I am working on an AutoLISP routine where I need to explode a block/table object during the execution of my custom command.
Currently I am using:
(command "._EXPLODE" obj "")
The object is exploded, and my routine usually continues, but AutoCAD also prints an “Unknown command” message after the EXPLODE operation. When I remove this EXPLODE line, the problem disappears.
From what I understand, the issue may be related to using the AutoCAD EXPLODE command inside another running AutoLISP command. After the explode operation, AutoCAD may refresh or lose the expected command context, so the remaining input is interpreted incorrectly.
I need to explode the object because I have to access/fill attribute-related data from the resulting entities. However, I must preserve the original block/table placement exactly: insertion point, rotation, scale, and geometry position should remain unchanged. It would also be acceptable if only the entities on a specific layer are exploded or copied out.
Is there a safer/custom AutoLISP or Visual LISP way to explode a block/table object without using (command "._EXPLODE" ...)?
For example, is using vla-Explode recommended in this case? If so, how can I explode or copy the block contents while preserving their transformed position, rotation, and scale exactly as they appear in the drawing?
Any example function or best-practice approach would be helpful.
Have you tried vla-explode?
Yes, its work but I dont want to vla functions because this functions dont work acad LT. So I looking for alternative
Perhaps you just need to simplify it like this:
(command ".-explode" obj)
You could make an  AutoCAD LT code and a an AutoCAD code.
This is what I use; I sent a support request to Bricsys, I ported it to C++ for the report since they don’t directly support Python (only BRX)
from pyrx import Ap, Db, Ed, Ge
#SR 223468 BRX
def check_layout_status(source_db: Db.Database, dest_db: Db.Database, layout_name: str) -> bool:
    source_layout_dict = Db.Dictionary(source_db.layoutDictionaryId())
    if not source_layout_dict.has(layout_name):
        print(f"Layout '{layout_name}' not found in source drawing.")
        return False
    dest_layout_dict = Db.Dictionary(dest_db.layoutDictionaryId())
    if dest_layout_dict.has(layout_name):
        print(f"Layout '{layout_name}' already exists")
        return False
    return True
def clone_layout_from_db(source_db: Db.Database, dest_db: Db.Database, layout_name: str):
    if not check_layout_status(source_db, dest_db, layout_name):
        return
    source_layout_id = source_layout_dict.getAt(layout_name)
    id_map = Db.IdMapping()
    id_map.setDestDb(dest_db)
    source_db.wblockCloneObjects(
        [source_layout_id],
        dest_db.layoutDictionaryId(),
        id_map,
        Db.DuplicateRecordCloning.kDrcIgnore,
@Ap.Command()
def doit():
    layoutName = "S7"
    source_path = "E:\\Batch\\06457 RE Submittal.dwg"
    dest_db = Db.curDb()
    source_db = Db.Database.createFromDWG(source_path)
    clone_layout_from_db(source_db, dest_db, layoutName)
    Ap.Application.refreshMainWindow()
  • 3 weeks later...
no  ""
As it works as a RETURN or ENTER
With out looking at the code the error is probably calling obj again but it is no longer valid (because its exploded). if you want to look at exploded items you have to then add them to a selection set use this method.
https://www.cadtutor.net/forum/topic/85374-why-would-entlast-not-be-getting-the-unioned-entity-in-this-code/#findComment-640512
-Edit
You can also look inside blocks to pull information you want without exploding.
Edited by mhupp
Regarding your initial message...
Try :
(command "_.explode" obj)
(while (< 0 (getvar (quote cmdactive)))
  (command "")
HTH.
Set bit 1 of the QAFLAGS system variable (storing the original value and resetting after the command); with bit 1 enabled, the EXPLODE command will accept selection sets when invoked from the LISP API. Alternatively, ensure that this bit is not set and only pass a single entity with no double quotes.
The key point is that by controlling the bit, you can ensure consistent behaviour.
Edited by Lee Mac
  • Like 4
