cecinamullah joined the community
Maxime joined the community
tegar joined the community
magiceween joined the community
Reload LineTypes in AutoCAD 2027 not working?
SLW210 replied to Aftertouch's topic in The CUI, Hatches, Linetypes, Scripts & Macros
@Aftertouch I thought this may be a bug. I think there may be other bugs since 2025 version, I had some issues last year with linetypes. I'll play around with it next week when I am at work and have AutoCAD 2026 to test. @tombu I have the other one in that thread from Cad Studio, I'll have to try yours out when I get to work next week. -
BIGAL replied to Aftertouch's topic in The CUI, Hatches, Linetypes, Scripts & Macros
Did the reload shx work ? It may take some time for a bug fix. -
Yep found the formula, also found some Excel convert formula. Did find even a lisp link. Try this in google. formula for convert latitude and longitude to northing and easting using lisp
Aftertouch replied to Aftertouch's topic in The CUI, Hatches, Linetypes, Scripts & Macros
@tombu Ive had contact with AutoDesk: Hello Michel, I am writing to confirm that I have reviewed the issue you reported and replicated the results you described (see this video:https://go.screenpal.com/watch/cOieX2nU2gH ). I want to assure you that we've reported it to our development team, and they're currently investigating it. The resulting internal development ticket is linked to this technical support case and has the following Issue ID/subject: "CPR-2262 Reloading complex linetype without SHX shape does not update line display". AutoCAD confirmed that this issue is present since AutoCAD 2025 version. -
tombu replied to Aftertouch's topic in The CUI, Hatches, Linetypes, Scripts & Macros
Have you tried saving, closing and reopening the drawing? I retired a few years ago and never saw the latest version. Here's a link to a lisp that will output the linetype definition of a selected line to the command line. I wrote it to extract linetypes I liked from drawings by others to add to my acad.lin file: https://forums.autodesk.com/t5/autocad-forum/export-linetype-to-acad-lin/m-p/11945136#M36909 which is why I called it LT_thief.lsp It will output the actual current linetype definition of a selected line to the command line including the shape references. -
Thanks for your interest. @BIGAL: To transform coordinates from LL to UTM, you only need to know the UTM zone, the hemisphere (N/S), and the datum (WGS84, ETRS89, Hayford, Clarke, etc.). The central meridian scale factor in the UTM system is always 0.9996. I usually work within UTM zones 31N, 32N, and 33N. However, the code should be able to return UTM coordinates for any location simply by specifying the UTM zone, hemisphere, and datum as parameters
dharani joined the community
Hi All, thanks for the replies. @tombu That is exactly the issue. I removed the SHAPE reference from the linetype, reload the linetype. I see that the linetype is changed a bit, but the SHAPE keeps being shown. Even when i check the linetype definition in the DWG, the SHPAE reference is gone there, but still visualy there. Look, there are my definitions: Video attatched with my relaoding action. when i load the WITHOUT.LIN in a NEW drawing. the linetype is just fine... In the last sec off the video i do a REA command, and you see the linetype presentation change a bit. Most anoying... in AutoCAD 2023 this works just fine... looks like an AutoCAD 2027 error. Sample.mp4 -
ching1791 joined the community
tombu started following Reload LineTypes in AutoCAD 2027 not working? and LAYER PROPERTIES
You can have multiple references to the same drawing with different Layer Properties. I've done it many times. You could insert the same XREF drawing into one of your project drawing with a different name, modify it's layer properties then copy each of them into your project drawings. You could also define Layer States in the XREF drawing for both Layer States in the XREF drawing then insert and name each of them into one of your project drawings then just copy each of those inserts to the rest of your project drawing.
Did you regen the drawing? Shapes are referenced by linetypes not defined by them. Whatever Shapes defined in the drawing would still be there. Did you remove the Shape references in the linetype definition before reloading it? - Last week
Just a maybe reload the shx while you sort out what is going on. Are your shx files and custom .lin files in a support path ? That may be why they are not reloading. (command "._LOAD" "C:\\Path\\To\\YourFile\\custom.shx") or (command "._LOAD" "Custom.shx") ; tested this Bricscad V25 -
The lat long convert is out there I have used one for here in AUS, the formula behind it is the same I think for any where in the world, but inside it is numerous values that depend on your location in the world, something like 8. values can be like 0.9987999 scale factor. So we need @PGia to tell us where she/he is in the world and what zones are relevant. Will do a quick look for the formula.
Djerekato joined the community
DaryaKu joined the community
Change text color in AutoCAD Lt Tables Lisp request
MSHR replied to MSHR's topic in AutoLISP, Visual LISP & DCL
Hi, 1-I create dwg files myself 2-Somtimes I receive lab result just pdf sometimes I received excle and pdf anyway I can change pdf to CSV online(easy) 3-I can ask AI for change to CSV Or exel -
Windows XP came out in late 2001, so that would be Windows 3.1 which came out in 1992. Best bet may be set back up with the Virtual XP, if you are determined. You might try Longbow Reviver I am with BIGAL on this though, try something else less costly than AutoCAD if the price of AutoCAD is too much, some also have a monthly option for infrequent use. LibreCAD is free 2D CAD, but basic, and FreeCAD is like it's name, Free, but 3D CAD.
I don't have AutoCAD 2027, but it may show up in AutoCAD 2026. I will do some checking when I get back to work next week. You should post your script and your shape linetypes that are an issue. You could see if a LISP works for you Lee Mac has one... https://lee-mac.com/loadlinetype.html. Here is an example of using loadlinetype.lsp in a Macro... You may want to contact Autodesk, they may know about the issue or at least would need to know. -
daid joined the community
Thanks, @BIGAL You're right: it's probably necessary to solve the problem of transforming latitude/longitude to UTM. I might review the code to publish a more complete version. Or maybe someone else will do it before me
Aftertouch started following Reload LineTypes in AutoCAD 2027 not working?
Aftertouch posted a topic in The CUI, Hatches, Linetypes, Scripts & Macros
Hi All, I just moved from AutoCAD 2023 to AutoCAD 2027. My script that reloads some linetypes seems to fail in this version. Afer soms manual testing, i noticed that the 'reload linetype' function looks totaly broken? Anybody else can confirm this? EDIT: After some more research, it seems like... when i got a linetype with a shape in it. and reload the linetype without the Shape. AutoCAD is still showing the SHAPE, like the removal of shapes isnt handled properly -
Danielm103 started following AutoLISP: Safe alternative to (command "EXPLODE") inside a custom command and Python, Clone Layout from another drawing
import traceback from pyrx import Ap, Db, Ed, Ge def validate_layout(source_db: Db.Database, target_db: Db.Database, layout_name: str): """Validates if the layout exists in source and is safe to write to target.""" source_layout_dict = Db.Dictionary(source_db.layoutDictionaryId()) if not source_layout_dict.has(layout_name): print(f"Layout '{layout_name}' not found in source drawing.") return False target_layout_dict = Db.Dictionary(target_db.layoutDictionaryId()) if target_layout_dict.has(layout_name): print(f"Layout '{layout_name}' already exists in target drawing.") return False return True def clone_layout_from_db(source_db: Db.Database, target_db: Db.Database, layout_name: str): """Clones a specified layout from a source database to a target database layout dictionary.""" if not validate_layout(source_db, target_db, layout_name): return False try: source_layout_dict = Db.Dictionary(source_db.layoutDictionaryId()) source_layout_id = source_layout_dict.getAt(layout_name) id_map = Db.IdMapping() id_map.setDestDb(target_db) source_db.wblockCloneObjects( [source_layout_id], target_db.layoutDictionaryId(), id_map, Db.DuplicateRecordCloning.kDrcIgnore, ) return True except Exception as e: print(f"Error encountered during cloning: {e}") traceback.print_exc() return False @Ap.Command() def doit(): layout_name = "S7" source_path = r"E:\Batch\06457 RE Submittal.dwg" target_db = Db.curDb() try: source_db = Db.Database.createFromDWG(source_path) if clone_layout_from_db(source_db, target_db, layout_name): print(f"Successfully cloned layout '{layout_name}'.") manager = Ap.LayoutManager() manager.updateLayoutTabs() except Exception as err: print(f"Failed to load or process source drawing: {err}")
- 1
@GLAVCVS nicely done, yes need a convert lat long to XY, if you have CIV3D then yes can read lat long directly.
Maybe its a language problem. Question 1 where are you getting the dwg from ? Question 2 why are you converting a pdf ? Question 3 can you not go back to who made the pdf and ask for the data say a CSV file The Excel means nothing to me I may have to give up without source data can not really help. -
Given that you indicate pre 2000 it is maybe time to upgrade. There is alternatives to Acad like Bricscad, Intellicad, Gstar to mention a few and much cheaper.
Here's a simple Lisp routine for obtaining data from an integrated GNSS receiver. It works by sending a small script to PowerShell, which writes the data to a file named 'pos.txt' saved in the Documents folder. I've only tested it on a single device, but it should work on any device equipped with an integrated GNSS receiver. The data is stored in latitude/longitude format, so each user will need to transform those coordinates into the desired coordinate reference system. To stop logging the data, simply close the PowerShell window This is just a starting point for anyone who wants to adapt it to their own needs. ;************************ G L A V C V S ************************* ;************************** F E C I T *************************** ;;;THIS CODE STARTS GNSS RECEIVER AND WRITES DATA TO A FILE CALLED 'pos.txt' IN THE My Docments FOLDER (defun startGNSS (/ cmd sh dir cad ur) (setq dir (VL-REGISTRY-READ "HKEY_CURRENT_USER\\Software\\Microsoft\\Windows\\CurrentVersion\\Explorer\\Shell Folders" "Personal" ) ) (if (setq sh (vlax-create-object "WScript.Shell")) (progn (if (and (or (setq ur (getint "\nUpdate rate (milliseconds) <1000>/2000/3000/5000 : ")) (not ur)) (member ur '(nil 1000 2000 3000 5000))) (progn (setq cad (strcat "Add-Type -AssemblyName System.Device" (chr 13) (chr 10) "# 1) Conectar con AutoCAD abierto" (chr 13) (chr 10) "$outFile = \'" dir "\\pos.txt\'" (chr 13) (chr 10) "try {" (chr 13) (chr 10) " $acad = [Runtime.InteropServices.Marshal]::GetActiveObject(\'AutoCAD.Application." (itoa (atoi (getvar "ACADVER"))) "\')" (chr 13) (chr 10) "}" (chr 13) (chr 10) "catch {" (chr 13) (chr 10) " Add-Type -AssemblyName System.Windows.Forms" (chr 13) (chr 10) " [System.Windows.Forms.MessageBox]::Show(" (chr 13) (chr 10) " \'Por alguna razón no se pudo conectar con AutoCAD mediante COM.\' + [Environment]::NewLine + $_.Exception.Message," (chr 13) (chr 10) " \'GNSS-}AutoCAD: Error de conexión\'," (chr 13) (chr 10) " [System.Windows.Forms.MessageBoxButtons]::OK," (chr 13) (chr 10) " [System.Windows.Forms.MessageBoxIcon]::Error" (chr 13) (chr 10) " )" (chr 13) (chr 10) " exit" (chr 13) (chr 10) "}" (chr 13) (chr 10) "# 2) Crear y arrancar receptor de ubicación Windows/GNSS" (chr 13) (chr 10) "$w = New-Object System.Device.Location.GeoCoordinateWatcher" (chr 13) (chr 10) "$w.Start()" (chr 13) (chr 10) "# 3) Bucle continuo: comprobar estado, obtener posición y escribir en USERS5" (chr 13) (chr 10) "while ($true) {" (chr 13) (chr 10) " $doc = $acad.ActiveDocument" (chr 13) (chr 10) " $status = $w.Status" (chr 13) (chr 10) " $p = $w.Position.Location" (chr 13) (chr 10) " $time = Get-Date -Format \'dd-MM-yyyy HH:mm:ss\'" (chr 13) (chr 10) " if ($status -eq \'Disabled\') {" (chr 13) (chr 10) " $line = \'*** GNSS ERROR: GNSS disabled ***\';;;;;;\"" (chr 13) (chr 10) " }" (chr 13) (chr 10) " elseif ($status -eq \'Initializing\') {" (chr 13) (chr 10) " $line = \'*** GNSS ERROR: Searching... ***\';;;;;;\"" (chr 13) (chr 10) " }" (chr 13) (chr 10) " elseif ($status -eq \'NoData\') {" (chr 13) (chr 10) " $line = \'*** GNSS ERROR: Without data ***\';;;;;;\"" (chr 13) (chr 10) " }" (chr 13) (chr 10) " elseif ($p.IsUnknown) {" (chr 13) (chr 10) " $line = \'*** ERROR GNSS: Unknown position ***\';;;;;;\"" (chr 13) (chr 10) " }" " else {" (chr 13) (chr 10) " $line = $p.Latitude + ';' + $p.Longitude + ';' + $p.Altitude + ';' + $p.HorizontalAccuracy + ';' + $p.VerticalAccuracy" (chr 13) (chr 10) " }" (chr 13) (chr 10) " try {" (chr 13) (chr 10) " Set-Content -Path $outFile -Value $line" (chr 13) (chr 10) " }" (chr 13) (chr 10) ;;; " catch {" ;;; (chr 13) ;;; (chr 10) ;;; " Write-Host 'ERROR escribiendo...: $($_.Exception.Message)'" ;;; (chr 13) ;;; (chr 10) ;;; " }" (chr 13) (chr 10) (strcat " Start-Sleep -Milliseconds " (if ur (itoa ur) "1000")) (chr 13) (chr 10) "}" ) cmd (strcat "powershell.exe -NoProfile -ExecutionPolicy Bypass -NoExit -Command \"" cad "\"" ) ) (vlax-invoke-method sh 'Run cmd 1 :vlax-false) (grtext -1 "*** GNSS writing file \'pos.txt\' ***") ) (alert "ERROR: \nUpdate rate should be 1000, 2000, 3000 or 5000\n\nExiting...") ) (vlax-release-object sh) ) ) )
@masao_8 Before i try this code, could you please explain what is does and/or provide a sample drawing to test it on? It would save me time trying to determine what you are doing. You didn't put any comments in your code explaining it. EDIT: So I tried your code and it seems to work OK for me. It appears that it adds text for circles with the dia. and copies properties from the base circle? I kind of understand what you are going for; to be able to change option (Text height) during selection. I don't have AutoCAD 2012 or AutoCAD 2016 to test what your issue is, but I think you will have to research how express tools have changed since those versions, and if the loading is different? TIP: during your window selection, you could add the filter for CIRCLES (it's already in your "_getwindowselection" function), then you wouldn't need to pick them out while processing the selection set.
@pkenewell I found an issue with the spacebar when using 'GRREAD' in CAD 2016. Like the code below, but using ARX files won't work across different versions.(CAD 2012 or 2016) ;;------------------=={ CDIA - Short English Version with TxtH }==-----------------;; (defun _redrawss (ss mode / i) (if (and ss (= (type ss) 'PICKSET) (> (sslength ss) 0)) (repeat (setq i (sslength ss)) (redraw (ssname ss (setq i (1- i))) mode) ) ) ) (defun _getwindowselection (msg p1 filter flag / gr p3 p2 p4 col winflag) (princ msg) (setq p3 nil) (while (/= 3 (car (setq gr (grread t 13 0)))) (if (= 5 (car gr)) (progn (redraw) (setq p3 (cadr gr)) (if (and p1 p3) (progn (setq p2 (list (car p3) (cadr p1) (caddr p3)) p4 (list (car p1) (cadr p3) (caddr p3)) col (if (or (eq flag "_C") (minusp (- (car p3) (car p1)))) -256 256) ) (grvecs (list col p1 p2 p1 p4 p2 p3 p3 p4)) ) ) ) ) ) (redraw) (if (and p1 p3) (progn (setq winflag (cond (flag) ((minusp (- (car p3) (car p1))) "_C") (t "_W"))) (if filter (ssget winflag p1 p3 (list filter)) (ssget winflag p1 p3)) ) nil ) ) (defun get-real-linetype (ed / lt lay layed) (setq lt (assoc 6 ed)) (if (or (null lt) (= (cdr lt) "BYLAYER")) (progn (setq lay (cdr (assoc 8 ed))) (if (setq layed (tblsearch "LAYER" lay)) (cdr (assoc 6 layed)) "CONTINUOUS") ) (cdr lt) ) ) (defun get-real-color (ed / col lay layed) (setq col (assoc 62 ed)) (if (or (null col) (= (cdr (assoc 62 ed)) 256)) (progn (setq lay (cdr (assoc 8 ed))) (if (setq layed (tblsearch "LAYER" lay)) (cdr (assoc 62 layed)) 7) ) (cdr col) ) ) (defun c:CDIA (/ old-error start-time loop_base base-ent base-ed base-ltype base-color ss express gr g1 g2 p1 pick filt i e root_path ver_name target_arx target_fas ent ed center radius loop_main pick_obj txt_h tmp _printmenu) (vl-load-com) (setq old-error *error*) (defun *error* (msg) (setvar "CMDECHO" 1) (setq *error* old-error) (princ "\n[Exit] Command ended by ESC.") (princ) ) (setvar "CMDECHO" 0) (setq txt_h 2.5) (if (not (vl-position "acetutil.arx" (arx))) (progn (if (findfile "CDIA.lsp") (setq root_path (strcat (vl-filename-directory (findfile "CDIA.lsp")) "\\")) (setq root_path (strcat (vl-filename-directory (getvar "DWGPREFIX")) "\\")) ) (if (or (null root_path) (= root_path "\\")) (setq root_path "")) (setq ver_name (strcat "R" (substr (getvar "ACADVER") 1 4))) (setq target_arx (strcat root_path "ExpressARX\\" ver_name "\\acetutil.arx")) (if (not (findfile target_arx)) (cond ((findfile (strcat root_path "ExpressARX\\R20.1\\acetutil.arx")) (setq target_arx (strcat root_path "ExpressARX\\R20.1\\acetutil.arx")) ) ((findfile (strcat root_path "ExpressARX\\R18.2\\acetutil.arx")) (setq target_arx (strcat root_path "ExpressARX\\R18.2\\acetutil.arx")) ) ) ) (setq target_fas (strcat root_path "acetutil.fas")) (if (findfile target_arx) (progn (arxload target_arx) (if (findfile target_fas) (vl-catch-all-apply 'load (list target_fas))) ) ) ) ) (setq express (and (vl-position "acetutil.arx" (arx)) (boundp 'acet-sys-shift-down) (not (null acet-sys-shift-down)))) (while t (setq start-time (getvar "DATE")) (setq loop_base t) (while loop_base (setq base-ent (entsel "\nSelect base circle (or ESC to exit)...")) (cond ((and (null base-ent) (= (getvar "ERRNO") 52)) (if (< (* 86400.0 (- (getvar "DATE") start-time)) 0.40) (progn (setvar "ERRNO" 0) (setq start-time (getvar "DATE")) ) (princ "\n[Tip] Select a circle, or press ESC to exit.") ) ) (t (setq loop_base nil)) ) ) (if (and base-ent (car base-ent)) (progn (setq base-ed (entget (car base-ent))) (if (/= (cdr (assoc 0 base-ed)) "CIRCLE") (princ "\n[Error] Object is not a circle.") (progn (setq base-ltype (get-real-linetype base-ed)) (setq base-color (get-real-color base-ed)) (setq ss (ssadd)) (setq filt (list (cons 0 "CIRCLE") (cons 6 base-ltype) (cons 62 base-color))) (defun _printmenu () (princ (strcat "\nBase -> LType: " base-ltype ", Color: " (itoa base-color) ", TxtH: " (rtos txt_h 2 2))) (princ "\n[H]:TxtH | [Space/Enter]:Done & Next Loop...") (princ "\nSelect objects: ") (princ) ) (_printmenu) (setq loop_main t) (while loop_main (setq gr (grread t 13 2) g1 (car gr) g2 (cadr gr)) (_redrawss ss 3) (cond ((= g1 5) nil) ((= g1 2) (cond ((member g2 '(13 32)) (setq loop_main nil) ) ((wcmatch (strcase (chr g2)) "H") (initget 6) (if (setq tmp (getreal (strcat "\nNew text height <" (rtos txt_h 2 2) ">: "))) (setq txt_h tmp) ) (_printmenu) ) (t nil) ) ) ((= g1 3) (if (and (setq pick_obj (nentselp g2)) (setq pick (car pick_obj)) (= (cdr (assoc 0 (entget pick))) "CIRCLE") (= (get-real-linetype (entget pick)) base-ltype) (= (get-real-color (entget pick)) base-color) ) (progn (if (and express (acet-sys-shift-down)) (if (ssmemb pick ss) (progn (ssdel pick ss) (redraw pick 4))) (if (not (ssmemb pick ss)) (ssadd pick ss)) ) ) (if (setq pick (_getwindowselection "\nSpecify Opposite Corner: " g2 nil nil)) (cond ((and express (acet-sys-shift-down)) (repeat (setq i (sslength pick)) (setq e (ssname pick (setq i (1- i)))) (if (and (ssmemb e ss) (wcmatch (cdr (assoc 0 (entget e))) "CIRCLE")) (progn (ssdel e ss) (redraw e 4)) ) ) ) (t (repeat (setq i (sslength pick)) (setq e (ssname pick (setq i (1- i)))) (if (and (= (cdr (assoc 0 (entget e))) "CIRCLE") (= (get-real-linetype (entget e)) base-ltype) (= (get-real-color (entget e)) base-color) (not (ssmemb e ss)) ) (ssadd e ss) ) ) ) ) ) ) (princ "\nSelect objects: ") ) ) ) (_redrawss ss 4) (if (> (sslength ss) 0) (progn (princ (strcat "\nSelected " (itoa (sslength ss)) " circles. Creating text...")) (setq i 0) (while (< i (sslength ss)) (setq ent (ssname ss i)) (setq ed (entget ent)) (setq center (cdr (assoc 10 ed))) (setq radius (cdr (assoc 40 ed))) (entmake (list '(0 . "TEXT") (cons 8 (cdr (assoc 8 ed))) (cons 10 center) (cons 11 center) (cons 40 txt_h) (cons 1 (strcat "%%C" (rtos (* radius 2) 2 2))) '(7 . "STANDARD") '(71 . 0) '(72 . 1) '(73 . 2) ) ) (setq i (1+ i)) ) (princ "\n[OK] Finished!") ) (princ "\n[Tip] No circles selected.") ) ) ) ) ) ) (setvar "CMDECHO" 1) (setq *error* old-error) (princ) ) (princ "\nCommand CDIA loaded.") (princ)
Hi, This my excle file saomle, I sent dwg file before. sample.xlsx -
This is what I use; I sent a support request to Bricsys, I ported it to C++ for the report since they don’t directly support Python (only BRX) from pyrx import Ap, Db, Ed, Ge #SR 223468 BRX def check_layout_status(source_db: Db.Database, dest_db: Db.Database, layout_name: str) -> bool: source_layout_dict = Db.Dictionary(source_db.layoutDictionaryId()) if not source_layout_dict.has(layout_name): print(f"Layout '{layout_name}' not found in source drawing.") return False dest_layout_dict = Db.Dictionary(dest_db.layoutDictionaryId()) if dest_layout_dict.has(layout_name): print(f"Layout '{layout_name}' already exists") return False return True def clone_layout_from_db(source_db: Db.Database, dest_db: Db.Database, layout_name: str): if not check_layout_status(source_db, dest_db, layout_name): return source_layout_dict = Db.Dictionary(source_db.layoutDictionaryId()) source_layout_id = source_layout_dict.getAt(layout_name) id_map = Db.IdMapping() id_map.setDestDb(dest_db) source_db.wblockCloneObjects( [source_layout_id], dest_db.layoutDictionaryId(), id_map, Db.DuplicateRecordCloning.kDrcIgnore, ) @Ap.Command() def doit(): layoutName = "S7" source_path = "E:\\Batch\\06457 RE Submittal.dwg" dest_db = Db.curDb() source_db = Db.Database.createFromDWG(source_path) clone_layout_from_db(source_db, dest_db, layoutName) Ap.Application.refreshMainWindow()
