Converting scanned engineering drawings into accurate editable CAD geometry
Legacy project drawings are often available only as scanned PDFs or raster images. Converting them into editable DWG geometry can be difficult because paper distortion, scanning errors, and inconsistent image scaling may affect dimensional accuracy.
Scaling the image using a single known dimension may not correct distortion across the entire drawing.
When converting old scanned drawings, how do you verify geometric accuracy across the full sheet? Do you use multiple control dimensions, image rectification, or manual reconstruction of critical geometry?
Edited by indiancad
