Guite
Sequential numbering a single attribute value in multiple attribute block
Guite
Hi all,
I am starting this new topic in the hope of getting better response. I found a topic which almost met my requirement here in the 8th post by ASMI. The difference is my blocks have multiple attributes.
My requirements are these:
1. User selects multiple block instances
2. User enters tag (choose if possible, hard coded also will do)
3. User enters starting number, including leading zeros, but no prefix or suffix
4. Routine puts in sequential numbers with leading zeros in the attribute value, starting at top left block, goes left to right, top to bottom.
In step 3 above, if the routine can 'remember' the last number of previous execution and continues, well and good. May be its difficult or impossible. If it can be done, then the routine might just as well 'remember' last tag used so that the user need only press enter on subsequent executions.
Can someone please help me on this?
Thanks in advance, this forum is wonderful.
Guite
Share this post
Link to post
Guest Alan Cullen
I'll just work on one problem at a time, your other one. :lol:
I'll leave this one for ASMI to sort out. o:)
Share this post
Link to post
Guite
I thought that one was a closed chapter :lol:. Anyway the two are related. If you can provide a solution to that one, it would be great.
Guite
Share this post
Link to post
Guest Alan Cullen
Guite,
Go back to the other thread, do what I asked, and I'll sort it out for you. o:)
Share this post
Link to post
ASMI
1. Specify start number
2. Pick to wanted attribute
3. Select blocks and press Spacebar
Enjoy...
(defun c:mnum(/ stStr stNum nLen cAtr dLst blName
      fLst blLst blSet aName sLst lZer aStr)
 (vl-load-com)
 (if
   (and
     (setq stStr(getstring "\nSpecify start number: "))
     (setq stNum(atoi stStr))
     (setq nLen(strlen stStr))
     ); end and
     (if
(and
   (setq cAtr(nentsel "\nPick attribute > "))
   (= "ATTRIB"(cdr(assoc 0(setq dLst(entget(car cAtr))))))
  ); end and
  (setq blName
    (vla-get-Name
       (vla-ObjectIDToObject
	  (vla-get-ActiveDocument
	     (vlax-get-acad-object))
	        (vla-get-OwnerID
	           (vlax-ename->vla-object(car cAtr)))))
	fLst(list '(0 . "INSERT")(cons 2 blName))
	aName(cdr(assoc 2 dLst))
	); end setq
  (princ "\n<<< Select blocks to number >>> ")
  (if
    (setq blSet(ssget fLst))
     (setq sLst
                   (mapcar 'vlax-ename->vla-object
	      (mapcar 'car
	       (vl-sort
	        (vl-sort
	          (mapcar '(lambda(x)(list x(cdr(assoc 10(entget x)))))
	            (vl-remove-if 'listp
                             (mapcar 'cadr(ssnamex blSet))))
	                '(lambda(a b)(<(caadr a)(caadr b))))
		          '(lambda(a b)(>(cadadr a)(cadadr b)))))))
     (foreach i sLst
       (setq lZer "")
       (repeat(- nLen(strlen(itoa stNum)))
	 (setq lZer(strcat lZer "0"))
	 ); end repeat
       (setq atLst
	      (vlax-safearray->list
		 (vlax-variant-value
		   (vla-GetAttributes i))))
       (foreach a atLst
	 (if
	   (= aName(vla-get-TagString a))
	      (vla-put-TextString a
		(strcat lZer(itoa stNum)))
	   ); end if
	 ); end foreach
	 (setq stNum(1+ stNum))
       ); end foreach
      ); end progn
    (princ "\nEmpty selection! Quit. ")
    ); end if
  ); end progn
(princ "\nThis isn't attribute! Quit. ")
); end if
     ); end progn
   (princ "\nInvalid start number! Quit. ")
   ); end if
 ); end of c:mnum
Share this post
Link to post
Guite
Thanks a lot, ASMI. I will try it out on Monday.
Cheers,
Guite
Share this post
Link to post
Guite
WOW! Just tested it and it works like a charm. Thank you so much ASMI.
Cheers,
Guite
Share this post
Link to post
Guest Alan Cullen
The guru strikes again. Guite, ASMI hates being refered to as a guru, but he really is, along with a few others here. :P o:)
Share this post
Link to post
Guite
Oh I see. So that's our little secret. Promise, I will only reveal it judiciously. :)
Guite
Share this post
Link to post
Guite
Hi ASMI,
Please look at the attached files. The numbering sequence in your script is based on world UCS. Can it be modified to read local/screen UCS? As it stands now, the sequence will be very difficult to follow/track when the drawing is printed.
Anyway, your script works perfectly when everything is aligned to world UCS. Thanks once again for your help this far.
Guite
DOOR-DD01.dwg
Share this post
Link to post
ASMI
Ok. Try it.
 (vl-load-com)
 (if
   (and
     ); end and
     (if
(and
  ); end and
  (setq blName
    (vla-get-Name
	        (vla-get-OwnerID
	); end setq
  (if
     (setq sLst
	      (mapcar 'car
	       (vl-sort
	        (vl-sort
		   (trans(cdr(assoc 10(entget x)))0 1)))
     (foreach i sLst
       (setq lZer "")
	 ); end repeat
       (setq atLst
		 (vlax-variant-value
       (foreach a atLst
	 (if
	   ); end if
	 ); end foreach
       ); end foreach
      ); end progn
    ); end if
  ); end progn
); end if
     ); end progn
   ); end if
 ); end of c:mnum
Share this post
Link to post
Guite
ASMI, you da man!!! It works perfectly (until I find another bug :wink: 8), just kidding of course).
Thank you very much. :D:D:D
Guite
Share this post
Link to post
JSNORTIN
I Would Like To Have This Add +2 So Say Your Start # Is 100 Your Next Would Be 102, 104, Etc... How Would I Change It To Do That?
Share this post
Link to post
ASMI
Find line:
and change to
(setq stNum(+ 2 stNum))
Share this post
Link to post
Trebuchet
Sorry to bring up an old thread, but I'm using this lisp, and is there a way to make it change the blocks by select order the way tcount does?
Thanks so much.
Share this post
Link to post
ASMI
Oops! One more submarine come to the surface.
... and is there a way to make it change the blocks by select order the way tcount does?
Because not? I will think about it next week. Today I have other work.
Share this post
Link to post
Trebuchet
Thank you!
Share this post
Link to post
wizman
just a sidenote:
express' acettxt.lsp may give a hint how it sorts its entities.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
