Showing results for tags 'autocad vb.net'.
Good Day I am looking to get the linetype name from the AutoCAD LineType dialog Box, as shown below: I want to use the LineType name - the code i have generated only returns the ID as a string - unable to find what parameter will return the line name as a string?? [size=2][/size][size=2][color=#0000ff][size=2][color=#0000ff]Private[/color][/size][/color][/size][size=2] [/size][size=2][color=#0000ff][size=2][color=#0000ff]Sub[/color][/size][/color][/size][size=2] But_LTCon_Click([/size][size=2][color=#0000ff][size=2][color=#0000ff]ByVal[/color][/size][/color][/size][size=2] sender [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] System.Object, [/size][size=2][color=#0000ff][size=2][color=#0000ff]ByVal[/color][/size][/color][/size][size=2] e [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] System.EventArgs) [/size][size=2][color=#0000ff][size=2][color=#0000ff]Handles[/color][/size][/color][/size][size=2] But_LTCon.Click [/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] xLineType [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] [/size][size=2][color=#0000ff][size=2][color=#0000ff]String[/color][/size][/color][/size] [size=2]xLineType = ShowLineTypeDialog() Txt_LTCon.Text = xLineType.ToString LtypeCon = xLineType.ToString [/size][size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2] [/size][size=2][color=#0000ff][size=2][color=#0000ff]Sub [/color][/size][/color][/size] [size=2][/size][size=2][color=#0000ff][size=2][color=#0000ff]Public[/color][/size][/color][/size][size=2] [/size][size=2][color=#0000ff][size=2][color=#0000ff]Function[/color][/size][/color][/size][size=2] ShowLineTypeDialog() [/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] acDoc [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] Document = Application.DocumentManager.MdiActiveDocument [/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] acCurDb [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] Database = acDoc.Database [/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] xLIneTypeDialog [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] [/size][size=2][color=#0000ff][size=2][color=#0000ff]New[/color][/size][/color][/size][size=2] LinetypeDialog() [/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] dr [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] System.Windows.Forms.DialogResult dr = xLIneTypeDialog.ShowDialog() [/size][size=2][color=#0000ff][size=2][color=#0000ff]If[/color][/size][/color][/size][size=2] dr = Windows.Forms.DialogResult.OK [/size][size=2][color=#0000ff][size=2][color=#0000ff]Then [/color][/size][/color][/size][size=2][/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] SelLineType [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] [/size][size=2][color=#0000ff][size=2][color=#0000ff]String[/color][/size][/color][/size] [size=2]SelLineType = xLIneTypeDialog[color=red][b].Linetype[/b][/color].ToString ([color=red]Returns ID want the Name?[/color][color=black])[/color] [/size][size=2][color=#0000ff][size=2][color=#0000ff]Return[/color][/size][/color][/size][size=2] SelLineType [/size][size=2][color=#0000ff][size=2][color=#0000ff]ElseIf[/color][/size][/color][/size][size=2] dr = Windows.Forms.DialogResult.Cancel [/size][size=2][color=#0000ff][size=2][color=#0000ff]Then [/color][/size][/color][/size][size=2][/size][size=2][color=#0000ff][size=2][color=#0000ff]Return[/color][/size][/color][/size][size=2] [/size][size=2][color=#a31515][size=2][color=#a31515]"Cancell" [/color][/size][/color][/size][size=2][/size][size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2] [/size][size=2][color=#0000ff][size=2][color=#0000ff]If [/color][/size][/color][/size][size=2][/size][size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2] [/size][size=2][color=#0000ff][size=2][color=#0000ff]Function [/color][/size][/color][/size] Any Help - Much Appreciated Regards CaveMan
- 3 replies
- linetype
- autocad vb.net
