  2. BIGAL
    ATTDEF COUNT...help
    " how many times each tag is repeated. " that is in the answer I provided. (("048" 1) ("047" 1) ("046" 1) ("045" 2) ("044" 1) ("043" 2) ("042" 1) ("041" 2) ("040" 1) ("039" 1) ("038" 2) ("037" 1) ("036" 2) ("035" 2) ("034" 6) ("033" 6) ("032" 6) ("031" 2) ("030" 2) ("029" 12) ("028" 6) ("027" 6) ("026" 23) ("025" 2) ("024" 4) ("023" 6) ("022" 6) ("021" 1) ("020" 1) ("019" 2) ("018" 2) ("017" 1) ("016" 1) ("015" 2) ("014" 6) ("013" 2) ("012" 2) ("011" 2) ("010" 1) ("009" 1) ("008" 1) ("007" 1) ("006" 4) ("005" 16) ("004" 1) ("003" 1) ("002" 1) ("001" 1)) change code at end add princ lst3 ) (princ lst3) (princ) ) I can do the send to excel if you want ? You have asked for text also can you post anther sample dwg with say both, text and Attdef. Will have a think about missing value.
  3. Today
  4. GLAVCVS
    ATTDEF COUNT...help
    var1, var2, and var3 should be "punto," "angulo," and "distancia"? So: angle and distance... between what objects?
  5. You don't draw a line read the questions asked, pick the pline, pick the block, pick a point to draw the line & blocks and enter a gap distance between them say 1000. The line with copied blocks is automatically drawn. The line will be as long as there is blocks.
  6. Here is the help for Extend it has some variables you can set may be applicable for Acad. https://help.bricsys.com/en-us/document/command-reference/e/extend-command?version=V25&id=165079077042
  7. Yesterday
  8. GLAVCVS
    ATTDEF COUNT...help
    ;BACALADO DE BILBADOOO (PLUS) (defun nqf (tuSS / i lista tipObj cant cad txs atts) (princ "\nNumero que falta") (terpri) (if tuSS (setq cant (sslength tuSS)) (progn (alert "No existe conjunto de seleccion o esta vacio") (exit) ) ) (princ "\nCantidad de textos seleccionados = ") (princ cant) (princ "\nLista de numeros faltantes") ;Pasar del SS a una lista de valores (setq i 0 txs 0 atts 0) (repeat (sslength tuSS) (setq tipObj (cdr (assoc 0 (setq le (entget (ssname tuSS i))))) num (atoi (cdr (assoc (if (= tipObj "TEXT") 1 2) le))) i (1+ i) lista (if (setq l (assoc num lista)) (subst (list num (1+ (cadr l))) l lista) (append lista (list (list num 1))) ) ) (if (= tipObj "TEXT") (setq txs (+ txs 1)) (setq atts (+ atts 1))) ) ;Imprimir los valores que no aparezcan (terpri) (setq i 1) (princ (strcat "\nLista de numeros existentes\n" (while lista (if (setq v (assoc i lista)) (setq cad (if (= (cadr v) 1) (if cad (strcat cad ", " (itoa (car v))) (itoa (car v)) ) (if cad (strcat cad ", " (itoa (car v)) "(" (itoa (cadr v)) ")") (strcat (itoa (car v)) "(" (itoa (cadr v)) ")") ) ) lista (vl-remove v lista) ) (princ (strcat "\nFalta el # " (itoa i))) ) (setq i (1+ i)) cad ) "\nTextos: " (itoa txs) "\nAtributos: " (itoa atts) ) ) (princ) ) (defun c:nqf nil (nqf (ssget '((0 . "TEXT,ATTDEF")))))
  9. @SLW210 it ask for the polyline where the blocks are inserted, then get the coordinates from such polyline , and use it to get all blocks as selectionset . It draw a polyline straight long enough to receive the new block at a given distance, 1000 units in this cas Then it copy each one and move to the new line
  10. Your latest works in AutoCAD 2000i on my home computer, though it makes a new line was that intended? I like yours a lot.
  11. I used the one supplied by the OP.
  12. Holy Old Post bump!!!! Yeah i was looking to do just this today.. totally forgot how... thanks to this thread.. i figured it out. Use the POLAR parameter, start point at the center of rotation, end point at the point you want the stretch to end. Add the POLAR STRETCH action to the SECOND point. Select the objects you want to stretch, like the line and end arrow. Select the object you want to rotate, like the line, end arrow and the triangular arrow near the circle. Boom Done Bob's your Uncle. DynBlock101.dwg
  13. @SLW210 @HypnoS edited please test. cpy-blk-2-poly.lsp
  14. @SLW210 please upload sample dwg , where yo did apply the lisp
  15. leonucadomi
    ATTDEF COUNT...help
    you can make the routine show the number of selected texts and the number of attributes, please
  16. I tried that everyway possible and no luck with AutoCAD 2026, if I get time I'll look through my settings again. Might be a quirk in my AutoCAD 2026. It does seem it used to work as you say.
  17. I get Command: CPY-BLK-2-POLY Select objects: ; error: bad argument type: lselsetp nil
  18. Here is my effort, worked on your drawing for me. ;;; Copy blocks to a polyline/line path in ascending order left to right based on ATTRIBUTE TAG value. | ;;; | ;;; https://www.cadtutor.net/forum/topic/98615-copy-blocks-to-curve-according-to-another-curve/#findComment-675378 | ;;; | ;;; By SLW210 (a.k.a. Steve Wilson) | ;;; | ;;;****************************************************************************************************************| ;| Lines/Polylines need be drawn Left-Right or reversed, could be coded to check direction and reverse them. I'm not motivated to do that, but feel free to alter the code. I did test on angled Polylines/Lines as well as vertical and it works, but might need adjustments. I adjusted a code I already had to handle this specific request for which it works, I doubt if I'll do anymore modifications. |; ;;;***************************************************************************************************************| ;;; This code asks to select the block and type in the tag name from options given (case sensitive). | ;;; | ;;;***************************************************************************************************************| (defun c:BlksSrt2PL (/ blkLst spacing pathEnt pathObj blkCopy len i param pt getAtVal parsFract attrVal blk startPt endPt dx dy visStart dist tangent rotAngle pathDist objType blkSelEnt blkSelObj tagList tagNames selTag ) (vl-load-com) ;; Function to get attribute value by tag name (defun getAtVal (blk tag / atts val) (setq atts (vlax-invoke blk 'GetAttributes)) (setq val "") (foreach att atts (if (= (strcase (vla-get-TagString att)) (strcase tag)) (setq val (vla-get-TextString att)) ) ) val ) ;; Function to convert fractional strings (like "1/2") to numbers (defun parsFract (s / pos num1 num2) (cond ((setq pos (vl-string-search "/" s)) (setq num1 (read (substr s 1 pos))) (setq num2 (read (substr s (+ pos 2)))) (if (and num1 num2 (/= num2 0)) (/ (float num1) num2) 0.0 ) ) ((distof s)) (T 0.0) ) ) ;; Select a block to determine attribute tag name (prompt "\nSelect a block to determine the tag name:") (setq blkSelEnt (car (entsel "\nSelect a block with attributes: "))) (if (not blkSelEnt) (progn (prompt "\nNo block selected. Exiting.") (exit) ) ) (setq blkSelObj (vlax-ename->vla-object blkSelEnt)) (if (not (vla-get-HasAttributes blkSelObj)) (progn (prompt "\nSelected block has no attributes. Exiting.") (exit) ) ) ;; Get all attribute tags from selected block (setq tagList '()) (foreach att (vlax-invoke blkSelObj 'GetAttributes) (setq tagList (cons (vla-get-TagString att) tagList)) ) (setq tagNames (apply 'strcat (mapcar '(lambda (x) (strcat "\n - " x)) tagList) ) ) (prompt (strcat "\nAvailable tags in selected block:" tagNames) ) (initget 1) (setq selTag (getstring "\nEnter the tag to use: ")) ;; --- Collect all blocks with that attribute tag --- (setq blkLst '()) (vlax-for ent (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-Acad-Object)) ) (if (and (= (vla-get-ObjectName ent) "AcDbBlockReference") (vla-get-HasAttributes ent) ) (progn (setq attrVal (getAtVal ent selTag)) (if (and attrVal (/= attrVal "")) (setq blkLst (cons (list (parsFract attrVal) ent) blkLst)) ) ) ) ) (if (= (length blkLst) 0) (progn (prompt "\nNo matching blocks found.") (exit) ) ) ;; Select path: polyline or line (prompt "\nSelect path (polyline or line): ") (setq pathEnt (car (entsel "\nSelect path (polyline or line): "))) (if (not pathEnt) (progn (prompt "\nNo object selected. Exiting.") (exit) ) ) (setq pathObj (vlax-ename->vla-object pathEnt)) (setq objType (vla-get-ObjectName pathObj)) (if (or (equal objType "AcDbPolyline") (equal objType "AcDbLine") ) (progn (setq startPt (vlax-curve-getStartPoint pathObj)) (setq endPt (vlax-curve-getEndPoint pathObj)) ) (progn (prompt (strcat "\nSelected object is not a polyline or line: " objType ". Exiting." ) ) (exit) ) ) ;; Determine start point (setq dx (- (car endPt) (car startPt))) (setq dy (- (cadr endPt) (cadr startPt))) (if (> (abs dy) (abs dx)) ;; Mostly vertical (setq visStart (if (> (cadr startPt) (cadr endPt)) startPt endPt ) ) ;; Mostly horizontal or diagonal (setq visStart (if (< (car startPt) (car endPt)) startPt endPt ) ) ) ;; Sort blocks by numeric tag value (setq blkLst (vl-sort blkLst (function (lambda (a b) (> (car a) (car b)))) ) ) (if (not (equal startPt visStart 1e-6)) (setq blkLst (reverse blkLst)) ) ;; Ask for spacing (initget 7) (setq spacing (getdist "\nEnter spacing between blocks: ")) ;; Place and rotate blocks along path (setq len (length blkLst)) (setq i 0) (setq dist 0.0) (setq pathDist (vlax-curve-getDistAtParam pathObj (vlax-curve-getEndParam pathObj) ) ) (while (and (< i len) (< dist pathDist)) (setq pt (vlax-curve-getPointAtDist pathObj dist)) (setq tangent (vlax-curve-getFirstDeriv pathObj (vlax-curve-getParamAtDist pathObj dist) ) ) (setq rotAngle (atan (cadr tangent) (car tangent))) ;; Flip angles to keep blocks upright (if (or (> rotAngle (/ pi 2)) (< rotAngle (- (/ pi 2)))) (setq rotAngle (+ rotAngle pi)) ) (if pt (progn (setq blk (cadr (nth i blkLst))) (setq blkCopy (vla-copy blk)) (vla-put-InsertionPoint blkCopy (vlax-3d-point pt)) (vla-put-Rotation blkCopy rotAngle) ) ) (setq dist (+ dist spacing)) (setq i (1+ i)) ) (prompt (strcat "\nCopied " (itoa i) " blocks along path.")) (princ) )
  19. pkenewell
    @BlackBox Thanks! (yeah - logand is fairly advanced, but shorter lol)
  20. BlackBox
    '... as simple'... using logand. (chortles) Teeheehee Props though, as yours allows arcs, etc... Well done
  21. pkenewell
    @BlackBox Beat me to the Punch! @james9710 Here is my version - as simple as I can make it: (defun C:PLH (/ e el) (command "._pline") (while (= (logand (getvar "cmdactive") 1) 1) (command pause) ) (if (and (setq e (entlast)) (setq el (entget e)) (= (cdr (assoc 0 el)) "LWPOLYLINE") (= (logand (cdr (assoc 70 el)) 1) 1) ) (command "._-hatch" "_pro" "_S" "_S" e "" "") (princ "\nInvalid Polyline Created (Must be complete and Closed).") ) (princ) )
  22. BlackBox
    Without using Visual LISP reactors, here's a starting point: (defun c:PLH (/ pt) (entlast) (command "._pline") (while (and (not (initget 32)) (if pt (setq pt (getpoint pt)) (setq pt (getpoint)) ) ) (command pt) ) (command "_c") (command "._-hatch" "_p" "_s" "_co" "." "." "_la" "." "_s" (ssadd (entlast)) "" "" ) (princ) )
  23. ronjonp
    @Mohamed Haytham Code updated to preserve global width.
  24. @james9710 please upload your sample dwg where you will apply such lisp
  25. @HypnoS Please show the command line text or error message.
  26. hi, can someone please assist me on creating a lisp: create polyline then after closing, it will automatically create a solid hatch within the closed polyline. hatch should be solid and layer is as per current. command should be PLH big thanks. we are working on large scale landscape projects that need hatches of each area of soft scape and hardscape
  27. It works, but the fence must pass on each side of the middle of the segment to be extended.
  28. I just did a quick look in AutoCAD, this may be a bit tricky for me. Let me get my paid to do work done and I'll do more looking.
