afrazawan Posted May 1, 2011 Share Posted May 1, 2011 pls any one can help me i need a good LISP or Toolpac for placing cordinate point or any level pls urgently suppose any point i clik i get N: E: point with leader in center Quote Link to comment Share on other sites More sharing options...
Tharwat Posted May 1, 2011 Share Posted May 1, 2011 Check this out Buddy . (defun c:TesT (/ *error* hgt cmd i icar icadr icaddr pt1 pt2 e) ; Tharwat 01. 05. 201 (defun *error* (msg) (and cmd (setvar 'cmdecho cmd)) (redraw) (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,"))) (princ (strcat "\nError: " msg)) ) ) (setq Sty (tblnext "STYLE" (null Sty))) (setq cmd (getvar 'cmdecho)) (setvar 'cmdecho 0) (while (setq i (getpoint "\n Specify Corrdinates Point :") icar (car i) icadr (cadr i) icaddr (caddr i)) (setq pt1 (getpoint "\n Second point of QLeader :" i )) (grdraw i pt1 3 1) (setq pt2 (getpoint "\n Last point of QLeader :" pt1 )) (entmakex (list (cons 0 "LEADER") (cons 100 "AcDbEntity") (cons 100 "AcDbLeader") (cons 10 i)(cons 10 PT1)(cons 10 PT2)(cons 71 1)(cons 72 0)(cons 73 3))) (entmakex (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 100 "AcDbMText") (cons 10 (trans pt2 1 0)) (cons 40 (cdr (assoc (if (zerop (cdr (assoc 40 Sty))) 42 40) Sty ))) (cons 1 (strcat "N" ":" (rtos icar 2 0) "\n" "E" ":" (rtos icadr 2 0))))) (redraw) ) (setvar 'cmdecho cmd) (princ) ) TharwaT Quote Link to comment Share on other sites More sharing options...
afrazawan Posted May 1, 2011 Author Share Posted May 1, 2011 Check this out Buddy . (defun c:TesT (/ *error* hgt cmd i icar icadr icaddr pt1 pt2 e) ; Tharwat 01. 05. 201 (defun *error* (msg) (and cmd (setvar 'cmdecho cmd)) (redraw) (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,"))) (princ (strcat "\nError: " msg)) ) ) (setq Sty (tblnext "STYLE" (null Sty))) (setq cmd (getvar 'cmdecho)) (setvar 'cmdecho 0) (while (setq i (getpoint "\n Specify Corrdinates Point :") icar (car i) icadr (cadr i) icaddr (caddr i)) (setq pt1 (getpoint "\n Second point of QLeader :" i )) (grdraw i pt1 3 1) (setq pt2 (getpoint "\n Last point of QLeader :" pt1 )) (entmakex (list (cons 0 "LEADER") (cons 100 "AcDbEntity") (cons 100 "AcDbLeader") (cons 10 i)(cons 10 PT1)(cons 10 PT2)(cons 71 1)(cons 72 0)(cons 73 3))) (entmakex (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 100 "AcDbMText") (cons 10 (trans pt2 1 0)) (cons 40 (cdr (assoc (if (zerop (cdr (assoc 40 Sty))) 42 40) Sty ))) (cons 1 (strcat "N" ":" (rtos icar 2 0) "\n" "E" ":" (rtos icadr 2 0))))) (redraw) ) (setvar 'cmdecho cmd) (princ) ) TharwaT brother not this one any pther lisp pls i cant get it thanks Quote Link to comment Share on other sites More sharing options...
Tharwat Posted May 1, 2011 Share Posted May 1, 2011 brother not this one any pther lisp pls i cant get it thanks Is it hard to describe what you looking for in a little details ? Quote Link to comment Share on other sites More sharing options...
Organic Posted May 1, 2011 Share Posted May 1, 2011 Is it hard to describe what you looking for in a little details ? Your lisp looks pretty good to me. Seems to do everything the OP wanted as I interpreted his post to be also. Quote Link to comment Share on other sites More sharing options...
afrazawan Posted May 1, 2011 Author Share Posted May 1, 2011 see i want to get cordinate E: and N: so pls this is sample Quote Link to comment Share on other sites More sharing options...
Tharwat Posted May 1, 2011 Share Posted May 1, 2011 Your lisp looks pretty good to me. Seems to do everything the OP wanted as I interpreted his post to be also. Thanks Dink . I guess that the OP feels hard to describe his aim . Quote Link to comment Share on other sites More sharing options...
Organic Posted May 1, 2011 Share Posted May 1, 2011 see i want to get cordinate E: and N: so pls this is sample Tharwat's lisp does give you Eastings and Northings. Are you saying you want it labeled Easting first, then Northing instead of N, E? Quote Link to comment Share on other sites More sharing options...
Tharwat Posted May 1, 2011 Share Posted May 1, 2011 This is with Easting first and Northing Later . (defun c:TesT (/ *error* hgt cmd i icar icadr pt1 pt2 e) ; Tharwat 01. 05. 201 (defun *error* (msg) (and cmd (setvar 'cmdecho cmd)) (redraw) (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,")) ) (princ (strcat "\nError: " msg)) ) ) (setq Sty (tblnext "STYLE" (null Sty))) (setq cmd (getvar 'cmdecho)) (setvar 'cmdecho 0) (while (setq i (getpoint "\n Specify Corrdinates Point :") icar (car i) icadr (cadr i) ) (setq pt1 (getpoint "\n Second point of QLeader :" i)) (grdraw i pt1 3 1) (setq pt2 (getpoint "\n Last point of QLeader :" pt1)) (entmakex (list (cons 0 "LEADER") (cons 100 "AcDbEntity") (cons 100 "AcDbLeader") (cons 10 i) (cons 10 PT1) (cons 10 PT2) (cons 71 1) (cons 72 0) (cons 73 3) ) ) (entmakex (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 100 "AcDbMText") (cons 10 (trans pt2 1 0)) (cons 40 (cdr (assoc (if (zerop (cdr (assoc 40 Sty))) 42 40 ) Sty ) ) ) (cons 1 (strcat "E" ":" (rtos icar 2 0) "\n" "N" ":" (rtos icadr 2 0) ) ) ) ) (redraw) ) (setvar 'cmdecho cmd) (princ) ) Quote Link to comment Share on other sites More sharing options...
alanjt Posted May 1, 2011 Share Posted May 1, 2011 Make a block.. BTW, Tharwat, you should consider translating your coordinates before converting them to a string. Quote Link to comment Share on other sites More sharing options...
LibertyOne Posted May 1, 2011 Share Posted May 1, 2011 Make a block.. BTW, Tharwat, you should consider translating your coordinates before converting them to a string. @alnjt what software did you use to make your animation? Quote Link to comment Share on other sites More sharing options...
alanjt Posted May 1, 2011 Share Posted May 1, 2011 Camtasia.............. Quote Link to comment Share on other sites More sharing options...
LibertyOne Posted May 1, 2011 Share Posted May 1, 2011 Camtasia.............. ok, I'll have to check that out... Quote Link to comment Share on other sites More sharing options...
LibertyOne Posted May 1, 2011 Share Posted May 1, 2011 great...but I was looking for something more open source like...I googled a bit to see what is out there on the market...the screencasts that you, Lee Mac and others have made really made me think about screencasting some of the AutoLisp programs and the functionality they have that I've made over the years...your videos/animations really show off some good programs! Quote Link to comment Share on other sites More sharing options...
digger Posted May 1, 2011 Share Posted May 1, 2011 great...but I was looking for something more open source like...I googled a bit to see what is out there on the market...the screencasts that you, Lee Mac and others have made really made me think about screencasting some of the AutoLisp programs and the functionality they have that I've made over the years...your videos/animations really show off some good programs! I found this: http://camstudio.org/ Quote Link to comment Share on other sites More sharing options...
Tharwat Posted May 2, 2011 Share Posted May 2, 2011 BTW, Tharwat, you should consider translating your coordinates before converting them to a string. Thanks Alanjt . I have always forget translating coordinates . BTW. how do you convert from camtasia format to .gif format ? Regards Quote Link to comment Share on other sites More sharing options...
