  2. pkenewell
    nestedblock window
    @jim78b You cannot make an AutoLISP or Visual LISP program have a modeless interface like your example unless you use a third party add-on called OpenDCL or another called ObjectDCL. Using those is also very advanced programming. Otherwise, DCL in AutoLISP can only make simple Modal dialogs (meaning you can't work in the graphics editor when they are displayed).
  3. Your Field inside your Formula needs an object selected. I just picked the top line and it works for me. Not sure if that works for the correct value, so you may need something else to pick. _d-spans fixed.dwg
  4. jim78b
    nestedblock window
    ok you are the best thanks for your time and support!
  5. SLW210
    nestedblock window
    I am waiting for IT to install some things including updates for Visual Studio, when that gets done, I'll look into writing something better. The LISP that was posted in your other thread was a better start than this.
  6. jim78b
    nestedblock window
    Ok for now thanks, I thought it was much simpler. Thanks a lot
  7. SLW210
    nestedblock window
    As I have already mentioned, that LISP has too many issues. I trash canned all of my attempts, @pkenewell is correct, I had something else in there. I'll try to think about it. Yes, I had nil there. Every issue I tracked down, a new one came up. Just forget that LISP and start from scratch.
  8. jim78b
    nestedblock window
    https://apps.autodesk.com/ACD/it/Detail/Index?id=8055037424722464637&appLang=en&os=Win64
  9. pkenewell
    nestedblock window
    @jim78b I don't understand what you mean. Again - if you want this program to be property troubleshooted, please provide an example drawing and a visual explanation if what you are expecting to happen.
  10. Today
  11. devitg
    acadauto.chm not found
    @pkenewell I dont know how , when, or why but I can see the acadauto.chm to work I did a copy file from Copy and paste chm and paste to the dwg , and despite vlide show the same alert NOT FOUND , it work.
  12. jim78b
    nestedblock window
    Sorry, but thank you for your hard work. It works now, but: I thought I had a window always open with the block list that automatically updates without me having to select anything. I'd like the window to stay open even when I'm working. If I click on a block name, it highlights in the drawing. Sorry if I wasn't specific. Thanks
  13. pkenewell
    nestedblock window
    @jim78b I also noticed on the first line, the setq statement need to be set to something. You can't just have (setq *block_name_list*). I just put "nil" below, but it seems to want a list of Block Names? ;; This global list will store the clean names for selection (setq *block_name_list* nil);<-- Needs to be set to something ALSO: If you want someone to work on this for you. I think you need to provide a sample drawing with what you want to accomplish. I don't have time to troubleshoot this by re-creating the circumstances where this program is needed.
  14. pkenewell
    nestedblock window
    @jim78b There is another one. Sorry - I did this accidentally in my earlier post on those 2 lines. I corrected my previous posts. " (sssetfirst nil nil)" ; Clear any previous selection grips
  15. pkenewell
    @devitg This appears to be a Bug in VLIDE. I get the same problem. I think the interface was not updated for the current help system.
  16. jim78b
    nestedblock window
    thanks i edit but give me again syntax error
  17. pkenewell
    nestedblock window
    @jim78b The end quote is in the wrong place on this line. See correction below. " (if ss (sssetfirst nil ss))" ;<--Quote BEFORE comment. Highlight all found instances in current space
  18. jim78b
    nestedblock window
    ;;----------------------------------------------------------------------;; ;; SNB_Select.lsp ;; ;; ;; ;; Interactively select and highlight nested blocks from a dialog. ;; ;; ;; ;; Depends on the updated `nestedblocks.dcl` file. ;; ;; ;; ;; To Run: APPLOAD -> Load File -> Type "SNB_SELECT" in the command. ;; ;;----------------------------------------------------------------------;; ;; This global list will store the clean names for selection (setq *block_name_list*) ;; Recursive function to populate the dialog list and our background list (defun FindAndListNestedBlocks (blkname level visited) (if (not (member blkname visited)) (if (tblsearch "BLOCK" blkname) (progn (setq visited (cons blkname visited)) ; Add current block to visited list (setq ent (tblobjname "BLOCK" blkname)) (setq ent (entnext ent)) (while ent (setq edata (entget ent)) (if (= "INSERT" (cdr (assoc 0 edata))) (progn (setq nested_blkname (cdr (assoc 2 edata))) (setq indent (make_string (* level 2) 32)) ;; Add the formatted name to the visible list box (add_list (strcat indent "|-- " nested_blkname)) ;; Add the clean name to our background list (setq *block_name_list* (append *block_name_list* (list nested_blkname))) ;; Recurse for the next level (FindAndListNestedBlocks nested_blkname (+ level 1) visited) ) ) (setq ent (entnext ent)) ) ) ) ) ) ;; Main command function (defun c:SNB_SELECT (/ sel edata blkname dcl_id selected_index ss) (princ "\n--- Interactive Nested Block Viewer ---") (setq sel (entsel "\nSelect a parent block to inspect: ")) (if sel (progn (setq dcl_id (load_dialog "nestedblocks.dcl")) (if (not (new_dialog "NestedBlockViewer" dcl_id)) (exit) ) (setq edata (entget (car sel))) (setq blkname (cdr (assoc 2 edata))) ;; Initialize the background list with the top-level block (setq *block_name_list* (list blkname)) ;; Populate the visible list in the dialog (start_list "block_tree") (add_list blkname) (FindAndListNestedBlocks blkname 1 nil) (end_list) ;; --- Define Actions for Dialog Buttons --- ;; Action for the "Highlight Selection" button (action_tile "highlight" (strcat "(progn" " (setq selected_index (atoi (get_tile \"block_tree\")))" " (setq selected_block (nth selected_index *block_name_list*))" " (princ (strcat \"\nHighlighting all instances of: \" selected_block))" " (sssetfirst nil nil) ; Clear any previous selection grips" " (setq ss (ssget \"_X\" (list (cons 0 \"INSERT\") (cons 2 selected_block) (cons 410 (getvar 'ctab)))))" " (if ss (sssetfirst nil ss)) ; Highlight all found instances in current space" ")" ) ) ;; Action for the OK button (and double-clicking a list item) (action_tile "accept" "(done_dialog)") ;; Display the dialog and wait for user action (start_dialog) (sssetfirst nil nil) ; Clear selection grips on exit (unload_dialog dcl_id) ) (princ "\nNo object selected.") ) (princ) ) (princ "\nLISP loaded. Type SNB_SELECT to run.") (princ) Give me again syntax error sorry
  19. SLW210
    TCOUNT for multileaders
    Works for me here as well.
  20. SLW210
    I placed a new LISP in my earlier post to just do a Sequential Find and Replace, see if that works for you. I am working on a bigger LISP with dialog box input and select the options, but that's going to be a while due to my workload.
  21. SLW210
    You still haven't provided the before and after drawing or the steps you want.
  22. I finally got it to act as you say. I'll see if I have time a little latter to work on it. Do you still have the original with the dimension text?
  23. SLW210
    nestedblock window
    You failed to fix the very first part I told you was giving that error. It should be setq. ;; This global list will store the clean names for selection (defun-q *block_name_list*) Should be ... (setq *block_name_list*)
  24. jim78b
    nestedblock window
    Sorry for late reply but i have problem with my internet connection. i tried to modify the lisp but give me syntax error, sorry. ;;----------------------------------------------------------------------;; ;; SNB_Select.lsp ;; ;; ;; ;; Interactively select and highlight nested blocks from a dialog. ;; ;; ;; ;; Depends on the updated `nestedblocks.dcl` file. ;; ;; ;; ;; To Run: APPLOAD -> Load File -> Type "SNB_SELECT" in the command. ;; ;;----------------------------------------------------------------------;; ;; This global list will store the clean names for selection (defun-q *block_name_list*) ;; Recursive function to populate the dialog list and our background list (defun FindAndListNestedBlocks (blkname level visited) (if (not (member blkname visited)) (if (tblsearch "BLOCK" blkname) (progn (setq visited (cons blkname visited)) ; Add current block to visited list (setq ent (tblobjname "BLOCK" blkname)) (setq ent (entnext ent)) (while ent (setq edata (entget ent)) (if (= "INSERT" (cdr (assoc 0 edata))) (progn (setq nested_blkname (cdr (assoc 2 edata))) (setq indent (make_string (* level 2) 32)) ;; Add the formatted name to the visible list box (add_list (strcat indent "|-- " nested_blkname)) ;; Add the clean name to our background list (setq *block_name_list* (append *block_name_list* (list nested_blkname))) ;; Recurse for the next level (FindAndListNestedBlocks nested_blkname (+ level 1) visited) ) ) (setq ent (entnext ent)) ) ) ) ) ) ;; Main command function (defun c:SNB_SELECT (/ sel edata blkname dcl_id selected_index ss) (princ "\n--- Interactive Nested Block Viewer ---") (setq sel (entsel "\nSelect a parent block to inspect: ")) (if sel (progn (setq dcl_id (load_dialog "nestedblocks.dcl")) (if (not (new_dialog "NestedBlockViewer" dcl_id)) (exit) ) (setq edata (entget (car sel))) (setq blkname (cdr (assoc 2 edata))) ;; Initialize the background list with the top-level block (setq *block_name_list* (list blkname)) ;; Populate the visible list in the dialog (start_list "block_tree") (add_list blkname) (FindAndListNestedBlocks blkname 1 nil) (end_list) ;; --- Define Actions for Dialog Buttons --- ;; Action for the "Highlight Selection" button (action_tile "highlight" (strcat "(progn" " (setq selected_index (atoi (get_tile \"block_tree\")))" " (setq selected_block (nth selected_index *block_name_list*))" " (princ (strcat \"\nHighlighting all instances of: \" selected_block))" " (sssetfirst nil nil) ; Clear any previous selection grips" " (setq ss (ssget \"_X\" (list (cons 0 \"INSERT\") (cons 2 selected_block) (cons 410 (getvar 'ctab)))))" " (if ss (sssetfirst nil ss)) ; Highlight all found instances in current space" ")" ) ) ;; Action for the OK button (and double-clicking a list item) (action_tile "accept" "(done_dialog)") ;; Display the dialog and wait for user action (start_dialog) (sssetfirst nil nil) ; Clear selection grips on exit (unload_dialog dcl_id) ) (princ "\nNo object selected.") ) (princ) ) (princ "\nLISP loaded. Type SNB_SELECT to run.") (princ)
  25. Mirrtext doesn’t have any influence on dims embedded in blocks only way to stop the mirroring is to use an attribute
  26. Yesterday
  27. What about MIRRTEXT variable it forces a flip mirror text. Worked as is for me Bricscad V25.
  28. BIGAL
    Did you try what I posted ? Worked for me.
