Showing results for tags 'acad_sortents'.
More search options
  1. Hello there! I need to make a small sub which aims putting all modelspace hatch objects to bottom in draw order. I've debugged the code below, but the line in red never works. Now I'm trapped in here. Please someone help me out? Thanks a million. Sub hatch_to_back() Dim eDictionary As ObjectDim sentityObj As Object Dim A1_STB(0) As Object For Each b In ThisDrawing.ModelSpace If TypeName(b) = "IAcadHatch" Then Set eDictionary = ThisDrawing.ModelSpace.GetExtensionDictionary* On Error Resume Next* Set sentityObj = eDictionary.GetObject("ACAD_SORTENTS") If sentityObj Is Nothing Then* Set sentityObj = eDictionary.AddObject("ACAD_SORTENTS", "AcDbSortentsTable") End If Set A1_STB(0) = b sentityObj.MoveToBottom A1_STB AcadApplication.Update End If Next End Sub
