Sequential numbering a single attribute value in multiple attribute block
Hi all,
I am starting this new topic in the hope of getting better response. I found a topic which almost met my requirement here in the 8th post by ASMI. The difference is my blocks have multiple attributes.
My requirements are these:
1. User selects multiple block instances
2. User enters tag (choose if possible, hard coded also will do)
3. User enters starting number, including leading zeros, but no prefix or suffix
4. Routine puts in sequential numbers with leading zeros in the attribute value, starting at top left block, goes left to right, top to bottom.
In step 3 above, if the routine can 'remember' the last number of previous execution and continues, well and good. May be its difficult or impossible. If it can be done, then the routine might just as well 'remember' last tag used so that the user need only press enter on subsequent executions.
Can someone please help me on this?
Thanks in advance, this forum is wonderful.
Guite
  • Replies 43
  • Guite
    8
  • ASMI
    6
  • fixo
    4
  • jva
    4
Posted Images
Guest Alan Cullen
I'll just work on one problem at a time, your other one. :lol:
I'll leave this one for ASMI to sort out. o:)
I thought that one was a closed chapter :lol:. Anyway the two are related. If you can provide a solution to that one, it would be great.
Guite
Guest Alan Cullen
Guite,
Go back to the other thread, do what I asked, and I'll sort it out for you. o:)
1. Specify start number
2. Pick to wanted attribute
3. Select blocks and press Spacebar
Enjoy...
(defun c:mnum(/ stStr stNum nLen cAtr dLst blName
      fLst blLst blSet aName sLst lZer aStr)
 (vl-load-com)
 (if
   (and
     (setq stStr(getstring "\nSpecify start number: "))
     (setq stNum(atoi stStr))
     (setq nLen(strlen stStr))
     ); end and
     (if
(and
   (setq cAtr(nentsel "\nPick attribute > "))
   (= "ATTRIB"(cdr(assoc 0(setq dLst(entget(car cAtr))))))
  ); end and
  (setq blName
    (vla-get-Name
       (vla-ObjectIDToObject
	  (vla-get-ActiveDocument
	     (vlax-get-acad-object))
	        (vla-get-OwnerID
	           (vlax-ename->vla-object(car cAtr)))))
	fLst(list '(0 . "INSERT")(cons 2 blName))
	aName(cdr(assoc 2 dLst))
	); end setq
  (princ "\n<<< Select blocks to number >>> ")
  (if
    (setq blSet(ssget fLst))
     (setq sLst
                   (mapcar 'vlax-ename->vla-object
	      (mapcar 'car
	       (vl-sort
	        (vl-sort
	          (mapcar '(lambda(x)(list x(cdr(assoc 10(entget x)))))
	            (vl-remove-if 'listp
                             (mapcar 'cadr(ssnamex blSet))))
	                '(lambda(a b)(<(caadr a)(caadr b))))
		          '(lambda(a b)(>(cadadr a)(cadadr b)))))))
     (foreach i sLst
       (setq lZer "")
       (repeat(- nLen(strlen(itoa stNum)))
	 (setq lZer(strcat lZer "0"))
	 ); end repeat
       (setq atLst
	      (vlax-safearray->list
		 (vlax-variant-value
		   (vla-GetAttributes i))))
       (foreach a atLst
	 (if
	   (= aName(vla-get-TagString a))
	      (vla-put-TextString a
		(strcat lZer(itoa stNum)))
	   ); end if
	 ); end foreach
	 (setq stNum(1+ stNum))
       ); end foreach
      ); end progn
    (princ "\nEmpty selection! Quit. ")
    ); end if
  ); end progn
(princ "\nThis isn't attribute! Quit. ")
); end if
     ); end progn
   (princ "\nInvalid start number! Quit. ")
   ); end if
 ); end of c:mnum
Thanks a lot, ASMI. I will try it out on Monday.
Cheers,
Guite
WOW! Just tested it and it works like a charm. Thank you so much ASMI.
Cheers,
Guite
Guest Alan Cullen
The guru strikes again. Guite, ASMI hates being refered to as a guru, but he really is, along with a few others here. :P o:)
Oh I see. So that's our little secret. Promise, I will only reveal it judiciously. :)
Guite
Hi ASMI,
Please look at the attached files. The numbering sequence in your script is based on world UCS. Can it be modified to read local/screen UCS? As it stands now, the sequence will be very difficult to follow/track when the drawing is printed.
Anyway, your script works perfectly when everything is aligned to world UCS. Thanks once again for your help this far.
Guite
DOOR-DD01.dwg
Ok. Try it.
 (vl-load-com)
 (if
   (and
     ); end and
     (if
(and
  ); end and
  (setq blName
    (vla-get-Name
	        (vla-get-OwnerID
	); end setq
  (if
     (setq sLst
	      (mapcar 'car
	       (vl-sort
	        (vl-sort
		   (trans(cdr(assoc 10(entget x)))0 1)))
     (foreach i sLst
       (setq lZer "")
	 ); end repeat
       (setq atLst
		 (vlax-variant-value
       (foreach a atLst
	 (if
	   ); end if
	 ); end foreach
       ); end foreach
      ); end progn
    ); end if
  ); end progn
); end if
     ); end progn
   ); end if
 ); end of c:mnum
ASMI, you da man!!! It works perfectly (until I find another bug :wink: 8), just kidding of course).
Thank you very much. :D:D:D
Guite
  • 3 months later...
I Would Like To Have This Add +2 So Say Your Start # Is 100 Your Next Would Be 102, 104, Etc... How Would I Change It To Do That?
Find line:
and change to
(setq stNum(+ 2 stNum))
  • 5 months later...
Sorry to bring up an old thread, but I'm using this lisp, and is there a way to make it change the blocks by select order the way tcount does?
Thanks so much.
Oops! One more submarine come to the surface.
... and is there a way to make it change the blocks by select order the way tcount does?
Because not? I will think about it next week. Today I have other work.
just a sidenote:
express' acettxt.lsp may give a hint how it sorts its entities.
