Good afternoon,
I am writing a simple LISP routine that I can run and will check / change drawing layers, colours etc to the client requirements. Saves me missing something as I go through the drawings.
For the title block they want it all on layer "Title", but to have different colours for different texts. So title description might be in Yellow, drawing number might be Red.
My idea for this is to modify the block attributes to the colours needed.
I am looking at adding a line or 2 to my LISP to modify the colours of the text.
I have tried using -attedit, which is OK, but seams to want a user input to select the block attributes to modify.
Any help would be great.
All the title blocks are the same, I know the block name and attribute names (MyBlock, Title_1, Title_2... Number, Project)
Ideally looking for something like
(command (MyBlock, Title_1, Color, "1"))
to set Title_1 to Red.
Sounds easy, and I am pretty sure it is I just need a bit of help. Thanks
