lines perpendicular to spline
ysand
Hello everyone.
I've been looking at this old thread:
http://www.cadtutor.net/forum/showthread.php?5953-lines-perpendicular-to-spline
I need to use that code, but i can't seem to be able to do it, because of all the "&@40;" stuff (from what i can tell at least).
Can someone re-make that last code from post #8, in a form so i can copy it, because I am less than a newbie in lisp. :oops:
Thank you in advance.
ysand,
The format of the post has been changed ( probably due to being archived ) to ASCII decimal.
You can do global search and replace in a text editor -
Replace:
With
With
You can use the ascii dec chart as a guide to what each value is as a character.
Remember to save the file as a true ascii file. -David
http://www.asciitable.com/
Ok, this now works perfectly, but:
I need it to work not only on the spline points existing, but in spaces i choose on the spline.
I mean, i tried converting it to a polyline to have the points i want, but it doesn't work with polyline.
If anyone could help i'd appreciate it a lot.
I use this...
(defun c:LPer (/ *error* ent pt)
 ;; Draw line perpendicular from selected curve
 ;; Required Subroutines: AT:GetSel
 ;; Alan J. Thompson, 09.29.09 / 12.20.10
 (vl-load-com)
 (defun *error* (msg)
   (and ent (redraw ent 4))
   (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,")))
 (if (setq ent
            (car (AT:GetSel
                   entsel
                   "\nSelect curve: "
                   (lambda (x)
                     (not (vl-catch-all-error-p (vl-catch-all-apply 'vlax-curve-getEndParam (list (car x))))
     (redraw ent 3)
     (while (setq pt (getpoint "\nSpecify point for line: "))
       (entmake
         (list '(0 . "LINE")
               (cons 10 (vlax-curve-getClosestPointToProjection ent (trans pt 1 0) '(0 0 1)))
               (cons 11 (trans pt 1 0))
 (*error* nil)
(defun AT:GetSel (meth msg fnc / ent good)
 ;; meth - selection method (entsel, nentsel, nentselp)
 ;; msg - message to display (nil for default)
 ;; fnc - optional function to apply to selected object
 ;; Ex: (AT:GetSel entsel "\nSelect arc: " (lambda (x) (eq (cdr (assoc 0 (entget (car x)))) "ARC")))
 ;; Alan J. Thompson, 05.25.10
 (setvar 'errno 0)
 (while (not good)
   (setq ent (meth (cond (msg)
                         ("\nSelect object: ")
   (cond
     ((vl-consp ent)
      (setq good (cond ((or (not fnc) (fnc ent)) ent)
                       ((prompt "\nInvalid object!"))
     ((eq (type ent) 'STR) (setq good ent))
     ((setq good (eq 52 (getvar 'errno))) nil)
     ((eq 7 (getvar 'errno)) (setq good (prompt "\nMissed, try again.")))
Hmm, are u sure the code is correct?
Couldn't make it work.
Quite sure, I use it all the time. Perhaps you could share what happened when you couldn't make it work.
Ok, i might be doing it wrong.
I make an .lsp file with this code.
I open autocad, go to autolisp and load the file.
Then i type LPer as a command, and nothing.
Are you shure you made the extension *.lsp??
--> YOu can also save the file to eg your desktop and then drag it into the autocad screen and release it. THen it loads too. It should work.
I guess i pasted the code wrong.
It seems to work now.
Thanx a million alan :)
Can you please explain how exactly it works? The numbers i'm placing are the distance each perpendicular line is drawn from the previous one? I have to lengthen or shorten them manually?
The length is based on the distance from the picked point.
How are you determining where on the curve to select for perpendicular line placement?
So, i pick a point (i.e. the one end of the spline) and then if i want each perpendicular line every 1 unit, i type 1,2,3,4,5 etc? They just will be longer the farther i go?
I click on the edge of the spline, and then i type the number of units i want each perpendicular line to be drawn at.
