pls any one can help me i need a good LISP or Toolpac for placing cordinate point or any level pls urgently suppose any point i clik i get N: E: point with leader in center
Check this out Buddy .:)
(defun c:TesT (/ *error* hgt cmd i icar icadr icaddr pt1 pt2 e)
 ; Tharwat 01. 05. 201
 (defun *error* (msg)
 (and cmd (setvar 'cmdecho cmd))
 (redraw)
 (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,")))
 (setq Sty (tblnext "STYLE" (null Sty)))
 (setq cmd (getvar 'cmdecho))
 (setvar 'cmdecho 0)
       (while
           (setq i (getpoint "\n Specify Corrdinates Point :")
            icar (car i)
            icadr (cadr i)
                icaddr (caddr i))
            (setq pt1 (getpoint "\n Second point of QLeader :" i ))
            (grdraw i pt1 3 1)
            (setq pt2 (getpoint "\n Last point of QLeader :" pt1 ))
 (entmakex (list (cons 0 "LEADER") (cons 100 "AcDbEntity") (cons 100 "AcDbLeader")
         (cons 10 i)(cons 10 PT1)(cons 10 PT2)(cons 71 1)(cons 72 0)(cons 73 3)))
 (entmakex (list (cons 0 "MTEXT") (cons 100 "AcDbEntity") (cons 100 "AcDbMText") (cons 10 (trans pt2 1 0))
           (cons 40 (cdr (assoc (if (zerop (cdr (assoc 40 Sty))) 42 40) Sty )))
           (cons 1 (strcat "N" ":" (rtos icar 2 0) "\n" "E" ":" (rtos icadr 2 0)))))
     (redraw)
TharwaT
(redraw)
(setvar 'cmdecho 0)
(while
icar (car i)
icadr (cadr i)
icaddr (caddr i))
(grdraw i pt1 3 1)
(redraw)
TharwaT
brother not this one any pther lisp pls i cant get it thanks
Is it hard to describe what you looking for in a little details ?
Your lisp looks pretty good to me. Seems to do everything the OP wanted as I interpreted his post to be also.
see i want to get cordinate E: and N: so pls this is sample
Thanks Dink .
I guess that the OP feels hard to describe his aim . :)
Tharwat's lisp does give you Eastings and Northings.
Are you saying you want it labeled Easting first, then Northing instead of N, E?
This is with Easting first and Northing Later . :D
(defun c:TesT (/ *error* hgt cmd i icar icadr pt1 pt2 e)
   (redraw)
   (if (and msg
 (setvar 'cmdecho 0)
 (while
         icar  (car i)
         icadr (cadr i)
    (setq pt1 (getpoint "\n Second point of QLeader :" i))
    (grdraw i pt1 3 1)
    (setq pt2 (getpoint "\n Last point of QLeader :" pt1))
                    (cons 10 i)
                    (cons 10 PT1)
                    (cons 10 PT2)
                    (cons 71 1)
                    (cons 72 0)
                    (cons 73 3)
    (entmakex
            (cons 40
                                42
                                40
                              Sty
            (cons 1
                  (strcat "E"
                          (rtos icar 2 0)
                          "\n"
                          "N"
                          (rtos icadr 2 0)
    (redraw)
Make a block..
BTW, Tharwat, you should consider translating your coordinates before converting them to a string.
Make a block..
@alnjt
what software did you use to make your animation?
Camtasia..............
ok, I'll have to check that out...
great...but I was looking for something more open source like...I googled a bit to see what is out there on the market...the screencasts that you, Lee Mac and others have made really made me think about screencasting some of the AutoLisp programs and the functionality they have that I've made over the years...your videos/animations really show off some good programs!
I found this:
http://camstudio.org/
Thanks Alanjt .
I have always forget translating coordinates .
BTW. how do you convert from camtasia format to .gif format ?
Regards
