Showing results for tags 'areat pline text'.
  1. I need some help solving a problem with a lisp routine. The routine work in earlier version of cad2009 but will not work in 2013. I am trying to replace text value with the area in sq. ft.after picking a polyline. I am onlygetting text replacement in sq. inches. [font=Times New Roman][size=3][/size][/font] [font=Calibri];;;CADDMAN: Area7.LSP Area Output (c) 2007 Kirby Turner [/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri](defun c:area7 (/ a1)[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri](SETQ A1 (ENTSEL "Area of tract<pickobject>: "))[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri](command "area" "e" a1)[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri](setq el (getvar "area"))[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri](setq d1 144)[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri] (setqfl (rtos (el 2 2))[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri] (setqe1 ( / f1 d1)[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri] ;;;(rtos(/ e1 144.0) 2 3)[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri];;;(rtos (/ e1 144.0) 2 3)[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri] (SETQED(ENTGET (CAR (NENTSEL "\nPick TEXT to change:"))))[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri] (setvar"CMDECHO" 0)[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri] (COMMAND"TEXTEVAL" 1)[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri] (SETQ ED(SUBST (cons 1 e1)[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri] (ASSOC 1 ED)[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri] ED[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri] )[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri])[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri](ENTMOD ED)[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri])[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri](alert[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri] (strcat"area7.LSP"[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri] "\n\n Type area7 to start"))[/font] [font=Times New Roman][size=3][/size][/font] [font=Calibri](princ)[/font] [font=Times New Roman][size=3] [/size][/font]
