Showing results for tags 'autodesk inventor 2013'.
Covert a 3D Model file (.stp) to a 2D .dwg file
HaroldSJS posted a topic in AutoCAD 3D Modelling & Rendering
This has probably been asked before, but if it has, can you please direct me to the thread? I am a new user to AutoDesk 2013. I have a bunch of .stp files, which I would like to convert to 2D .dwg s, which have all dimensions, as part of the. Is there a plug-in, or a stand alone software package, which can read the .stp, and extrapolate the embedded dimensions? Again, I would imagine this has been asked many times before. Sorry for the redundancy! Can you direct me to the answer?http://www.cadtutor.net/forum/images/icons/icon5.gif Thanks! -
While using the new version of autodesk software, I facing several problems:- 1. Lag while selecting the plan to sketch causing selecting wrong plane. - computer spec (8gb ram, firepro v4800, intel xeon) 2. While using constrain to assemble parts, the preview didn't show even I check the "show preview" check box. 3. Change the part's appearance in assembly, but the part's appearance in .ipt didn't change. 4. The "rules" can't function well for complex machine. 1st time run is fine but after save and then open again it occur error. - example, the part should be hide but still show out in main assembly but sub assmbly already hide. [Feel weird because 3d should be link together each other] 5. Using paste special to paste the excel table into .dwg file to sustain the link but if the table to big ,the table in drawing will miss some data. - example, I copy the table from range a1 to v9 but the thing paste out just a1 to s9. That some of the problems I facing. Anyone have face same problems and have solution. Please help and thank you. There are another question I would like to ask because I just start using this software. So there is many things I don't know, 1. What is Level of Detail? usage? 2. Don't have auto dimension function for creating dimension for drawing? 3. Ipart will auto generate out the configurate part file? 4. Can not use rule to control the ipart? Like changing it's length. 4. Can I extrude parameter data from the rule or ipart configuration setting to excel file? 5. This is the right software for a machine while many variation? Previously, I am using solidworks and feel that solidworks in 3d model look like more advance than inventor. Thank you in advance.
- 6 replies
- basic question
- autodesk inventor 2013
