Showing results for tags '2d taper'.
  1. I'm looking for a way to produce a tapered offset in AutoCad 2008 (a simple linear taper will do for a starter), perhaps by specifying starting and ending offset distances to be applied along the length of a selected arc, polyline (2D) or spline. I'm thinking that this will probably require some code, although it seems like this might be a fairly common requirement, such that there would be an existing solution that I just haven't gleaned as yet. Thoughts?
