  2. Danielm103
    KDTree as a NET application.
    all you would need to do is edit the bat file to point at the target platform. AI says you can jut create a project file next to the .cs, then use “dotnet build -c Release” <Project Sdk="Microsoft.NET.Sdk"> <PropertyGroup> <!-- Use net48 for AutoCAD 2021-2024, or net8.0-windows for AutoCAD 2025+ --> <TargetFramework>net8.0-windows</TargetFramework> <ImplicitUsings>enable</ImplicitUsings> <Nullable>enable</Nullable> <Platforms>x64</Platforms> </PropertyGroup> <!-- Reference your AutoCAD libraries --> <ItemGroup> <Reference Include="AcCoreMgd"> <HintPath>C:\Program Files\Autodesk\AutoCAD 2017\AcCoreMgd.dll</HintPath> <Private>False</Private> <!-- Prevents copying AutoCAD DLLs to your output folder --> </Reference> <Reference Include="AcDbMgd"> <HintPath>C:\Program Files\Autodesk\AutoCAD 2017\AcDbMgd.dll</HintPath> <Private>False</Private> </Reference> <Reference Include="AcMgd"> <HintPath>C:\Program Files\Autodesk\AutoCAD 2017\AcMgd.dll</HintPath> <Private>False</Private> </Reference> </ItemGroup> </Project>
  3. Today
  4. Danielm103
    Nice! I used Nanoflann for the python wrappers, Ge.Point2dTree, Ge.Point3dTree https://github.com/jlblancoc/nanoflann it builds the tree multi-threaded. Nanoflann can be made dynamic in that it can add or remove points, though I didn’t add that in to the python wrappers. I also created a wrapper for AutoLISP here https://github.com/CEXT-Dan/ads_geo Wrappers are limited though, in C++ you can create a payload I.e. { Point Data } Otherwise, you have to create a hashmap to link the point with the payload. A professional C# version might use an interface for X,Y,Z, so you can expand the tree to allow any class or structure that has the proper interface
  5. Yesterday
  6. ymg3
    I am kind of a Green Horn when it comes to compiling. I don't even have vstudio. So I still use the legacy csc compiler. On top of that i only have access to acad 2017, so I am not aware of what would be needed to compile it for more recent version of Autocad.
  7. BIGAL
    Whilst I probably won't use it, have you looked at compiling for Non Acad, say Bricscad a lot of users here.
  8. BIGAL
    A new get length LISP
    Yes outputting results as both may be the simplest way. Re make a dcl, I use say multi radio buttons.lsp as it only needs 3 lines of code to work, you comment out the vla-deletefile, so the dcl code remains, I then use the RLX convert dcl to lisp so paste the converted code into my programs, using the multi just saves typing to make the source dcl. Just another comment, I have a make a radio button dcl from a dwg. RLX was looking into doing similar. I have code also for Libreoffice Calc reading and writing plus more. Happy to post. Opening is not as straight forward as Excel. Where are the grand kids ? I am north of Sydney. Convert dcl 2 lisp rlx.lsp
  9. Been playing quite a bit with Gilles Chanteau's kdtree lisp app published at theSwamp kd-tree (AutoLISP). So decided to turn it into a dll to use from autolisp. I am attaching the C# code below and a bat file to compile it for Autocad 2017. The dll will create the following function for autolisp: KDtreeLisp.dll Reference & Command SyntaxIn AutoLISP documentation standards, optional parameters are enclosed in square brackets [optional]. (KD-BUILD pointList [dimensions] [customHandle]) Builds a KD-Tree spatial index from a list of points. Arguments: pointList: LIST — List of 2D or 3D point lists ((x y z) ...). dimensions (optional): INT — 2 for 2D $(X,Y)$ or 3 for 3D $(X,Y,Z)$. Default is 2. customHandle (optional): STR — Custom string handle identifier. Returns: STR handle (e.g., "<KD-TREE-1>" or "<KD-TREE-SURVEY>"), or nil on failure. (KD-NEAREST handle targetPoint [count] [maxRadius]) Finds the nearest n points to a target point. Arguments: handle: STR — KD-Tree handle string. targetPoint: LIST — Target point (x y z). count (optional): INT — Number of nearest points to retrieve. Default is 1. maxRadius (optional): REAL or INT — Maximum search radius limit. Points farther than this distance are ignored. Returns:If count = 1 (or omitted): A single point (x y z). If count > 1: A list of points ((x1 y1 z1) (x2 y2 z2) ...). (KD-NEAREST-INFO handle targetPoint [count] [maxRadius]) Finds nearest points with detailed metadata. Arguments: handle: STR — KD-Tree handle string. targetPoint: LIST — Target point (x y z). count (optional): INT — Number of points to retrieve. Default is 1. maxRadius (optional): REAL or INT — Maximum search radius limit. Returns: A list of detailed entries (((x y z) index distance) ...). (KD-RANGE handle centerPoint radius) Finds all points inside a fixed search radius without a count limit. Arguments: handle: STR — KD-Tree handle string. centerPoint: LIST — Center search coordinate (x y z). radius: REAL or INT — Search radius. Returns: A list of all enclosed points ((x1 y1 z1) (x2 y2 z2) ...) sorted by distance, or nil if none are found. (KD-FREE [handle]) Frees tree memory. Arguments: handle (optional): STR — Tree handle to free. If omitted, clears all active trees. Returns: INT — Number of trees removed. Once you've compiled the C#, kdtreelisp.dll will be created and ready to use in Autocad. using System; using System.Collections.Generic; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; using Autodesk.AutoCAD.Runtime; namespace KdTreeLisp { // ========================================== // 1. DATA STRUCTURES & TREE ENGINE // ========================================== public class KdItem { public Point3d Point { get; set; } public int Id { get; set; } public KdItem(Point3d pt, int id) { Point = pt; Id = id; } } public class KdNode { public Point3d Point { get; set; } public int Id { get; set; } public KdNode Left { get; set; } public KdNode Right { get; set; } public KdNode(Point3d point, int id) { Point = point; Id = id; } } public class NeighborResult : IComparable<NeighborResult> { public KdNode Node { get; set; } public double DistanceSq { get; set; } public NeighborResult(KdNode node, double distSq) { Node = node; DistanceSq = distSq; } public int CompareTo(NeighborResult other) { return other.DistanceSq.CompareTo(this.DistanceSq); } } public class KdTree { public KdNode Root { get; private set; } public int ActiveDimensions { get; private set; } public void Build(List<KdItem> items, int activeDimensions) { ActiveDimensions = Math.Max(1, Math.Min(3, activeDimensions)); Root = BuildRecursive(items, 0); } private KdNode BuildRecursive(List<KdItem> items, int depth) { if (items == null || items.Count == 0) return null; int axis = depth % ActiveDimensions; items.Sort(delegate(KdItem a, KdItem b) { return GetAxisValue(a.Point, axis).CompareTo(GetAxisValue(b.Point, axis)); }); int medianIndex = items.Count / 2; KdNode node = new KdNode(items[medianIndex].Point, items[medianIndex].Id); node.Left = BuildRecursive(items.GetRange(0, medianIndex), depth + 1); node.Right = BuildRecursive(items.GetRange(medianIndex + 1, items.Count - (medianIndex + 1)), depth + 1); return node; } public double CalculateDistanceSq(Point3d p1, Point3d p2) { double dx = p1.X - p2.X; double dy = p1.Y - p2.Y; if (ActiveDimensions == 2) { return dx * dx + dy * dy; } double dz = p1.Z - p2.Z; return dx * dx + dy * dy + dz * dz; } // K-Nearest Neighbor Search with Optional Maximum Radius Limit public List<NeighborResult> FindNearest(Point3d target, int count, double maxRadius = double.MaxValue) { List<NeighborResult> heap = new List<NeighborResult>(); if (Root == null || count <= 0) return heap; double maxDistSq = (maxRadius == double.MaxValue) ? double.MaxValue : maxRadius * maxRadius; SearchNearest(Root, target, count, maxDistSq, heap, 0); // Sort ascending by distance before returning heap.Sort(delegate(NeighborResult a, NeighborResult b) { return a.DistanceSq.CompareTo(b.DistanceSq); }); return heap; } private void SearchNearest(KdNode current, Point3d target, int count, double maxDistSq, List<NeighborResult> heap, int depth) { if (current == null) return; double distSq = CalculateDistanceSq(current.Point, target); // Accept point only if inside maximum distance threshold if (distSq <= maxDistSq) { if (heap.Count < count) { heap.Add(new NeighborResult(current, distSq)); heap.Sort(); } else if (distSq < heap[0].DistanceSq) { heap[0] = new NeighborResult(current, distSq); heap.Sort(); } } int axis = depth % ActiveDimensions; double diff = GetAxisValue(target, axis) - GetAxisValue(current.Point, axis); KdNode primary = diff < 0 ? current.Left : current.Right; KdNode secondary = diff < 0 ? current.Right : current.Left; SearchNearest(primary, target, count, maxDistSq, heap, depth + 1); // Pruning condition: check if secondary subtree could contain points closer than current worst candidate double currentSearchRadiusSq = (heap.Count < count) ? maxDistSq : Math.Min(heap[0].DistanceSq, maxDistSq); if (diff * diff < currentSearchRadiusSq) { SearchNearest(secondary, target, count, maxDistSq, heap, depth + 1); } } // Range Search: Retrieves ALL points within radius public List<NeighborResult> RangeSearch(Point3d center, double radius) { List<NeighborResult> results = new List<NeighborResult>(); if (Root == null || radius < 0) return results; double radiusSq = radius * radius; SearchRangeRecursive(Root, center, radiusSq, results, 0); results.Sort(delegate(NeighborResult a, NeighborResult b) { return a.DistanceSq.CompareTo(b.DistanceSq); }); return results; } private void SearchRangeRecursive(KdNode current, Point3d center, double radiusSq, List<NeighborResult> results, int depth) { if (current == null) return; double distSq = CalculateDistanceSq(current.Point, center); if (distSq <= radiusSq) { results.Add(new NeighborResult(current, distSq)); } int axis = depth % ActiveDimensions; double diff = GetAxisValue(center, axis) - GetAxisValue(current.Point, axis); if (diff < 0) { SearchRangeRecursive(current.Left, center, radiusSq, results, depth + 1); if (diff * diff <= radiusSq) { SearchRangeRecursive(current.Right, center, radiusSq, results, depth + 1); } } else { SearchRangeRecursive(current.Right, center, radiusSq, results, depth + 1); if (diff * diff <= radiusSq) { SearchRangeRecursive(current.Left, center, radiusSq, results, depth + 1); } } } private double GetAxisValue(Point3d pt, int axis) { switch (axis) { case 0: return pt.X; case 1: return pt.Y; default: return pt.Z; } } } // ========================================== // 2. AUTOLISP INTERFACE BRIDGE // ========================================== public class LispBridge { private static readonly Dictionary<string, KdTree> _trees = new Dictionary<string, KdTree>(); private static int _treeCounter = 1; // Signature: (KD-BUILD pointList [dimensions] [customHandle]) [LispFunction("KD-BUILD")] public static TypedValue BuildTree(ResultBuffer args) { if (args == null) return new TypedValue((int)LispDataType.Nil); TypedValue[] arr = args.AsArray(); List<KdItem> items = new List<KdItem>(); int idCounter = 0; int requestedDimensions = 2; string customHandle = null; foreach (TypedValue tv in arr) { if (tv.TypeCode == (int)LispDataType.Point3d) { items.Add(new KdItem((Point3d)tv.Value, idCounter++)); } else if (tv.TypeCode == (int)LispDataType.Point2d) { Point2d pt2 = (Point2d)tv.Value; items.Add(new KdItem(new Point3d(pt2.X, pt2.Y, 0.0), idCounter++)); } else if (tv.TypeCode == (int)LispDataType.Int16 || tv.TypeCode == (int)LispDataType.Int32) { requestedDimensions = Convert.ToInt32(tv.Value); } else if (tv.TypeCode == (int)LispDataType.Text) { customHandle = Convert.ToString(tv.Value); } } if (items.Count == 0) return new TypedValue((int)LispDataType.Nil); KdTree tree = new KdTree(); tree.Build(items, requestedDimensions); string handle = string.IsNullOrEmpty(customHandle) ? string.Format("<KD-TREE-{0}>", _treeCounter++) : string.Format("<KD-TREE-{0}>", customHandle.ToUpper()); _trees[handle] = tree; return new TypedValue((int)LispDataType.Text, handle); } // Signature: (KD-NEAREST handle targetPoint [count] [maxRadius]) [LispFunction("KD-NEAREST")] public static ResultBuffer FindNearest(ResultBuffer args) { if (args == null) return null; List<TypedValue> values = ExtractValues(args); if (values.Count < 2) return null; if (values[0].TypeCode != (int)LispDataType.Text) return null; string handle = Convert.ToString(values[0].Value); if (!_trees.ContainsKey(handle)) return null; KdTree tree = _trees[handle]; if (tree.Root == null) return null; Point3d target; if (values[1].TypeCode == (int)LispDataType.Point3d) { target = (Point3d)values[1].Value; } else if (values[1].TypeCode == (int)LispDataType.Point2d) { Point2d p2 = (Point2d)values[1].Value; target = new Point3d(p2.X, p2.Y, 0.0); } else { return null; } int count = 1; if (values.Count > 2 && (values[2].TypeCode == (int)LispDataType.Int16 || values[2].TypeCode == (int)LispDataType.Int32)) { count = Convert.ToInt32(values[2].Value); } double maxRadius = double.MaxValue; if (values.Count > 3) { TypedValue v = values[3]; if (v.TypeCode == (int)LispDataType.Double || v.TypeCode == (int)LispDataType.Int16 || v.TypeCode == (int)LispDataType.Int32) { maxRadius = Convert.ToDouble(v.Value); } } List<NeighborResult> results = tree.FindNearest(target, count, maxRadius); if (results.Count == 0) return null; ResultBuffer res = new ResultBuffer(); if (count == 1) { res.Add(new TypedValue((int)LispDataType.Point3d, results[0].Node.Point)); } else { res.Add(new TypedValue((int)LispDataType.ListBegin)); foreach (NeighborResult item in results) { res.Add(new TypedValue((int)LispDataType.Point3d, item.Node.Point)); } res.Add(new TypedValue((int)LispDataType.ListEnd)); } return res; } // Signature: (KD-NEAREST-INFO handle targetPoint [count] [maxRadius]) [LispFunction("KD-NEAREST-INFO")] public static ResultBuffer FindNearestInfo(ResultBuffer args) { if (args == null) return null; List<TypedValue> values = ExtractValues(args); if (values.Count < 2) return null; if (values[0].TypeCode != (int)LispDataType.Text) return null; string handle = Convert.ToString(values[0].Value); if (!_trees.ContainsKey(handle)) return null; KdTree tree = _trees[handle]; Point3d target; if (values[1].TypeCode == (int)LispDataType.Point3d) target = (Point3d)values[1].Value; else if (values[1].TypeCode == (int)LispDataType.Point2d) target = new Point3d(((Point2d)values[1].Value).X, ((Point2d)values[1].Value).Y, 0.0); else return null; int count = 1; if (values.Count > 2 && (values[2].TypeCode == (int)LispDataType.Int16 || values[2].TypeCode == (int)LispDataType.Int32)) count = Convert.ToInt32(values[2].Value); double maxRadius = double.MaxValue; if (values.Count > 3) { TypedValue v = values[3]; if (v.TypeCode == (int)LispDataType.Double || v.TypeCode == (int)LispDataType.Int16 || v.TypeCode == (int)LispDataType.Int32) maxRadius = Convert.ToDouble(v.Value); } List<NeighborResult> results = tree.FindNearest(target, count, maxRadius); if (results.Count == 0) return null; ResultBuffer res = new ResultBuffer(); res.Add(new TypedValue((int)LispDataType.ListBegin)); foreach (NeighborResult item in results) { res.Add(new TypedValue((int)LispDataType.ListBegin)); res.Add(new TypedValue((int)LispDataType.Point3d, item.Node.Point)); res.Add(new TypedValue((int)LispDataType.Int32, item.Node.Id)); res.Add(new TypedValue((int)LispDataType.Double, Math.Sqrt(item.DistanceSq))); res.Add(new TypedValue((int)LispDataType.ListEnd)); } res.Add(new TypedValue((int)LispDataType.ListEnd)); return res; } // Signature: (KD-RANGE handle centerPoint radius) [LispFunction("KD-RANGE")] public static ResultBuffer RangeSearch(ResultBuffer args) { if (args == null) return null; List<TypedValue> values = ExtractValues(args); if (values.Count < 3) return null; if (values[0].TypeCode != (int)LispDataType.Text) return null; string handle = Convert.ToString(values[0].Value); if (!_trees.ContainsKey(handle)) return null; KdTree tree = _trees[handle]; Point3d center; if (values[1].TypeCode == (int)LispDataType.Point3d) center = (Point3d)values[1].Value; else if (values[1].TypeCode == (int)LispDataType.Point2d) center = new Point3d(((Point2d)values[1].Value).X, ((Point2d)values[1].Value).Y, 0.0); else return null; double radius = 0.0; TypedValue rVal = values[2]; if (rVal.TypeCode == (int)LispDataType.Double || rVal.TypeCode == (int)LispDataType.Int16 || rVal.TypeCode == (int)LispDataType.Int32) { radius = Convert.ToDouble(rVal.Value); } else { return null; } List<NeighborResult> results = tree.RangeSearch(center, radius); if (results.Count == 0) return null; ResultBuffer res = new ResultBuffer(); res.Add(new TypedValue((int)LispDataType.ListBegin)); foreach (NeighborResult item in results) { res.Add(new TypedValue((int)LispDataType.Point3d, item.Node.Point)); } res.Add(new TypedValue((int)LispDataType.ListEnd)); return res; } // Signature: (KD-FREE [handle]) [LispFunction("KD-FREE")] public static TypedValue FreeTree(ResultBuffer args) { if (args == null) { int count = _trees.Count; _trees.Clear(); return new TypedValue((int)LispDataType.Int32, count); } List<TypedValue> values = ExtractValues(args); if (values.Count == 0 || values[0].TypeCode != (int)LispDataType.Text) { int count = _trees.Count; _trees.Clear(); return new TypedValue((int)LispDataType.Int32, count); } string handle = Convert.ToString(values[0].Value); bool removed = _trees.Remove(handle); return new TypedValue((int)LispDataType.Int32, removed ? 1 : 0); } private static List<TypedValue> ExtractValues(ResultBuffer resbuf) { List<TypedValue> list = new List<TypedValue>(); foreach (TypedValue tv in resbuf.AsArray()) { if (tv.TypeCode != (int)LispDataType.ListBegin && tv.TypeCode != (int)LispDataType.ListEnd) { list.Add(tv); } } return list; } } } ymg KDtreeLisp.cs Build.bat
  10. mhupp
    Add radius to a Mline
    I Had a lisp that adds radius to polylines ignoring larger radius then what you where setting. Used it to adjust for CNC permitter routing to avoid share edges.
  11. The Hatch command has long been a core tool in AutoCAD for filling areas with patterns or solid fills. In fact, Hatch is likely the command that has evolved the most over the years. Over multiple releases, from those earlier versions and especially since AutoCAD 2025, the AutoCAD team has focused on three main areas for improvement: workflow, performance, and reliability. These recent updates make creating and managing hatches more flexible, faster in demanding drawings, and more stable across real-world files. <?xml encoding="utf-8" ?> Performance can vary with large, dense, or Xref-heavy drawings, and some drawing-specific edge cases remain. Still, the changes delivered so far address common pain points and give users clearer, more predictable results. Let’s take a closer look at those three categories. Workflow Improvements The biggest shift for everyday use is how you can start a hatch. Starting in AutoCAD 2025, a new creation workflow lets you generate a hatch or fill from an area, a path, or a shape. You no longer need predefined closed boundary geometry in every case. This reduces setup time and opens options when traditional boundary selection is awkward or time-consuming. A dedicated Path option was added so you can create a hatch by following an existing path. Interactive selection also behaves more consistently—repeated clicks in the same area are handled without wasted effort or confusion. If you cancel mid-command, AutoCAD returns control sooner instead of finishing unnecessary processing in the background. The Hatch Command’s Path Option AutoCAD 2025.1 brought additional usability refinements: clearer prompts, better error messaging for certain boundary-definition situations, and closer alignment between the ribbon/UI behavior and the command line. Altogether, these changes make hatch creation feel more flexible and less rigid. Performance Gains Performance work targeted the internal boundary engine, especially in larger or more complex drawings. Boundary detection for large sets of geometry was improved so the software organizes and searches objects more efficiently. This helps scaling when many potential boundary elements are present. Boundary picking and tracing steps were optimized to reduce the time spent identifying regions and tracing closed loops. The overall boundary-processing pipeline was streamlined for representative real-world cases, cutting unnecessary overhead. On the legacy path, retry logic was made more efficient so the system avoids redundant or costly retries when starting from a pick point. The result is more predictable timing. Xref-heavy drawings received specific attention. Hatching and boundary tracing when attached drawings are involved now avoid some of the longer waits that previously appeared in those workflows. Users working with larger files, complex boundaries, or external references should notice better responsiveness in many common scenarios. Reliability and Stability Stability work focused on crashes, hangs, and inconsistent results. AutoCAD 2026.1 addressed crashes that could occur when creating a hatch in drawings containing empty boundaries or island loops. Additional fixes reduced hangs in certain xref workflows so the command remains responsive. Legacy hatch paths received further hardening to lower the incidence of crashes and hangs in higher-impact situations. Boundary-handling reliability improved in AutoCAD 2025.1, including better handling of boundary-definition issues, clearer errors in some AEC cases, and more consistent closed-path behavior. Display and reporting problems were also corrected—draw order, custom hatch display, hatch origin placement. Looking further back, foundational work from 2015 through 2024 improved behavior around small gaps, non-continuous linetypes, and general stability. These earlier changes continue to support the later refinements. Overall Hatch Improvements Are a lot of these updates and improvements in the background? Absolutely. Other than some of the UI and creation options, these important changes will serve only to improve the user experience. These updates were made to make hatch creation more flexible, improve responsiveness in many larger or complex drawings, and reduce the frequency of failures. You should notice fewer wasted clicks, shorter waits in common scenarios, and greater dependability across a wider range of files. More Tuesday Tips Check out our whole Tuesday Tips series for ideas on how to make AutoCAD work for you. The post A Better Hatch Experience: Tuesday Tips With Frank appeared first on AutoCAD Blog. View the full article
  12. There can be a lot more to it than that. "A closed boundary could not be determined" when creating a hatch in AutoCAD It actually says for one option- "Zoom out until all boundaries are visible. Then specify a new pick point", but I have actually had to zoom way in. "Valid hatch boundary not found." when adding Hatches in AutoCAD Products Also AutoCAD has an issue sometimes Select Object works, even though you should be able to use Pick points. This is about Boundary, but affects Hatches as well... Read the entire thread. Also, you can read this thread, though also boundary related. So basically the issue, besides the obvious gaps, elevations, et al, is summed up by @eldon
  13. SLW210
    Somebody else can add the Multi, it works great for my job right now. I do not want direct to Excel as I plan to use LibreOffice when away from work, in the beginning of updating I had thoughts of making it an option, that is still on the table. I may remove the code and just paste the file, so at least a sign-in is required. As for a long code to copy, just double-click the first character then shift-click the end. As for the Architectural: 1500'-0", you didn't change the values in the code to convert to mm, I put them at the top. I need to do a few changes on that output when metric, I'll see if the next version was already doing that. That's the reason I posted this version, to see what I didn't think of before the final version. I think I started the next version to include a DCL to switch instead of commandline as well as the report, as well as multiple selections and more columns in CSV. Is there a big need for meters in something like this? I know in the USA sheet metal is normally Metric in mm and Imperial is inches, sometimes on certain things they use Meters and Architectural, but I have seldom seen that. I do need to add the inches option as well, so Meters should be an option I suppose. I need to do more gap and overlap testing, most of my actual job is actually ends touching, I just needed to get them through a Viewport and in an anonymous block (I used to need to change to a regular block, then go to block editor, etc.), SOLPROF is lines and arcs, etc. so a lot of work . I'll finish up my work work and see if I have time to work on this some more. Thanks for the Metric test and BricsCAD test. If any GstarCAD, NanoCAD, CMS IntelliCAD users could test, that would be nice. I go over their sites and see if I can see what users report working and not working, but that probably doesn't cover everything or account for those that just made an error using the code. For USA that use both Metric and Imperial, would reporting both be beneficial? That might yet again be more options needed. P.S. My 3 grandkids from near me in Florida are now in Australia until the End of October, so last night my time they Facetimed me, so I got very little done at home.
  14. Have you ever tried to hatch a closed area, but CAD says the boundary is not closed? A small gap between two lines can stop the hatch from working properly. A quick way to find the problem is to use BOUNDARY or check the area with PEDIT → JOIN. If there is a small gap, close it and try HATCH again. For complicated drawings, increasing the Gap Tolerance in the Hatch settings can also help. How many of you have faced this problem? What was causing the gap in your drawing?
  15. THANKS for that!
  16. In another post there was questions about changing Mline styles for existing Mlines. So answered that and thought what about adding fillets to a mline. Wel as we know you can not do that, so did it this way. Converting the individual mlines to plines then filleting the plines produced. The fillet radius changing matching the offsets. ; Convert mline to plines and add a rdius. ; By AlanH Aug 2026 (defun LWPoly (lst cls) (entmakex (append (list (cons 0 "LWPOLYLINE") (cons 100 "AcDbEntity") (cons 100 "AcDbPolyline") (cons 90 (length lst)) (cons 70 cls)) (mapcar (function (lambda (p) (cons 10 p))) lst))) ) (defun c:ml2plrad ( / oldsnap pt1 pt2 ent obj obj2 co-ords dict col lst x) (setq oldsnap (getvar 'osmode)) (setvar 'osmode 0) (setq pt1 (getpoint "\nPick 1st point for drag ")) (setq pt2 (getpoint pt1 "\nPick 2nd point ")) (setq pts (list pt1 pt2)) (setq ent (ssname (ssget "F" pts (list (cons 0 "Mline"))) 0)) (setq obj (vlax-ename->vla-object ent)) (setq styleName (vla-get-StyleName obj)) (setq lay (vlax-get obj 'layer)) (setvar 'clayer lay) (setq co-ords (vlax-get obj 'coordinates)) (vla-delete obj) (setq pts2 '() x 0) (repeat (/ (length co-ords) 3) (setq pts2 (cons (list (nth x co-ords)(nth (1+ x) co-ords)) pts2)) (setq x (+ x 3)) ) (setq dict (dictsearch (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_MLINESTYLE"))) styleName)) (setq offsets (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 49)) dict))) (setq col (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 62)) dict))) (setq col (cdr col)) ; ignore 1st color (setq lst '() x 0) (repeat (length col) (setq lst (cons (list (nth x offsets)(nth x col)) lst)) (setq x (1+ x)) ) (LWPoly pts2 0) (setvar 'filletrad (getreal "\nEnter Fillet radius for most outside offset ")) (command "fillet" "P" (entlast)) (setq x 1) (repeat (- (length col) 1) (setq obj2 (vlax-ename->vla-object (entlast))) (vlax-put obj2 'color (nth (1- x) col)) (vla-offset (vlax-ename->vla-object (entlast)) (- (nth x offsets)(nth (1- x) offsets))) (setq x (1+ x)) ) (setq obj2 (vlax-ename->vla-object (entlast))) (vlax-put obj2 'color (nth (1- x) col)) (setvar 'osmode oldsnap) (princ) ) (c:ml2plrad)
  17. BIGAL
    @SLW210 did a little bit of testing and works ok in Metric dwt. The only thing is the Architectural result. Limited Testing in Bricscad V25. made some shapes and inserted some blocks. A rectang 5000x4000 mm or decimal units. For metric don't need Architectural units. Curve length: 18000 Gaps: 0 Total: 18000 Architectural: 1500'-0" ?? For metric could do dwg is in mm but result is in metres to 3 decimals. You could use the Multi radio buttons.lsp to make choices. As its demand loaded you do not have to add it to your code. Re CSV your more than welcome to use the defuns in Alan Excel.lsp to write direct to Excel. Could demand load a lisp with just the defuns needed as don't need all that is in the lisp. Just a Ps a big file to screen copy maybe also post a file copy.
  18. Last week
  19. I don't know if there was ever another LISP/Program to do this type of get length at least I never found one, my original just did what I needed, I have since made it more generally useful (I hope). As per the drawing I will attach, I just need to get the length of the center between the inner and outer of the perimeter of guards, etc. to determine the unrolled length. Normally the guards are 3D and I create the profiles with SOLPROF which creates an anonymous block (I used to change these with UNANON) or sometimes in the past I have used SOLVIEW and SOLDRAW, the same issue arises that you just can't select them and get the profile length. So originally that's what this LISP was created to do (I still have some of the older basic versions). I have upgraded it to it's current state and also still working on another version, but only small enhancements. For inside a block that is scaled, you will need to multiply the results by the scale factor, working through a viewport the viewport needs to be active, so I might tackle those issues as well as make a more detailed CSV. I also will try to make sure it works in non-AutoCAD like BricsCAD, CMS IntelliCAD, nanoCAD, etc. when I get time. I lightly tested in most situations, I have no idea how it acts on non-uniformly scaled blocks, though. It handles gaps and slight overlaps, I have some settings at the top, hopefully with enough instructions to modify on your own. Where I work (except for the machine shop which uses decimal inches) they use Architectural units, I did not double check this in Metric, so if someone would report back on that it would help. GetLenTest.dwg GetLen.lsp
  20. I wouldn't trust any company that's not an Autodesk official reseller.
  21. If you have an AutoCAD license, you get the toolsets like Map 3D free, you could use MAPCLEAN, which can fill gaps and also has a weed function and more. What if they are overlapping and not a gap, you can get unexpected results from a large selection set and MPedit>Join from overlapping/collinear (P)Lines? I use MPedit as well, you just have to run a polyline weed LISP (like PLDiet.lsp) sometimes to get single polylines. You may also want to look into Overkill and Fillet with radius = 0, it can help with cleanup as well. I know everyone that has this problem is working on a drawing that was not of their own and either generated by another CAD platform or by a past or former coworker. But, the best method for these issues are to properly use and setup your CAD not to have unjoined/unconnected/ends touching (P)Lines, Arcs, Splines, etc. Good post from @irneb here on that issue...
  22. Do you have an example drawing that does this? That sounds more like a Graphics Card or driver issue, though as you say, could be AutoCAD 2010 (I presume that's what you mean since v10 is very old now and was released in 1988). If you still use v10 I would definitely say that's the issue.
  23. I moved your thread to the AutoCAD 3D Modelling & Rendering Forum. Please start threads in the most appropriate forum.
  24. This can happen when working on a 3D model. Two solids may look like one object, but they can still be separate. A simple way to check is to click each part and see if you can select them separately. If they need to become one solid, UNION can combine them. You can also use INTERFERE to check if two solids are overlapping. How many of you have faced this while making a 3D model?
  25. Have you ever used PEDIT → JOIN, but CAD does not join the lines? Sometimes the lines look connected, but there is a small gap between them. They can also have different Z values. First, check the endpoints using OSNAP. If the lines have different Z values, FLATTEN can help bring them to the same level. How many of you have faced this problem? What fixed it for you?
  26. One other thing I've noticed.. Inserting a 3d block into model space. Occasionally everything in model space disappears and the 3d part appears, nothing else. Purging does not solve it, the 3d part is invisible otherwise. It's very strange and may be a bug in v10.
  27. [Side DIM] VCID: 5EDNWJ @ VedaCAD
  28. [Omni Wheel] VCID: US87Y8 @ VedaCAD
  29. Hi, Does anyone have experience with stack social? (LT @ 199/yr) Thanks!
