I'm struggling to get my LISP to call & run another LISP (actually, it's a .vlx file). Here's the relevant bit of code:
(LOAD "SPL2PL")
(COMMAND "SPL2PL" "ALL" "" "0.1")
And here's my error message:
[DS> Another Freebee from http://www.dotsoft.com loaded, type SPL2PL to
run!SPL2PL Unknown command "SPL2PL". Press F1 for help.]
I'm confused.....
  • Replies 31
  • Lee Mac
    12
  • Rooster
    8
  • Commandobill
    6
  • alanjt
    3
(C:SPL2PL) should work, although you may have trouble with the "ALL" "" and "0.1"
thanks for the reply lee, but i'm still getting the same message after changing it...
Is the load successful?
Include an [onfailure] msg:
(load "spl2pl" "Load Failed")
(c:spl2pl)
done that - same message again, no reference to load being successful or not....
is it because it's a .vlx file rather than a .lsp? or should that not make a difference?
I wouldn't have thought it'd make a difference... I shall experiment :P
I'm not sure why your getting that error. As far as passing those arguments in know you can pass a selection set to a lisp like so...
 (sssetfirst nil (ssget "X" '((0 . "SPLINE"))))
 (C:SPL2PL)
That is of course if that is what you meant by "all"
 (C:SPL2PL)
Nice idea, but I think that would depend upon how the LISP is engineered, I think that would only work if the LISP had an ssgetfirst call to start.
I dont believe thats necessarily true. It works with burst. As long as the lisp is looking for a selection set it should work. as far as the '.01' I'm not sure how you would pass that argument
Just tested your theory, and yes, I've got to admit, you were right on this one o:)
(defun c:test ()
 (if (ssget)
   (alert "CommandoBill was right!")
   (alert "CommandoBill was wrong!"))
 (princ))
^^ code used to test theory.
(defun c:test ()
 (if (ssget)
 (princ))
Ahahahaha :P
untested, but this should work:
(defun c:TEST (/)
 (or c:SPL2PL (load "SPL2PL"))
 (vla-sendcommand
   (vla-get-activedocument
     (vlax-get-acad-object)
   ) ;_ vla-get-activedocument
   "SPL2PL all  0.1 "
 ) ;_ vla-sendcommand
) ;_ defun
I'm still struggling to get my LISP to call & run other LISPS. Below is a simple LISP that someone on here helped me with - it just filters text by style. When I try and call this LISP from another LISP I get an 'unknown command' error. How do I do it??!! aaargh!
;FILTER TEXT BY STYLE
(defun c:fts(/ cSet)
 (setq cSet(ssget
              '((0 . "TEXT,MTEXT")(7 . "Standard"))
            ); end ssget
); end setq
 (if cSet
     (princ(strcat "\n" (itoa(sslength cSet)) " found."))
     (sssetfirst nil cSet)
     ); end progn
    (princ "\nNothing found. ")
   ); end if
 ); end of c:fts
All this function is doing is calling another function and sending a selection set to it. Give it a shot. Make sure you change the "c:\\fts.lsp" to the correct location and file name of the lisp
(defun c:run ()
 (load "c:\\fts.lsp" "Load Failed");change to have the name and location of the lisp
 (sssetfirst nil (ssget))
 (c:fts)
Something like this?
(defun c:fts  (/ cSet)
 (if (setq cSet (ssget '((0 . "*TEXT") (7 . "Standard"))))
     (princ (strcat "\n" (rtos (sslength cSet) 2 0) " found."))
     (sssetfirst nil cSet))
   (princ "\n<< Nothing found >>"))
 (princ))
(defun c:test ()
 (c:fts)
 (princ))
EDIT: Beat me to it by seconds...
Wow.. literally
 (princ))
(defun c:test ()
 (c:fts)
 (princ))
so using this way would be like creating a sub-function within the lisp, right? the fts lisp that i already have is already automatically loaded into every new drawing. if i was using it on its own (ie. not through another lisp) i would just type 'fts' at the commandline and off we go. can i not do something similar when using it within another lisp? i also have quite a few other small simple lisps like the fts one that i also want to use within this lisp, so i don't really want dozens of sub-functions if i can help it. i still can't get what you've coded above to work anyway - same old error: unknown command..... :(
The fts still remains independent, and can be called on its own, and the "test" LISP is just calling it:
(c:fts)
It all works fine for me, which command is it saying is unknown?
