mhupp started following Anyone see a routine in their travels that does this? (block numbering)
mhupp replied to ILoveMadoka's topic in AutoLISP, Visual LISP & DCL
Think this can also be done with dynamic blocks less automated but will prompt you for inputs when inserted into a drawing. - Today
Now that I think about it... let's assume there will be multiple attributes.- 33 replies
- autolisp
- block position
(and 3 more)
Tagged with:
SLW210 replied to HypnoS's topic in AutoLISP, Visual LISP & DCL
There has to some consistency in what's being sorted. Will there always be just one attribute?- 33 replies
- autolisp
- block position
(and 3 more)
Tagged with:
There are several LISPs and programs around for cable trays. @Tharwat has a program. Cable tray program | Tharwat Al Choufi Here's a thread on T-Connections... Draw cable tray T connection - AutoLISP, Visual LISP & DCL - AutoCAD Forums
How to stop flip action reversing offsets in dynamic block
SLW210 replied to jamami's topic in AutoCAD Drawing Management & Output
No time for me to look at your blocks, but have you looked into constraints? I have some dynamic block with lots of actions and even constrained if you do things in a weird order they can get a little off. So make sure length is set before the flip action. Probably could constrain them more or different. I don't know. I'll see what time I have today, but I am at work for a shorter time today than usual. -
well I hoped for this lisp to work with any blocks with attributes. here are the same b locks Im using. example [2].dwg- 33 replies
- autolisp
- block position
(and 3 more)
Tagged with:
AutoCAD gets strange sometimes when objects get far away from 0,0,0. That's all I can come up with.
SLW210 replied to ILoveMadoka's topic in AutoLISP, Visual LISP & DCL
TCOUNT Express Tool. There used to be quite a few LISPs and Programs around to do that, you'll need to find one that suits your needs best. I use Lee Mac's from time to time. AutoCAD Mechanical has Balloon which works with a BOM and all sorts of options. -
My code only gives that error if there are letters in the ATTRIBUTE, works no errors on the drawing you posted. Maybe you should post an actual drawing that you are using this on. Even the images you posted are different by a lot from the drawing you posted.- 33 replies
- autolisp
- block position
(and 3 more)
Tagged with:
Dynamic Block w/Rotation and Stretch
DATVO replied to Bill Tillman's topic in AutoCAD Drawing Management & Output
Is this what you're looking for ? DynBlock101_modified.dwg -
@devitgcode acts weird. It asks me to type distance,and when I do it places only one block and asks for distance again to pace another block, and on and on.- 33 replies
- autolisp
- block position
(and 3 more)
Tagged with:
CivilTechSource replied to ILoveMadoka's topic in AutoLISP, Visual LISP & DCL
This is a good video that explains lisp and how to do autocount block -
DATVO started following Pan without losing current viewport zoom scale
DATVO replied to rcb007's topic in AutoLISP, Visual LISP & DCL
You may consider using this tool, which enables viewport panning with a customizable layer interface, retains coordinate memory, and functions even when the viewport is locked. I hope this helps you: https://lispautocad.gumroad.com/l/bgesj -
When copying layouts from one drawing to another the viewport layers change
DATVO replied to Steve Daley's topic in AutoCAD Drawing Management & Output
If your original drawing has saved Layer States, you can: - Open the original drawing. - Go to Layer Properties Manager → click Layer States Manager. - Export the layer state. - In the new drawing, import that layer state and apply it to the viewport. This preserves layer visibility, color, linetype... - Yesterday
where are experts of autocad no answer since five days
Adding data to property lookup tables
I agree with separating the constituent parts . have broken the assembly into separate dynamic blocks so that the central trusses, roof tracking , edge beams and ridge units are separate dynamics . I have run into a few issues that I have uploaded as a new thread . ive tried running the lisp above but struggling to see how I can use this to add data to the lookup tables?? -
jamami started following How to stop flip action reversing offsets in dynamic block
jamami posted a topic in AutoCAD Drawing Management & Output
I have developed the attached dynamic block which positions nested blocks according to the distance value set in a block properties table. To avoid text mirroring of the nested block labels I have used attributes and added a flip action. This all works well until I try and change the length after a flip. It appears the xpos value in the block properties table is applied as positive despite the flip state. I have tried changing the point parameters to stretch parameters but have similar problems, especially when rotating the assembly to different angles. I was hoping something as simple as adding a formulae into the block properties table ie dist*flipstate would work but there doesn't seem to be anyway to do this. Is there a way to solve this? jam3.dwg -
devitg replied to HypnoS's topic in AutoLISP, Visual LISP & DCL
@HypnoS Find attached cpy-blk-2-poly-01.lsp- 33 replies
- autolisp
- block position
(and 3 more)
Tagged with:
ILoveMadoka replied to ILoveMadoka's topic in AutoLISP, Visual LISP & DCL
Should have known.... LeeMac -
ILoveMadoka started following Anyone see a routine in their travels that does this? (block numbering)
ILoveMadoka posted a topic in AutoLISP, Visual LISP & DCL
Not sure how to even frame the question... Given a block like this: If it is inserted and is the first instance, change the text to 01, each additional insert will be numbered based upon the total number of that particular block being inserted. Can the text be text/mtext or would it have to be an attribute? I suppose it would search the block table when it is run and number additional inserts based upon the total existing in the drawing at the time of the insert. Has anyone seen such a routing/proggie that does that? If I used diesel (or other) could the numbers update automatically if one is deleted either by regen or some other trigger? Based upon their order within the blocktable? I do not even know how to search on something like this... Since I figured something would have to be written, I asked here but other forums might know of solutions.. -
Overall, Lisp works as expected. I mainly use it to draw simple cable trays. I know that creating things like T-junctions and branches will be impossible, so I'm not even asking for that. Width range we use between 50-500mm most often 100mm and 200mm.
Fillet Polylines with no Trim
SLW210 replied to Ahmed Khaled's topic in AutoCAD 2D Drafting, Object Properties & Interface
You should first ask at that thread in your link and let the author of that code amend it. -
I'll look into that, I might have posted the wrong one. I was working on one to just use the block clicked assuming a single attribute.- 33 replies
- autolisp
- block position
(and 3 more)
Tagged with:
It seems non productive to not get a FREE program to do what you need. Maybe I'll have time later today to look at them, I have these LISPs from a while back, though I may have skipped some versions. So just to make any time spent on this worthwhile, what exactly are you looking to do and what, besides the error and select elbow from dropdown, that you mentioned? What standards do you use? What size ranges do you work with? Are you doing pipe, ducts, cable trays, etc.
Lee Mac started following acet-laytrans
Use double-backslashes.
- 1 reply
- 1
