drawings, I create blocks and scale in both directions, no matter the method used to create the linework. If it is a critical part that needs to be drawn very accurate or just a terrible plot, scan, etc., I just look at the drawing and totally redraw from scratch using the indicated dimensions or even better for small objects I just measure the object if available.
  8. Is this for AutoCAD, Civil 3D, Map 3D or all of them? As stated on another thread, if a subcontractor submitted incomplete drawings, they would be sent back or not paid.
  9. Steven P
    Associative Textbox (Lee Mac)
    Select both entities, the text and the text box? Edit: Thinking about it, probably best to copy just the text and recreate the textbox to be sure to keep the new text and box associated,
  10. Follow-up for anyone who just needs a city rather than a custom rectangle: there are ready-made city pages now, e.g. London https://osm2cdr.com/en/map/united-kingdom/england/london/ and New York https://osm2cdr.com/en/map/united-states/new-york/new-york/ — the DWG/DXF there comes split into layers (roads, buildings, water, landuse) in the CRS you pick. Disclosure: I'm the developer.
  11. Hopefully there are dimensions noted on the scan. That's what I would typically use to manually redraw it accurately in CAD from scratch.
  12. indiancad
    Reflecting Light
    The black ceiling is likely caused by the renderer not calculating enough indirect illumination. Increasing material reflectivity alone won't solve this. You need to enable global illumination (GI) or indirect lighting so light can bounce off the floor and surrounding surfaces. Also, check whether your renderer supports bounced light and adjust the indirect illumination settings. Self-illumination can help simulate light sources, but excessive use may produce an artificial appearance.
  13. Legacy project drawings are often available only as scanned PDFs or raster images. Converting them into editable DWG geometry can be difficult because paper distortion, scanning errors, and inconsistent image scaling may affect dimensional accuracy. Scaling the image using a single known dimension may not correct distortion across the entire drawing. When converting old scanned drawings, how do you verify geometric accuracy across the full sheet? Do you use multiple control dimensions, image rectification, or manual reconstruction of critical geometry?
  14. Slotted holes are commonly used in mechanical assemblies to allow adjustment during installation. However, specifying their dimensions and positional tolerances can become challenging when the slot must provide sufficient adjustment without compromising the final alignment. A simple length and width dimension may not communicate all the functional requirements, particularly when the slot position is critical to the assembly. When detailing slotted holes, how do you specify their geometry and positional tolerances? Do you use GD&T with a defined datum reference frame, or follow another dimensioning approach?
  15. AONE_LED
    How can I add an Emergency Light Type to existing lights?
    Put the half-shaded emergency symbol in a nested Generic Annotation family, not as model lines. In that annotation, draw the normal fixture symbol and a solid half-fill. Select only the half-fill and link its Visibility to a Yes/No parameter, for example EmergencyGraphic. Load the annotation into the lighting fixture family, place it as the plan symbol, and hide the 3D geometry in plan views. Associate the nested EmergencyGraphic parameter with a type parameter of the same name in the host family. Create two types: Normal (unchecked) and Emergency (checked). Switching the type in the project then shows or hides the half-shade, like a single-pole versus 3-way switch. If the graphic does not appear, confirm the annotation is visible in plan/RCP and that you used a type parameter, not an instance one.
  16. AONE_LED
    Reflecting Light
    Draft uses a simplified lighting model, so the ceiling can look lit with no bounced light. Low and higher presets use ray-traced direct light only, unless you turn on indirect illumination. A cowling around a downward fluorescent correctly blocks direct light from reaching the ceiling, which is why everything above the fixtures goes black. Turn on Global Illumination and Final Gather in the Render settings. Start with Photons/sample around 500 to 1000 and Final Gather rays around 500, then increase if the ceiling looks blotchy. Give the floor and walls realistic diffuse reflectance (about 0.2 to 0.3 for a floor, 0.5 to 0.7 for walls) so photons can bounce. Also check that the light source is not fully enclosed by the cowling solid; leave a downward opening, or no light escapes. With photometric units on, intensity in candela or lumens needs to be high enough for a 16 ft room.
  17. Each DIALux export usually creates a unique anonymous block (*U...) per luminaire, so BLOCKREPLACE and the Express Tools replace-block command cannot swap them in one step. A reliable workaround is to harvest the insertion data, then place your own named blocks. Use DATAEXTRACTION on all INSERT objects whose names start with *U. Export insertion point X/Y/Z, rotation, and X/Y scale to a CSV. In a clean copy of the drawing, erase the anonymous inserts (FILTER or QSELECT by name *U*), then run a short script or LISP that reads the CSV and inserts your fixture block at each point with the same rotation and scale. If several luminaire types were exported, group them first by layer or by any DIALux type attribute that survived the export. Keep a backup before erasing the *U blocks.
  18. Yesterday
  19. Hello CADTutor community, As someone working with civil engineering infrastructure datasets, one of the most frustrating bottlenecks has always been data migration from AutoCAD into GIS environments (QGIS, ArcGIS, PostGIS). Often, drawings received from subcontractors sit at arbitrary (0,0) origins with zero projection metadata, line layers lack topology, and pipe invert tags are trapped as plain CAD text. To tackle this, we developed a tool called GeoMorph AI (https://propertyrock.in) that automates the extraction and georeferencing pipeline in ~12 seconds: Key Features: - Direct Ingestion: Parses raw DWG/DXF layers, text tags, and invert levels using Python ezdxf. - Autonomous Coordinate Alignment: Pattern-matches local CAD layout features to real-world WGS84/UTM coordinates without manual rubber-sheeting. - Topology Rebuilding: Converts unjoined polylines into clean network topology for water/sewer/telecom lines while preserving diameters and depths. - Multi-Format Export: ESRI Shapefile bundle (.shp, .shx, .dbf, .prj), GeoPackage (.gpkg), GeoJSON, and direct PostGIS 3.4 database sync. - 3D WebGL Map: Interactive browser viewer for instant visual quality control. 1-Minute Video Demonstration: https://youtu.be/V9LtA6QLPz0 We would genuinely appreciate thoughts and critique from draftsmen and CAD managers: - What edge cases (e.g. 3D solids, complex dynamic blocks, splines) usually break your exports into GIS? - How does your current workflow handle local grid to national projection transformations? If anyone has a sample tricky DWG they would like to test, feel free to share or test it directly on the platform! Best regards, Pramod Kumar
  20. Alessandro
    Dear sir, on my autocad LT 2027, if i generate a TBOX and then i copy and paste the text (both using the command copy and using ctrl+c - ctrl+v), i don't have a copy of the tbox too. Is there a solution for this?
  21. For lighting schedules in vanilla AutoCAD, a fixture block with attributes plus DATAEXTRACTION is usually the most reliable method. Use a unique type mark (A, B, C) as an attribute at the insertion point, and add attributes for description, lumens, wattage, CCT, voltage, mounting (recessed, surface or pendant) and ceiling cut-out. Keep one block definition per fixture type so the counts stay accurate. DATAEXTRACTION can then build a table of Type, Description, Quantity, Watts and Lumens, and you can refresh it when the layout changes. Excel is still useful for photometric and driver data that does not live in the drawing; DATALINK the finished table back into the sheet so the two stay in step. Avoid mixing a hand-counted grid with extracted quantities, or the schedule will drift.
  22. In AutoCAD 2000 you cannot declare a solid as a light source, and photometric weblights did not exist yet. Model each fluorescent as a simple 26 mm (T8) or 16 mm (T5) cylinder, then place a row of low-intensity point lights along the tube centreline at about 200–300 mm centres so the light is even. Give the tube a pale, slightly self-illuminated material so the lamp reads as glowing in the render; keep the housing as ordinary geometry so it can cast a soft shadow. For a ceiling grid, copy this fixture as a block to each troffer location and aim the lights downward. If you later move to AutoCAD 2007 or newer, set LIGHTINGUNITS to 2 (SI) and use one WEBLIGHT per fixture with a manufacturer IES file instead.
  23. Cove lighting on an RCP is usually shown as a continuous dashed or hidden line along the inside face of the cove, not as a row of downlight circles. Put it on its own layer, for example A-CLNG-LITE-COVE, so you can plot it lighter than the ceiling grid. If the cove has a linear LED or fluorescent strip, a single dashed line at the lamp position is enough; a narrow hatch or a double line can indicate a wider light shelf. Tag the run with the fixture type (for example "C1 – LED tape in cove") and note the soffit depth in the legend. Recessed downlights and the ceiling grid stay as solid symbols. Grey-tone RCPs are common: existing work in grey, new lighting and notes in black, all drawn at 1:1 in model space.
  24. Last week
  25. In projects that use dynamic blocks for equipment layouts, electrical symbols, or standard components, changing visibility states and block parameters can sometimes leave attribute information inconsistent across different block instances. This becomes particularly troublesome when drawings contain hundreds of instances with part numbers, descriptions, or equipment tags that must remain accurate. Commands such as ATTSYNC can synchronise attribute definitions, but they may also affect manually modified attribute values. How do you manage attribute consistency in drawings containing large numbers of dynamic block instances? Do you rely on ATTSYNC, custom AutoLISP routines, or a different block-management workflow?
  26. This can be automated using AutoLISP with the WBLOCK command. A routine can iterate through all 3DSOLID entities, export each one as a separate DWG, and generate sequential filenames such as Solid-001.dwg. One important detail is to distinguish between preserving the original world coordinates and moving each solid to 0,0,0. Which output do you need: original coordinates or each solid individually positioned at the origin?
