I’m trying to draw a model of a part, using the original 2d sketch and a picture... I am having a hard time figuring out how to blend all these corners and included drafts. I am self taught with this software and probably over my head with this. I’ve done most of the online tutorials and visited all the forums, but nothing seems to relate to my part... Im pretty sure i am going about this the wrong way.. should i be using surfaces instead??
This is a quick "throw together" of sketches i am just pulling off the dwg. so not much has been put in to Inventors sketch constraints. Once I figure out how to blend everything together, i will go back and re do it all properly. The attached picture is from an old worn out part, and in the end, the new part just needs to "look" right. Any help is appreciated. I’ve also attached the dwg and my ipt file.
part.zip
orig2d.dwg
