Rooster Posted June 25, 2009 Author Share Posted June 25, 2009 It all works fine for me, which command is it saying is unknown? ok - i seem to have got it going without the error message now. next problem (!): when i use the fts lisp within a script that i run, i use it to select all text with 'standard' text style (which is what fts does) and then change the text style of these to my own style like so: FTS (enter) ALL (enter) (enter) CHT (enter) S (enter) (enter) LDS_TEXT (enter) when running fts within this new lisp, how can i get it to do everything from 'ALL' onwards? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 25, 2009 Share Posted June 25, 2009 This will make FTS select all text items with Standard style: (defun c:fts (/ cSet) (if (setq cSet (ssget "_X" '((0 . "*TEXT") (7 . "Standard")))) (progn (princ (strcat "\n" (rtos (sslength cSet) 2 0) " found.")) (sssetfirst nil cSet)) (princ "\n<< Nothing found >>")) (princ)) (defun c:test () (c:fts) (princ)) Quote Link to comment Share on other sites More sharing options...
Rooster Posted June 25, 2009 Author Share Posted June 25, 2009 This will make FTS select all text items with Standard style: i thought it was already doing that? my problem was then in using the selection & changing it to a different text style as i would do in my script.... Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 25, 2009 Share Posted June 25, 2009 i thought it was already doing that? my problem was then in using the selection & changing it to a different text style as i would do in my script.... In the previous posted version, the user would have to select the text items manually. Quote Link to comment Share on other sites More sharing options...
Rooster Posted June 25, 2009 Author Share Posted June 25, 2009 In the previoud posted version, the user would have to select the text items manually. ah - i see! thanks - i think that helps me with my next step. much appreciated as always, lee Quote Link to comment Share on other sites More sharing options...
gilsoto13 Posted August 14, 2009 Share Posted August 14, 2009 untested, but this should work: (defun c:TEST (/) (or c:SPL2PL (load "SPL2PL")) (vla-sendcommand (vla-get-activedocument (vlax-get-acad-object) ) ;_ vla-get-activedocument "SPL2PL all 0.1 " ) ;_ vla-sendcommand (princ) ) ;_ defun I never thought it was possible... Tested and works... let's automate all of our lisps. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 15, 2009 Share Posted August 15, 2009 I never thought it was possible... You should know by now... anything is possible Quote Link to comment Share on other sites More sharing options...
alanjt Posted August 15, 2009 Share Posted August 15, 2009 You should know by now... anything is possible here at cadtutor, we make your wildest dreams come true. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 15, 2009 Share Posted August 15, 2009 here at cadtutor, we make your wildest dreams come true. I think you forgot the tags... Quote Link to comment Share on other sites More sharing options...
alanjt Posted August 15, 2009 Share Posted August 15, 2009 I think you forgot the tags... the sleepy guy was the best i could do. i didn't like the eye rolling one. Quote Link to comment Share on other sites More sharing options...
TheyCallMeJohn Posted December 5, 2013 Share Posted December 5, 2013 Is there a way though to call another lisp command when the first lisp finishes or a way to make the lisp quit and call another one. (Sorry to hijack the thread but there are several already with almost the exact same title...) Quote Link to comment Share on other sites More sharing options...
MSasu Posted December 6, 2013 Share Posted December 6, 2013 call another lisp command when the first lisp finishes Do you have access to the code? If yes, then just add a call statement at its end: (defun MyFunction1st() ... [color=magenta] (MyFunction2nd) ;add call to second function[/color] (princ) ) Other: (defun MyFunction3rd() (MyFunction1st) ;call first function (MyFunction2nd) ;call second function (princ) ) Or, maybe, take a look to reactors. make the lisp quit and call another one. Can you give us more details on this? You are looking to call the second function instead of first? For this case, if the symbol isn't protected, redefine it: (defun MyFunction1st() (MyFunction2nd) ;call second function (princ) ) Quote Link to comment Share on other sites More sharing options...
